AD1224HB-Y51
AD1224HB-Y51
    ADDA(協禧電機)
AD1224HB-Y51 数据手册
AD12032 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve○=1B1S ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) (CFM) (InAq) (mmAq) 0.96 1450 1.682 59.461 0.075 1.905 26.9 36.2 Rated System Voltage Current Type (VDC) (mm) 120x120x32 Rated Bearing AD1212DB-Y51 ◎※ ● 12 0.08 *Noise Level Weight (dB/A) (g) AD1212LB- Y51 ◎※ ● 12 0.19 2.28 2000 2.348 82.981 0.123 3.124 AD1212MB- Y51 ◎※ ● 12 0.26 3.12 2400 2.803 99.069 0.167 4.241 41.1 AD1212HB- Y51 ◎※ ● 12 0.32 3.84 2750 3.161 111.710 0.241 6.121 43.3 AD1212UB- Y51 ◎※ ● 12 0.51 6.12 3200 3.776 133.440 0.317 8.051 48.4 AD1224DB- Y51 ◎※ ● 24 0.05 1.20 1450 1.682 59.461 0.075 1.905 26.9 AD1224LB- Y51 ◎※ ● 24 0.10 2.40 2000 2.348 82.981 0.123 3.124 36.2 AD1224MB- Y51 ◎※ ● 24 0.16 3.84 2400 2.803 99.069 0.167 4.241 41.1 AD1224HB- Y51 ◎※ ● 24 0.21 5.04 2750 3.161 111.710 0.241 6.121 43.3 AD1224UB- Y51 ◎※ ● 24 0.32 7.68 3200 3.776 133.440 0.317 8.051 48.4 AD1248HB- Y51 ◎※ ● 48 0.11 5.28 2750 3.161 111.710 0.241 6.121 43.3 AD1248UB- Y51 ◎※ ● 48 0.15 7.20 3200 3.776 133.440 0.317 8.051 48.4 213.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.000 10.0 0.849 1.698 2.547 3.396 風扇型號: M D 4.245 0.390 L H 0.312 6.0 0.234 4.0 0.156 2.0 0.078 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) U 8.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 30 60 90 120 150 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD1224HB-Y51 价格&库存
很抱歉,暂时无法提供与“AD1224HB-Y51”相匹配的价格&库存,您可以联系我们找货
