AK1861HB-AW
AK1861HB-AW
    ADDA(協禧電機)
AK1861HB-AW 数据手册
AK18065 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Bearing size Model No. System (mm) Type AK1861HB 180x180x65 Volt. (VAC) (Hz) 115 ◎ A K1862HB Freq. 50/60 230 Rated Maximum Maximum AirFlow Pressure Current Power Speed (A) (W) (rpm) (CMM) (CFM) 0.55/0.48 59.80/55.20 0.20/0.22 46.50/51.10 2800/3200 9.905/11.603 350.0/410.0 (InAq) 0.700/0.850 (mmAq) *Noise Level Weight (dB/A) (g) 17.780/21.590 70.0/72.0 1800 Specif ic atio ns subje ct to change wit hout notic e. 60Hz 50Hz Fan Performance Curve Fan Performance Curve FLOWRATE(CMM) 2.820 5.640 8.460 FLOWRATE(CMM) 11.280 14.100 24.0 0.000 0.944 2.820 5.640 8.460 11.280 0.944 風扇型號: 風扇型號: 21.0 0.826 21.0 0.826 H 0.708 15.0 0.590 12.0 0.472 9.0 0.354 6.0 3.0 0.0 100 200 300 FLOWRATE(CFM) C 400 500 18.0 0.708 15.0 0.590 12.0 0.472 9.0 0.354 0.236 6.0 0.236 0.118 3.0 0.118 0.000 0.0 STATIC PRESSURE(mmAq) 18.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) H 0 14.100 24.0 STATIC PRESSURE(InAq) 0.000 *Safety approvals 0.000 0 100 200 300 400 500 FLOWRATE(CFM) COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AK1861HB-AW 价格&库存
很抱歉,暂时无法提供与“AK1861HB-AW”相匹配的价格&库存,您可以联系我们找货
