AD1212DB-A71GL
AD1212DB-A71GL
    ADDA(協禧電機)
    DC Fan Axial Ball Bearing 12V 56.3CFM 24.7dB (120 X 120 X 25mm)
AD1212DB-A71GL 数据手册
AD12025 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size (mm) 120x120x25 Rated Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) Bearing Rated System Voltage Current Type (VDC) (CFM) AD1212DB-A7BGL ◎※ ● 12 0.11 1.32 1500 1.618 57.205 (InAq) (mmAq) 0.074 1.879 *Noise Level Weight (dB/A) (g) 27.2 AD1212LB-A7BGL ◎※ ● 12 0.15 1.80 1800 2.032 71.806 0.093 2.362 34.4 AD1212MB-A7BGL ◎※ ● 12 0.16 1.92 2050 2.293 81.054 0.113 2.870 38.0 AD1212HB-A7BGL ◎※ ● 12 0.29 3.48 2200 2.486 87.870 0.134 3.403 39.1 AD1212UB-A7BGL ◎※ ● 12 0.39 4.68 2500 2.800 98.965 0.174 4.419 43.3 AD1224DB-A7BGL ◎※ ● 24 0.07 1.68 1500 1.618 57.205 0.074 1.879 27.2 AD1224LB-A7BGL ◎※ ● 24 0.10 2.40 1800 2.032 71.806 0.093 2.362 34.4 AD1224MB-A7BGL ◎※ ● 24 0.13 3.12 2050 2.293 81.054 0.113 2.870 38.0 AD1224HB-A7BGL ◎※ ● 24 0.13 3.12 2200 2.486 87.870 0.134 3.403 39.1 AD1224UB-A7BGL ◎※ ● 24 0.19 4.56 2500 2.800 98.965 0.174 4.419 43.3 AD1248HB-A7BGL ◎※ ● 48 0.10 4.80 2200 2.486 87.870 0.134 3.403 39.1 AD1248UB-A7BGL ◎※ ● 48 0.12 5.76 2500 2.800 98.965 0.174 4.419 43.3 156.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.000 6.0 0.679 1.358 2.037 2.716 風扇型號: 3.395 0.236 M L D H 4.8 0.189 3.6 0.142 2.4 0.094 1.2 0.047 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) U *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 24 48 72 96 120 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD1212DB-A71GL 价格&库存
很抱歉,暂时无法提供与“AD1212DB-A71GL”相匹配的价格&库存,您可以联系我们找货
