AD0424HB-G70
AD0424HB-G70
    ADDA(協禧電機)
AD0424HB-G70 数据手册
AD4010(8) SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve○=1B1S ●=Hypro bearin g Rated Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) 0.07 0.35 4200 0.119 4.20 5 0.11 0.55 4800 0.142 5.00 5 0.16 0.80 6000 0.175 6.20 ◎※○● 12 0.06 0.72 4200 0.119 4.20 AD0412MB-G70(8) ◎※○● 12 0.06 0.72 4800 0.142 AD0412HB-G70(8) ◎※○● 12 0.09 1.08 6000 Bearing Rated System Voltage Current Type (VDC) AD0405LB-G70 (8) ◎※○● 5 AD0405MB-G70(8) ◎※○● AD0405HB-G70(8) ◎※○● AD0412LB-G70(8) Frame Model No. size (mm) 40x40x10 *Noise Level Weight (mmAq) (dB/A) (g) 1.52 21.0 0.078 1.98 22.0 0.100 2.54 26.0 0.060 1.52 21.0 5.00 0.078 1.98 22.0 0.175 6.20 0.100 2.54 26.0 (CFM) (InAq) 0.060 AD0424LB-G70(8) ◎※○● 24 0.03 0.72 4200 0.119 4.20 0.060 1.52 21.0 AD0424MB-G70(8) ◎※○● 24 0.04 0.96 4800 0.142 5.00 0.078 1.98 22.0 AD0424HB-G70( 8 ) ◎※○● 24 0.06 1.44 6000 0.175 6.20 0.100 2.54 26.0 17.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.000 3.0 0.045 0.090 0.136 0.181 L 風扇型號: 0.226 0.118 M *Motor protective circuit and third lead wire functions H 2.4 0.094 1.8 0.071 1.2 0.047 0.6 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.024 0.0 0.000 0.0 1.6 3.2 4.8 6.4 8.0 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0424HB-G70 价格&库存
很抱歉,暂时无法提供与“AD0424HB-G70”相匹配的价格&库存,您可以联系我们找货
