AD1212DB-F51
AD1212DB-F51
    ADDA(協禧電機)
AD1212DB-F51 数据手册
AD12038 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure Level Weight (A) (W) (rpm) (CMM) (CFM) (InAq) (mmAq) (dB/A) (g) 0.12 1.44 1500 1.621 57.292 0.085 2.159 28.4 Rated System Voltage Current Type (VDC) 12 (mm) 120x120x38 Rated Bearing AD1212DB-F5B(N) ◎※ ● *Noise AD1212LB- F5B(N) ◎※ ● 12 0.22 2.64 1950 2.027 71.635 0.128 3.251 36.2 AD1212MB- F5B(N) ◎※ ● 12 0.34 4.08 2540 2.725 96.300 0.228 5.791 45.0 AD1212HB- F5B(N) ◎※ ● 12 0.39 4.68 2800 2.984 105.461 0.265 6.731 46.7 AD1212UB- F5B(N) ◎※ ● 12 0.62 7.44 3200 3.399 120.109 0.335 8.509 48.0 AD1224DB- F5B(N) ◎※ ● 24 0.07 1.68 1500 1.621 57.292 0.085 2.159 28.4 AD1224LB- F5B(N) ◎※ ● 24 0.10 2.40 1950 2.027 71.635 0.128 3.251 36.2 AD1224MB- F5B(N) ◎※ ● 24 0.20 4.80 2540 2.725 96.300 0.228 5.791 45.0 AD1224HB- F5B(N) ◎※ ● 24 0.26 6.24 2800 2.984 105.461 0.265 6.731 46.7 AD1224UB- F5B(N) ◎※ ● 24 0.38 9.12 3200 3.399 120.109 0.335 8.509 48.0 AD1248LB- F5B(N) ◎※ ● 48 0.09 4.32 1950 2.027 71.635 0.128 3.251 36.2 AD1248MB- F5B(N) ◎※ ● 48 0.13 6.24 2540 2.725 96.300 0.228 5.791 45.0 AD1248HB- F5B(N) ◎※ ● 48 0.18 8.64 2800 2.984 105.461 0.265 6.731 46.7 AD1248UB- F5B(N) ◎※ ● 48 0.22 10.56 3200 3.399 120.109 0.335 8.509 48.0 235.0 /Plastic 297.0 /Aluminum Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.000 10.0 0.792 1.585 2.377 3.170 風扇型號: 3.962 0.394 M L D H 0.315 6.0 0.236 4.0 0.157 2.0 0.079 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) U 8.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.0 0.000 0 28 56 84 112 140 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD1212DB-F51 价格&库存
很抱歉,暂时无法提供与“AD1212DB-F51”相匹配的价格&库存,您可以联系我们找货
