AD5012HB-D70
AD5012HB-D70
    ADDA(協禧電機)
    ADDA - AD5012HB-D70 - AXIAL FAN, 50MM, 12VDC, 140mA
AD5012HB-D70 数据手册
AD5015 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve○=1B1S ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) (CFM) (InAq) (mmAq) 0.129 3.277 34.0 25.0 Rated System Voltage Current Type (VDC) (mm) 50x50x15 Rated Bearing AD5005HB-D70 ◎※ ● 5 0.21 1.05 4800 0.404 14.30 *Noise Level Weight (dB/A) (g) AD5012LB-D70 ◎※ ● 12 0.07 0.84 3600 0.312 11.00 0.070 1.778 AD5012MB-D70 ◎※ ● 12 0.08 0.96 4300 0.367 13.00 0.100 2.540 30.0 AD5012HB-D70 ◎※ ● 12 0.11 1.32 4800 0.404 14.30 0.129 3.277 34.0 AD5012UB-D70 ◎※ ● 12 0.14 1.68 5500 0.467 16.50 0.180 4.572 37.5 27.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve *Motor protective circuit and third lead wire functions(5V/24V) FLOWRATE(CMM) 0.113 0.226 0.339 M L H U 0.189 3.6 0.142 2.4 0.094 1.2 0.047 0.0 0.0 0 1 2 3 4 6 7 8 9 A B 0.565 0.236 4.8 STATIC PRESSURE(mmAq) 0.452 4.0 8.0 12.0 16.0 STATIC PRESSURE(InAq) 0.000 6.0 *Motor protective circuit and third lead wire functions(12V) 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 20.0 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD5012HB-D70 价格&库存
很抱歉,暂时无法提供与“AD5012HB-D70”相匹配的价格&库存,您可以联系我们找货
