AD0412MB-C71GP
AD0412MB-C71GP
    ADDA(協禧電機)
AD0412MB-C71GP 数据手册
AD4020GP SERIES Exter nal Dimensions Frame:Plastic(UL:94V-0) Impeller:Plastic(UL:94V-0) Lead wire:UL1007AWG26 Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure Level Weight (A) (W) (rpm) (CMM) (CFM) (InAq) (mmAq) (dB/A) (g) 0.08 0.96 5000 0.181 6.40 0.150 3.81 19.0 Rated System Voltage Current Type (VDC) (mm) 40x40x20 Rated Bearing *Noise AD0412LB-C73GP(P) ◎ 12 AD0412MB-C73 GP(P) ◎ 12 0.12 1.44 6200 0.226 8.00 0.230 5.84 26.0 AD0412HB-C73 GP(P) ◎ 12 0.14 1.68 7200 0.266 9.40 0.320 8.13 30.0 AD0412UB-C73 GP(P) ◎ 12 0.15 1.80 8200 0.311 11.00 0.400 10.16 33.0 AD0412XB-C73 GP(P) ◎ 12 0.24 2.88 10000 0.368 13.00 0.540 13.72 42.0 28.0 Specif ic atio ns subje ct to change wit hout notic e. Fan Performance Curve FLOWRATE(CMM) 0.000 18.0 0.084 0.168 0.252 0.336 0.420 0.705 風扇型號: H M L U 0.564 10.8 0.423 7.2 0.282 3.6 0.141 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) X 14.4 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 3 6 9 12 15 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0412MB-C71GP 价格&库存
很抱歉,暂时无法提供与“AD0412MB-C71GP”相匹配的价格&库存,您可以联系我们找货
