AD0812HB-D71
AD0812HB-D71
    ADDA(協禧電機)
AD0812HB-D71 数据手册
AD8015 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve○=1B1S ●=Hypro bearin g Bearing Rated Rated Maximum System Voltage Current Power Speed AirFlow Type (VDC) (A) (W) (rpm) (CMM) (CFM) (InAq) AD0805MB-D71 ◎※○● 5 0.13 0.65 2440 0.634 22.40 0.070 AD0805HB-D71 ◎※○● 5 0.22 1.10 3200 0.847 29.90 0.129 3.28 33.4 AD0812LB-D71 ◎※○● 12 0.03 0.36 2000 0.567 20.00 0.050 1.27 19.6 AD0812MB-D71 ◎※○● 12 0.05 0.60 2440 0.634 22.40 0.070 1.78 26.0 AD0812HB-D71 ◎※○● 12 0.09 1.08 3200 0.847 29.90 0.129 3.28 33.4 AD0812UB-D71 ◎※○● 12 0.16 1.92 3800 0.950 33.60 0.169 4.29 39.1 Frame Model No. size (mm) 80x80x15 Maximum Pressure *Noise Level Weight (mmAq) (dB/A) (g) 1.78 26.0 AD0812XB-D71 ◎※○● 12 0.24 2.88 4300 1.086 38.40 0.201 5.10 42.3 AD0824MB-D71 ◎※○● 24 0.04 0.96 2440 0.600 22.40 0.070 1.78 26.0 AD0824HB-D71 ◎※○● 24 0.08 1.92 3200 0.847 29.90 0.129 3.28 33.4 63.0 Specif ic atio ns subje ct to change wit hout notic e. Fan Performance Curve FLOWRATE(CMM) 0.283 0.566 0.849 1.415 0.235 4.8 STATIC PRESSURE(mmAq) 1.132 H M L U 0.188 X 3.6 0.141 2.4 0.094 1.2 0.047 0.0 STATIC PRESSURE(InAq) 0.000 6.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 10 20 30 40 50 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0812HB-D71 价格&库存
很抱歉,暂时无法提供与“AD0812HB-D71”相匹配的价格&库存,您可以联系我们找货
