AD1212LB-A71GL
AD1212LB-A71GL
    ADDA(協禧電機)
    AD1212LB-A71GL
AD1212LB-A71GL 数据手册
ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 6 20 X 20 X 10 20 X 20 X 10 20 X 20 X 10 20 X 20 X 10 20 X 20 X 10 20 X 20 X 10 20 X 20 X 10 20 X 20 X 10 20 X 20 X 10 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 6 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD2005DX-K70 AD2005LX-K70 AD2005MX-K70 AD2005MX-K73 AD2005DB-K70(S) AD2005LB-K70(S) AD2005MB-K70(S) AD2012LX-K70 AD2012MX-K70 AD2012LB-K70(S) AD2012MB-K70(S) AD2005MX-G70 AD2005MX-G73 AD2005LB-G70 AD2005LB-G73 AD2005MB-G70 AD2005MB-G73 AD2012LX-G70 AD2012LB-G70 AD2012LM-G70 AD0205LX-K50 AD0205LX-K53 AD0205MX-K50 AD0205MX-K53 AD0205LB-K50(S) AD0205LB-K53(S) AD0205MB-K50(S) AD0205MB-K53(S) AD0205HB-K50(S) AD0212LX-K50 AD0212MX-K50 AD0212LB-K50(S) AD0212MB-K50(S) AD0205LX-G50 AD0205LX-G50(D) AD0205LX-G53GL AD0205MX-G50GL AD0205MX-G53GL AD0205HX-G50 AD0205LB-G50GL AD0205LB-G50(D) AD0205LB-G53GL AD0205MB-G50GL HYPRO HYPRO HYPRO HYPRO 1B,1S 1B,1S 1B,1S HYPRO HYPRO 1B,1S 1B,1S HYPRO HYPRO Bor1B1S BALL Bor1B1S Bor1B1S HYPRO BALL BALL HYPRO HYPRO HYPRO HYPRO 1B,1S 1B,1S 1B,1S 1B,1S 1B,1S HYPRO HYPRO BALL BALL HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL 5 5 5 5 5 5 5 12 12 12 12 5 5 5 5 5 5 12 12 12 5 5 5 5 5 5 5 5 5 12 12 12 12 5 5 5 5 5 5 5 5 5 5 0.06 0.10 0.15 0.12 0.04 0.05 0.13 0.06 0.07 0.06 0.07 0.14 0.11 0.06 0.08 0.07 0.08 0.06 0.07 0.06 0.08 0.06 0.13 0.12 0.05 0.05 0.09 0.07 0.09 0.06 0.09 0.06 0.07 0.10 0.08 0.08 0.12 0.12 0.18 0.10 0.07 0.06 0.12 0.30 0.50 0.75 0.60 0.20 0.25 0.65 0.72 0.84 0.72 0.84 0.70 0.55 0.30 0.40 0.35 0.40 0.72 0.84 0.72 0.40 0.30 0.65 0.60 0.25 0.25 0.45 0.35 0.45 0.72 1.08 0.72 0.84 0.50 0.40 0.40 0.60 0.60 0.90 0.50 0.35 0.30 0.60 7000 10500 14000 14000 7000 10500 14000 10500 14000 10500 14000 11500 10000 9000 8000 11500 10000 9000 9000 11500 9000 9000 12000 12000 9000 9000 12000 12000 12000 9000 12000 9000 12000 8000 4500 8000 10000 10000 12000 8000 6500 8000 10000 0.4 0.6 0.7 0.7 0.4 0.6 0.7 0.6 0.7 0.6 0.7 0.8 0.8 0.6 0.4 0.8 0.8 0.6 0.6 0.8 1.8 1.8 2.4 2.4 1.8 1.8 2.4 2.4 2.4 1.8 2.4 1.8 2.4 1.8 1.0 1.8 2.3 2.3 2.8 1.8 1.4 1.8 2.3 0.022 0.066 0.103 0.130 0.022 0.066 0.103 0.066 0.103 0.066 0.103 0.072 0.072 0.055 0.039 0.072 0.072 0.055 0.055 0.072 0.100 0.100 0.185 0.185 0.100 0.100 0.185 0.185 0.185 0.100 0.185 0.100 0.185 0.116 0.034 0.116 0.173 0.173 0.236 0.116 0.064 0.116 0.173 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 12.0 19.5 26.9 26.0 12.0 19.5 26.9 19.5 26.9 19.5 26.9 26.0 26.0 26.0 11.0 20.0 26.0 20.0 20.0 26.0 20.5 20.5 26.0 26.0 20.5 20.5 26.0 26.0 26.0 20.5 26.0 20.5 26.0 15.6 2.4 15.6 23.1 23.1 28.0 15.6 12.0 15.6 23.1 4 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 5 5 5 5 5 5 5 5 5 5 5 5 5 8 8 8 8 8 8 8 8 8 8 Features Available Safety Approvals 0 0 0 3 0 0 0 0 0 0 0 0 3 0 3 0 3 0 0 0 0 3 0 3 0 3 0 3 0 0 0 0 0 0 0 3 0 3 0 0 0 3 0 CE TUV,CE CE CE CE TUV,CE CE CE CE CE CE UL,CUL,CE CE UL,CUL,CE CE UL,CUL,TUV,CE CE UL,CUL,CE CE CE TUV,CE CE CE CE TUV,CE CE CE UL,CUL,TUV,CE CE CE CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE Units Per Box Box Wt. (lbs.) 600 600 600 600 600 600 600 600 600 600 600 900 900 900 900 900 900 900 900 900 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 12.28 12.28 12.28 12.28 12.28 12.28 12.28 12.28 12.28 12.28 12.28 17.60 17.60 17.60 17.60 17.60 17.60 17.60 17.60 17.60 13.60 13.60 13.60 13.60 13.60 13.60 13.60 13.60 13.60 13.60 13.60 13.60 13.60 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 10 25 X 25 X 15 25 X 25 X 15 25 X 25 X 15 25 X 25 X 15 25 X 25 X 15 25 X 25 X 15 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 6 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0205MB-G53 AD0205HB-G50GL AD0205HB-G53 AD0212LX-G50 AD0212MX-G50GL AD0212HX-G50GL AD0212LB-G50 AD0212MB-G50 AD0212HB-G50 AD0205LX-D50 AD0205LB-D50 AD0205MB-D50 AD0205HB-D50 AD0205HB-D53 AD0205HB-D53(A) AD0305LX-K70 AD0305LX-K73 AD0305MX-K70 AD0305MX-K73 AD0305HX-K70 AD0305HX-K73 AD0305LB-K70(S) AD0305LB-K73(S) AD0305MB-K70(S) AD0305MB-K73(S) AD0305MB-K73(Y) AD0305HB-K73(S) AD0312LX-K70 AD0312MX-K70 AD0312HX-K70 AD0312LB-K70(S) AD0312MB-K70(S) AD0312HB-K70(S) AD0305DX-G50 AD0305LX-G50 AD0305LX-G53 AD0305MX-G53 AD0305HX-G50 AD0305DB-G50 AD0305LB-G50 AD0305LB-G53 AD0305MB-G50 AD0305MB-G53 BALL BALL BALL HYPRO HYPRO HYPRO BALL BALL BALL HYPRO BALL BALL BALL BALL BALL HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO 1B,1S 1B,1S BALL 1B,1S 1B,1S 1B,1S HYPRO HYPRO HYPRO BALL BALL BALL HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL Bor1B1S Bor1B1S 5 5 5 12 12 12 12 12 12 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 5 5 5 5 5 5 5 5 5 5 0.07 0.14 0.12 0.07 0.08 0.09 0.07 0.08 0.09 0.08 0.06 0.09 0.13 0.13 0.13 0.09 0.07 0.12 0.10 0.18 0.11 0.06 0.05 0.08 0.06 0.08 0.07 0.06 0.10 0.08 0.06 0.06 0.09 0.09 0.12 0.09 0.11 0.17 0.06 0.12 0.08 0.13 0.11 0.35 0.70 0.60 0.84 0.96 1.08 0.84 0.96 1.08 0.40 0.30 0.45 0.65 0.65 0.65 0.45 0.35 0.60 0.50 0.90 0.55 0.30 0.25 0.40 0.30 0.40 0.35 0.72 1.20 0.96 0.72 0.72 1.08 0.45 0.60 0.45 0.55 0.85 0.30 0.60 0.40 0.65 0.55 10000 12000 12000 8000 10000 12000 8000 10000 12000 5000 5000 6000 8000 8000 7500 7500 7500 9000 8000 10500 10500 7500 7500 9000 9000 9000 10500 7500 9000 10500 7500 9000 10500 5500 8000 8000 9000 10500 5500 8000 8000 9000 9000 2.3 2.8 2.8 1.8 2.3 2.8 1.8 2.3 2.8 1.2 1.2 1.4 1.9 1.9 1.8 2.5 2.5 3.3 8.3 3.6 3.6 2.5 2.5 3.3 3.3 7.2 3.6 2.5 3.3 3.6 2.5 3.3 3.6 1.8 3.0 3.0 4.1 4.2 1.8 3.0 3.0 4.1 4.1 0.173 0.236 0.236 0.116 0.173 0.236 0.116 0.173 0.236 0.040 0.040 0.054 0.114 0.114 0.091 0.082 0.082 0.138 0.196 0.164 0.164 0.082 0.082 0.138 0.138 0.120 0.164 0.082 0.138 0.164 0.082 0.138 0.164 0.080 0.115 0.115 0.148 0.210 0.080 0.115 0.115 0.148 0.148 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 23.1 28.0 28.0 15.6 23.1 28.0 15.6 23.1 28.0 7.2 7.2 10.0 19.2 19.2 16.7 20.0 20.0 27.9 34.7 32.1 32.1 20.0 20.0 27.9 27.9 34.0 32.1 20.0 27.9 32.1 20.0 27.9 32.1 17.0 20.2 20.2 27.9 30.7 17.0 20.2 20.2 27.9 27.9 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 6 6 6 11 6 6 6 6 6 6 6 6 6 6 6 6 6 6 8 8 8 8 8 8 8 8 8 8 Features Available Safety Approvals 3 0 3 0 0 0 0 0 0 0 0 0 0 3 3 0 3 0 3 0 3 0 3 0 3 3 3 0 0 0 0 0 0 0 0 3 3 0 0 0 3 0 3 TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE CE CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE CE CE CE UL,CUL,TUV,CE CE CE CE CE CE UL,CUL,TUV,CE CE CE CE UL,CUL,TUV,CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE Units Per Box Box Wt. (lbs.) 600 600 600 600 600 600 600 600 600 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 12.30 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 10 30 X 30 X 15 30 X 30 X 15 30 X 30 X 15 30 X 30 X 15 30 X 30 X 15 30 X 30 X 15 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 6 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 35 X 35 X 10 40 X 40 X 6 Model Part Number Bearing Type Volts (V) Current (A) AD0305DX-G50 AD0312LX-G50 AD0312MX-G50 AD0312DB-G50 AD0312LB-G50 AD0312MB-G50 AD0312HB-G50 AD0305LB-D50 AD0305MB-D50 AD0305MB-D50(S) AD0305MB-D53 AD0305HB-D50 AD0305HB-D53 AD3505LX-K70 AD3505LX-K73 AD3505MX-K70 AD3505MX-KBO AD3505LB-K70(S) AD3505MB-K70(S) AD3505MB-K73(S) AD3505HB-K70(S) AD3505HB-K73(S) AD3512LX-K70 AD3512MX-K70 AD3512HX-K70 AD3512LB-K70(S) AD3512MB-K70(S) AD3512HB-K70 AD3505LX-G53 AD3505MX-G50 AD3505MX-G53 AD3505HX-G53 AD3505LB-G50 AD3505MB-G50 AD3505MB-G53 AD3505MB-G53(S) AD3512LX-G50 AD3512MX-G50 AD3512HX-G50 AD3512LB-G50 AD3512MB-G50 AD3512HB-G50 AD0405LX-K90 HYPRO HYPRO HYPRO Bor1B1S BALL Bor1B1S Bor1B1S BALL BALL 1B,1S BALL Bor1B1S BALL HYPRO HYPRO HYPRO HYPRO 1B,1S 1B,1S 1B,1S 1B,1S 1B,1S HYPRO HYPRO HYPRO BALL BALL BALL HYPRO HYPRO HYPRO HYPRO BALL BALL BALL 1B,1S HYPRO HYPRO HYPRO BALL BALL BALL HYPRO 5 12 12 12 12 12 12 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 5 5 5 5 5 5 5 5 12 12 12 12 12 12 5 0.06 0.07 0.12 0.05 0.06 0.12 0.11 0.07 0.08 0.10 0.06 0.13 0.10 0.10 0.08 0.14 0.14 0.06 0.10 0.08 0.13 0.09 0.06 0.08 0.10 0.05 0.06 0.08 0.09 0.17 0.13 0.17 0.12 0.13 0.13 0.13 0.08 0.09 0.11 0.08 0.09 0.11 0.05 NOTE B=Ball S=Sleeve X= Hypro Power (W) Speed (RPM) 0.72 6000 0.84 8000 1.44 9000 0.60 6000 0.72 8000 1.44 9000 1.32 10500 0.35 4500 0.40 5500 0.50 5500 0.30 5500 0.65 7000 0.50 7000 0.50 6500 0.40 6500 0.70 8000 0.70 7000 0.30 6500 0.50 8000 0.40 8000 0.65 9500 0.45 9500 0.72 6500 0.96 8000 1.20 9500 0.60 6500 0.72 8000 0.96 9500 0.45 7000 0.85 8000 0.65 8000 0.85 9500 0.60 7000 0.65 8000 0.65 8000 0.65 8000 0.96 7000 1.08 8000 1.32 9500 0.96 7000 1.08 8000 1.32 9500 0.25 4500 AT= Terminals AW= Wires Air Flow (CFM) Pressure (Inches) 2.5 3.0 4.1 2.5 3.0 4.1 4.2 2.2 2.6 2.6 2.6 3.7 3.7 3.5 3.5 4.7 3.6 3.5 4.7 4.7 4.9 4.9 3.5 4.7 4.9 3.5 4.7 4.9 5.1 6.0 6.0 7.1 5.1 6.0 6.2 6.0 5.1 6.0 7.1 5.1 6.0 7.1 4.2 0.068 0.115 0.148 0.068 0.115 0.148 0.210 0.045 0.074 0.074 0.074 0.110 0.110 0.063 0.063 0.111 0.097 0.063 0.111 0.111 0.150 0.150 0.063 0.111 0.150 0.063 0.111 0.150 0.100 0.131 0.138 0.174 0.100 0.131 0.160 0.138 0.100 0.138 0.174 0.100 0.138 0.174 0.044 Noise Weight (dB/A) (g) 16.0 20.2 27.9 16.0 20.2 27.9 30.7 10.0 16.0 16.0 16.0 22.5 22.5 19.0 19.0 28.0 29.0 19.0 28.0 28.0 35.0 35.0 19.0 28.0 35.0 19.0 28.0 35.0 27.5 30.0 30.0 37.6 27.5 30.0 27.0 30.0 27.5 30.0 37.6 27.5 30.0 37.6 19.5 8 8 8 8 8 8 8 10 10 10 10 10 10 7 7 7 4 7 7 7 7 7 7 7 7 7 7 7 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 Features Available Safety Approvals 0 0 0 0 0 0 0 0 0 0 3 0 3 0 3 0 0 0 0 3 0 3 0 0 0 0 0 0 3 0 3 3 0 0 3 3 0 0 0 0 0 0 0,6 CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE CE CE CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE TUV,CE CE CE CE TUV,CE CE CE CE CE TUV,CE CE CE TUV,CE TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE Units Per Box Box Wt. (lbs.) 400 400 400 400 400 400 400 14.00 14.00 14.00 14.00 14.00 14.00 14.00 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.00 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 6 40 X 40 X 8 40 X 40 X 8 40 X 40 X 8 40 X 40 X 8 40 X 40 X 8 40 X 40 X 8 40 X 40 X 9 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0405LX-KCO AD0405LX-KC3 AD0405MX-K90 AD0405MX-KC0 AD0405MX-KC3(Y) AD0405HX-K90 AD0405HX-KC0 AD0405HX-KC3 AD0405LB-K90(S) AD0405MB-K90(S) AD0405MB-KC3 AD0405HB-K90(S) AD0405MS-K90 AD0412LX-K90 AD0412MX-K90 AD0412HX-K90 AD0412LB-K90(S) AD0412MB-K90(S) AD0412HB-K90(S) AD0405LX-J90 AD0405MX-J90 AD0405MX-J93 AD0405HX-J91 AD0405MB-J90 AD0412MX-J90 AD0405HX-RA3 AD0405DX-G70 AD0405LX-G70 AD0405LX-G76 AD0405MX-G70 AD0405MX-G7 AD0405HX-G70 AD0405DB-G70 AD0405LB-G70 AD0405MB-G70 AD0405MB-G72 AD0405MB-G73 AD0405MB-G76 AD0405HB-G70 AD0405HB-G72 AD0405HB-G76 AD0405LS-G70 AD0405MS-G70 HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO 1B,1S 1B,1S BALL 1B,1S S HYPRO HYPRO HYPRO 1B,1S 1B,1S 1B,1S HYPRO HYPRO HYPRO HYPRO BALL HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL S S 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 5 5 5 5 5 12 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0.11 0.08 0.09 0.20 0.11 0.12 0.23 0.13 0.05 0.09 0.11 0.12 0.09 0.06 0.06 0.08 0.06 0.06 0.08 0.12 0.16 0.15 0.23 0.20 0.13 0.25 0.07 0.08 0.08 0.11 0.11 0.19 0.07 0.08 0.11 0.15 0.15 0.11 0.19 0.25 0.19 0.08 0.11 0.55 0.40 0.45 1.00 0.55 0.60 1.15 0.65 0.25 0.45 0.55 0.60 0.45 0.72 0.72 0.96 0.72 0.72 0.96 0.60 0.80 0.75 1.15 1.00 1.56 1.25 0.35 0.40 0.40 0.55 0.55 0.95 0.35 0.40 0.55 0.75 0.75 0.55 0.95 1.25 0.95 0.40 0.55 4500 4500 5500 5500 5500 6300 6000 6000 4800 5800 5800 6600 5500 4500 5500 6300 4800 5800 6600 4100 5500 5500 6000 5000 5000 6000 3300 4200 4200 4800 4800 6000 3300 4600 4800 4800 4800 5000 6000 6000 6000 4200 4800 3.6 4.6 5.2 4.6 4.6 6.0 5.0 5.0 4.5 5.5 4.9 6.0 5.2 4.4 5.2 5.9 4.7 5.5 6.0 5.1 6.3 6.8 7.5 6.1 6.1 3.1 3.8 4.7 4.7 5.7 5.7 6.7 3.8 5.0 5.7 5.7 5.7 6.0 6.8 6.7 6.8 4.7 5.7 0.061 0.068 0.064 0.093 0.093 0.079 0.110 0.110 0.051 0.067 0.102 0.090 0.064 0.049 0.064 0.079 0.049 0.067 0.090 0.058 0.094 0.098 0.110 0.089 0.089 0.334 0.044 0.060 0.060 0.780 0.078 0.100 0.044 0.060 0.078 0.078 0.078 0.080 0.100 0.100 0.100 0.060 0.078 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 22.4 27.1 23.8 28.6 28.6 27.0 31.2 31.2 19.9 25.0 30.0 30.0 23.8 20.9 23.8 27.0 21.6 25.0 30.0 20.0 28.7 29.0 31.0 26.0 26.0 40.3 14.5 14.0 14.0 19.0 20.0 25.0 14.5 14.0 20.0 20.0 20.0 20.0 25.0 25.0 25.0 14.0 20.0 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 5 5 5 5 5 5 5 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 Features Available Safety Approvals 0 3 0,6 0,3 3 0,6 0 3 0,6 0,6 3 0,6 0 0,6 0,6 0,6 0,6 0,6 0,6 0 0 3 1,3 0 0 3 0 0 6 0 6 0,6 0 0,6 0 2 3 6 0 2 6 0,6 0,2,6 UL,CUL,TUV,CE UL,CUL,TUV,CE UL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE CE CE CE CE CE CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE Units Per Box Box Wt. (lbs.) 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 13.20 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 10 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0405HS-G70 AD0405HS-G7B AD0409HS-G70 AD0409LS-G70 AD0409MS-G70 AD0409US-G70 AD0412DX-G70 AD0412LX-G70 AD0412MX-G70 AD0412HX-G70 AD0412HX-G71 AD0412DB-G70 AD0412LB-G70 AD0412MB-G70 AD0412MB-G72 AD0412MB-G73 AD0412HB-G70 AD0412HB-G70(U) AD0412HB-G72 AD0412UB-G70 AD0412DS-G70 AD0412LS-G70 AD0412MS-G70 AD0412HS-G70 AD0424LX-G70(T) AD0424MX-G70 AD0424MX-G70(T) AD0424HX-G70 AD0424HX-G76(T) AD0424LB-G70 AD0424MB-G70 AD0424MB-G76 AD0424HB-G70 AD0424HB-G76 AD0424LS-G70 AD0424LS-G76 AD0424MS-G70 AD0424HS-G70 AD0424HS-G76 AD0412LX-D50 AD0412LX-D52 AD0412LX-D56 AD0412MX-D50 S S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL S S S S S HYPRO HYPRO HYPRO HYPRO 5 5 9 9 9 9 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 12 12 12 12 0.19 0.15 0.13 0.08 0.10 0.15 0.07 0.07 0.08 0.10 0.10 0.07 0.07 0.08 0.09 0.09 0.10 0.10 0.10 0.10 0.07 0.07 0.08 0.10 0.07 0.05 0.08 0.09 0.09 0.07 0.08 0.08 0.09 0.09 0.07 0.07 0.08 0.09 0.09 0.08 0.10 0.08 0.10 0.95 0.75 1.17 0.72 0.90 1.35 0.84 0.84 0.96 1.20 1.20 0.84 0.84 0.96 1.08 1.08 1.20 1.20 1.20 1.20 0.84 0.84 0.96 1.20 1.68 1.20 1.92 2.16 2.16 1.68 1.92 1.92 2.16 2.16 1.68 1.68 1.92 2.16 2.16 0.96 1.20 0.96 1.20 6000 6000 6000 4200 4800 7000 3300 4200 4800 6000 6000 3300 4600 5000 5000 4800 6000 6800 6000 6800 3300 4200 4800 6000 4200 4200 4800 6000 6000 4600 4800 5000 6000 6000 4200 4200 4800 6000 6000 6000 6000 6000 7000 6.7 6.7 6.8 4.7 5.6 7.7 3.8 4.7 5.7 6.7 6.7 3.8 5.0 5.9 6.0 5.7 6.7 7.9 6.7 7.9 3.8 4.7 5.7 6.7 4.7 4.7 5.7 6.8 6.7 5.0 5.7 5.9 6.7 6.7 4.7 4.7 5.7 6.7 6.7 6.8 6.8 6.8 8.1 0.100 0.100 0.100 0.060 0.080 0.068 0.044 0.060 0.078 0.100 0.100 0.044 0.060 0.080 0.080 0.078 0.100 0.129 0.100 0.129 0.044 0.060 0.078 0.100 0.060 0.068 0.078 0.100 0.100 0.060 0.078 0.080 0.100 0.100 0.060 0.060 0.078 0.100 0.100 0.161 0.161 0.161 0.210 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 25.0 25.0 25.0 14.0 19.0 29.7 14.5 14.0 19.0 25.0 25.0 14.5 14.0 20.0 20.0 20.0 25.0 28.0 25.0 28.0 14.5 14.0 20.0 25.0 14.0 17.2 20.0 25.0 25.0 14.0 20.0 20.0 25.0 25.0 14.0 14.0 20.0 25.0 25.0 30.3 30.3 30.3 31.8 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 27 27 27 27 Features Available Safety Approvals 0,6 0 0 0 0 0 0 0,6 0,6 0,6 1 0 0,6 0,6 2 3 0,6 0 2,3 0,6 0 0,6 0,6 0,6 0,6 0 0,6 0 0 0,6 0 6 0 6 0 6 0,6 0 6 0 2 6 0,6 UL,CUL,TUV,CE CE UL,CE CE CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,CSA,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,CSA,TUV,CE UL,CUL,TUV.CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CSA,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE Units Per Box Box Wt. (lbs.) 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 700 500 44.00 44.00 44.00 44.00 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 15 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0412MX-D52 AD0412HX-D50 AD0412LB-D50 AD0412LB-D50(S) AD0412LB-D52 AD0412MB-D50 AD0412MB-D50(S) AD0412MB-D52 AD0412HB-D50 AD0412HB-D50(S) AD0412HB-D52 AD0412HB-D56 AD0412LS-D50 AD0412MS-D50 AD0412HS-D50 AD0405LX-C50 AD0405MX-C50 AD0405HX-C50 AD0405HX-C52 AD0405DB-C50 AD0405LB-C50 AD0405MB-C50 AD0405HB-C50 AD0405HB-C52 AD0405HB-C56 AD0405DS-C50 AD0405LS-C50 AD0405MS-C50 AD0405HS-C50 AD0405HS-C56 AD0412DX-C50 AD0412LX-C50 AD0412MX-C50 AD0412MX-C53 AD0412HX-C50 AD0412DB-C50 AD0412LB-C50 AD0412LB-C51 AD0412MB-C50 AD0412MB-C52 AD0412HB-C50 AD0412HB-C52 AD0412HB-C53 HYPRO HYPRO BALL 1B & 1S BALL BALL 1B & 1S BALL BALL 1B & 1S BALL BALL S S S HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 0.12 0.12 0.08 0.08 0.10 0.10 0.10 0.12 0.12 0.12 0.15 0.12 0.08 0.10 0.12 0.14 0.16 0.29 0.40 0.12 0.14 0.16 0.29 0.40 0.29 0.12 0.14 0.16 0.29 0.29 0.05 0.07 0.08 0.13 0.11 0.05 0.07 0.11 0.08 0.13 0.10 0.15 0.15 1.44 1.44 0.96 0.96 1.20 1.20 1.20 1.44 1.44 1.44 1.80 1.44 0.96 1.20 1.44 0.70 0.80 1.45 2.00 0.60 0.70 0.80 1.45 2.00 1.45 0.60 0.70 0.80 1.45 1.45 0.60 0.84 0.96 1.56 1.32 0.60 0.84 1.32 0.96 1.56 1.20 1.80 1.80 7000 8000 6000 6500 6000 7000 7500 7000 8000 8500 8000 8000 6000 7000 8000 5700 6300 7500 7500 4200 6000 6500 7800 7800 7800 3700 5700 6300 7500 7500 3700 6000 6700 6700 7500 4200 6200 6200 6900 6900 7800 7800 7800 8.1 9.2 6.8 7.3 6.8 8.1 8.5 8.1 9.2 10.2 9.2 9.2 6.8 8.1 9.2 7.2 7.8 9.2 9.2 4.9 7.2 8.1 9.9 9.9 9.9 4.7 7.2 7.8 9.2 9.2 4.7 7.5 8.3 8.3 9.6 4.9 7.7 7.7 8.5 8.5 10.1 10.1 10.1 0.210 0.287 0.161 0.183 0.161 0.210 0.231 0.210 0.287 0.298 0.287 0.287 0.161 0.210 0.287 0.142 0.171 0.250 0.250 0.080 0.142 0.171 0.256 0.256 0.256 0.064 0.142 0.171 0.250 0.250 0.064 0.154 0.180 0.180 0.240 0.080 0.165 0.165 0.190 0.190 0.263 0.263 0.263 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 31.8 39.3 30.3 30.6 30.3 31.8 33.5 31.8 39.3 39.8 39.3 39.3 30.3 31.8 39.3 22.4 26.3 31.0 31.0 16.5 22.4 27.0 31.9 31.9 31.9 10.0 22.4 26.3 31.0 31.0 10.0 23.9 27.5 27.5 31.0 16.5 25.0 25.0 28.5 28.5 31.9 31.9 31.9 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 27 27 28 28 27 27 28 28 28 28 28 28 28 Features Available Safety Approvals 2 0,6 0,6 0,6 2 0,6 0,6 2 0,6 0,6 2 0,6 0,6 0,6 0,6 0,6 0,6 0,6 2 0,6 0,6 0,6 0 2 6 0 0,6 0,6 0 6 0,6 0,6 0,6 3 0,6 0 0,6 1,2 0,6 2,3 0,6 2 3 UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE Units Per Box Box Wt. (lbs.) 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 40 X 40 X 20 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 6 45 X 45 X 7 45 X 45 X 7 45 X 45 X 7 45 X 45 X 7 45 X 45 X 9 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0412UB-C50 AD0412DS-C56 AD0412LS-C50 AD0412LS-C56 AD0412MS-C50 AD0412HS-C50 AD0412HS-C52 AD0412US-C50 AD0424LX-C50 AD0424MX-C50 AD0424HX-C50 AD0424LB-C50 AD0424MB-C50 AD0424HB-C50 AD0424LS-C50 AD0424MS-C50 AD0424HS-C50 AD4505LX-K90 AD4505MX-K90 AD4505HX-K90 AD4505LB-K90(S) AD4505MB-K90(S) AD4505HB-K90(S) AD4512LX-K90 AD4512MX-K90 AD4512HX-K90 AD4512LB-K90(S) AD4512MB-K90(S) AD4512HB-K90(S) AD4505MX-QA0 AD4505HX-QA0 AD4505HX-QA3 AD4505HB-QA3 AD4505HX-RB3 AD4505LX-G70(T) AD4505MX-G70 AD4505MX-G70(T) AD4505MX-GD0 AD4505MX-GD1 AD4505HX-G70 AD4505HX-G76 AD4505HX-GD0 AD4505HX-GD1 BALL S S S S S S S B or S B or S B or S BALL BALL BALL S S S HYPRO HYPRO HYPRO 1B & 1S 1B & 1S 1B & 1S HYPRO HYPRO HYPRO 1B & 1S 1B & 1S 1B & 1S HYPRO HYPRO HYPRO BALL HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 5 5 5 5 5 5 12 12 12 12 12 12 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0.14 0.05 0.07 0.07 0.08 0.11 0.15 0.14 0.06 0.07 0.09 0.06 0.07 0.09 0.06 0.07 0.09 0.10 0.12 0.14 0.10 0.12 0.14 0.08 0.09 0.10 0.08 0.09 0.10 0.09 0.14 0.12 0.12 0.22 0.16 0.10 0.18 0.25 0.15 0.20 0.20 0.22 0.17 1.68 0.60 0.84 0.84 0.96 1.32 1.80 1.68 1.44 1.68 2.16 1.44 1.68 2.16 1.44 1.68 2.16 0.50 0.60 0.70 0.50 0.60 0.70 0.96 1.08 1.20 0.96 1.08 1.20 0.45 0.70 0.60 0.60 1.10 0.80 0.50 0.90 1.25 0.75 1.00 1.00 1.10 0.85 8500 3700 6000 6000 6700 7500 7500 8200 6000 6700 7500 6200 6900 7800 6000 6700 7500 4300 5000 6000 4500 5500 6200 4300 5000 6000 4500 5500 6200 5000 5700 6200 6200 4500 3800 4200 4500 4200 5000 5500 5500 5200 4800 10.6 4.7 7.5 7.5 8.3 9.6 9.6 10.3 7.5 8.3 9.6 7.7 8.5 10.1 7.5 8.3 9.6 6.2 7.1 9.2 6.5 7.2 9.5 6.2 7.1 9.2 6.5 7.2 9.5 1.6 1.8 2.1 2.1 3.1 6.8 6.9 7.5 2.0 2.3 9.1 9.1 2.7 7.0 0.325 0.064 0.154 0.154 0.180 0.240 0.240 0.305 0.154 0.180 0.240 0.165 0.190 0.263 0.154 0.180 0.240 0.056 0.074 0.103 0.059 0.085 0.111 0.056 0.074 0.103 0.059 0.085 0.111 0.224 0.332 0.397 0.397 0.213 0.062 0.069 0.078 0.290 0.342 0.107 0.109 0.434 0.050 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 36.1 10.0 23.9 23.9 27.5 31.0 31.0 35.0 23.9 27.5 31.0 25.0 28.5 31.9 23.9 27.5 31.0 23.0 25.5 32.6 23.3 26.5 33.0 23.0 25.5 32.6 23.3 26.5 33.0 25.5 28.5 31.2 31.2 31.8 17.5 21.6 22.0 22.0 31.1 27.4 28.6 27.4 28.9 28 27 27 27 28 27 28 28 28 28 27 28 28 28 28 28 27 24 24 24 24 24 24 24 24 24 24 24 24 23 23 23 23 26 24 24 24 26 26 24 24 26 26 Features Available Safety Approvals 0,6 6 0 6 0,6 0,6 2 0 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0 0,6 0 0,6 3 3 3 0,6 0,6 0,6 0,6 1 0 6 0,3 1 UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE CE CE CE Units Per Box Box Wt. (lbs.) 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 560 560 560 560 560 560 560 560 560 560 560 560 480 480 480 480 500 500 500 500 500 500 500 500 500 500 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 36.96 19.30 19.30 19.30 19.30 19.30 19.30 19.30 19.30 19.30 19.30 19.30 19.30 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 45 X 45 X 10 50 X 50 X 15 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD4505LB--G70 AD4505MB-G70 AD4505MB-G76 AD4505MB-GD0 AD4505HB-G70 AD4505HB-G70(S) AD4505HB-G70(T) AD4505HB-GD0 AD4505LS-G70(T) AD4505MS-G70 AD4505MS-G76 AD4505HS-G70 AD4505HS-GD0(Y) AD4512LX-G70(T) AD4512MX-G70 AD4512MX-G70(T) AD4512HX-G70 AD4512HX-G70(T) AD4512LB-G70 AD4512MB-G70 AD4512MB-G70(T) AD4512MB-G72(S) AD4512HB-G70 AD4512HB-G70(T) AD4512LS-G70(T) AD4512MS-G70 AD4512MS-G76 AD4512MS-G70(T) AD4512HS-G70 AD4512HS-G70(T) AD4524LX-G70(T) AD4524MX-G70(T) AD4524HX-G70(T) AD4524LB-G70(T) AD4524LB-G70(S) AD4524MB-G70(T) AD4524MB-G70(S) AD4524HB-G70(T) AD4524LS-G70(T) AD4524MS-G70(T) AD4524HS-G70(T) AD4524HB-G70(S) AD5005MS-D70 BALL BALL BALL BALL BALL 1B & 1S BALL BALL S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO BALL Bor1B1S BALL 1B & 1S Bor1B1S BALL S S S S S S HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL S 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 5 0.16 0.16 0.18 0.25 0.20 0.20 0.20 0.22 0.16 0.16 0.18 0.20 0.22 0.06 0.07 0.07 0.09 0.09 0.06 0.07 0.07 0.08 0.09 0.09 0.06 0.07 0.07 0.07 0.09 0.09 0.06 0.07 0.08 0.06 0.06 0.09 0.07 0.08 0.06 0.07 0.08 0.08 0.24 0.80 0.80 0.90 1.25 1.00 1.00 1.00 1.10 0.80 0.80 0.90 1.00 1.10 0.72 0.84 0.84 1.08 1.08 0.72 0.84 0.84 0.96 1.08 1.08 0.72 0.84 0.84 0.84 1.08 1.08 1.44 1.68 1.92 1.44 1.44 2.16 1.68 1.92 1.44 1.68 1.92 1.92 1.20 4200 4200 4500 4200 5000 5500 5500 5200 3800 4200 4500 5500 5200 3800 4200 4500 6500 5500 4200 4200 4500 4800 5000 5500 3800 4200 4200 4500 5000 5500 3800 4800 5500 3800 4200 4500 4800 5500 3800 4800 5500 5700 4300 7.0 6.9 7.5 2.0 8.2 9.8 9.1 2.7 6.8 6.9 7.5 9.1 2.7 6.8 6.9 7.5 10.4 9.1 7.0 6.9 7.5 7.9 8.3 9.1 6.8 6.9 6.9 7.5 8.3 9.1 6.8 7.5 9.1 6.8 7.0 7.5 7.9 9.1 6.8 7.5 9.1 9.8 12.6 0.066 0.069 0.078 0.290 0.101 0.116 0.107 0.434 0.062 0.069 0.078 0.107 0.434 0.062 0.069 0.078 0.145 0.107 0.066 0.069 0.078 0.081 0.097 0.107 0.062 0.069 0.069 0.078 0.097 0.109 0.062 0.078 0.109 0.062 0.066 0.078 0.081 0.109 0.062 0.078 0.109 0.107 0.113 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 20.4 21.6 22.0 22.0 26.2 27.5 27.4 35.3 17.5 21.6 22.0 27.4 35.3 17.5 21.6 22.0 31.6 27.4 20.4 21.6 22.0 23.7 26.1 27.4 17.5 21.6 21.6 22.0 26.1 28.6 17.5 22.0 28.6 17.5 20.4 22.0 23.7 28.6 17.5 22.0 28.6 27.4 29.0 24 24 24 26 24 24 24 26 24 24 24 24 26 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 55 Features Available Safety Approvals 0,6 0 6 0,6 0 0 0,6 0,6 0,6 0 6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 2 0,6 0,6 0,6 0 6 0,6 0 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0,6 0 UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE Units Per Box Box Wt. (lbs.) 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 24.64 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 50 X 50 X 15 52 X 52 X 9 52 X 52 X 9 52 X 52 X 9 52 X 52 X 9 52 X 52 X 9 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 Model Part Number Bearing Type AD5012LX-D70 HYPRO AD5012MX-D70 HYPRO AD5012HX-D70 HYPRO AD5012UX-D76 HYPRO AD5012LB-D70 BALL AD5012MB-D70 BALL AD5012MB-D76(S) 1B & 1S AD5012HB-D70 BALL AD5012HB-D70(S) 1B & 1S AD5012UB-D70 BALL AD5012UB-D70(S) 1B & 1S AD5012LS-D70 S AD5012MS-D70 S AD5012HS-D76 S AD5012US-D76 S AD0505MX-RB1 HYPRO AD0505HX-RB0 HYPRO AD0505HX-RB1 HYPRO AD0505MB-RB1 BALL AD0512MX-RB0 HYPRO AD0505LX-G70(T) HYPRO AD0505MX-G70 HYPRO AD0505MX-G90 HYPRO AD0505HX-G70(T) HYPRO AD0505HX-G90 HYPRO AD0505LB-G70(T) BALL AD0505LB-G70(TS) 1B & 1S AD0505MB-G70 BALL AD0505MB-G70(T) BALL AD0505MB-G70(TS) 1B & 1S AD0505HB-G70(T) BALL AD0505HB-G90 BALL AD0505HB-G96 BALL AD0505LS-G70 S AD0505LS-G76 S AD0505MS-G70(T) S AD0505MS-G90 S AD0505HS-G70 S AD0505HS-G70(T) S AD0512LX-G70(T) HYPRO AD0512MX-G70(T) HYPRO AD0512MX-G72 HYPRO AD0512MX-G90 HYPRO NOTE B=Ball S=Sleeve X= Hypro Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 5 5 5 5 12 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 0.08 0.10 0.14 0.20 0.08 0.10 0.10 0.14 0.14 0.20 0.20 0.08 0.10 0.14 0.20 0.17 0.22 0.22 0.17 0.10 0.12 0.18 0.12 0.23 0.15 0.12 0.12 0.14 0.18 0.18 0.23 0.15 0.15 0.12 0.12 0.18 0.12 0.18 0.23 0.10 0.07 0.10 0.07 0.96 1.20 1.68 2.40 0.96 1.20 1.20 1.68 1.68 2.40 2.40 0.96 1.20 1.68 2.40 0.85 1.10 1.10 0.85 1.20 0.60 0.90 0.60 1.15 0.75 0.60 0.60 0.70 0.90 0.90 1.15 0.75 0.75 0.60 0.60 0.90 0.60 0.90 1.15 0.72 0.84 1.20 0.84 3600 4300 4800 5500 3600 4300 4500 4800 500 5500 5700 3600 4300 4800 5500 4800 5000 5000 4800 4800 3700 4300 3300 5000 3800 3700 3900 4600 4300 4500 5000 3800 3800 3700 3700 4300 3300 5200 500 3700 4300 4300 3300 10.8 12.6 14.4 16.5 10.8 12.6 28.5 14.4 15.0 16.5 17.1 10.8 12.6 14.4 16.5 3.0 3.2 9.5 3.0 3.0 9.0 10.5 8.5 11.2 9.8 9.0 9.4 10.5 10.5 10.8 11.2 9.8 9.8 9.0 9.0 10.5 8.5 11.9 11.2 9.0 10.5 10.5 8.5 0.084 0.113 0.141 0.181 0.084 0.113 0.126 0.141 0.152 0.181 0.194 0.084 0.113 0.141 0.181 0.320 0.320 0.100 0.320 0.320 0.060 0.100 0.068 0.130 0.082 0.060 0.060 0.100 0.100 0.100 0.130 0.082 0.082 0.060 0.060 0.100 0.068 0.130 0.130 0.060 0.100 0.100 0.068 AT= Terminals AW= Wires Noise Weight (dB/A) (g) 23.6 29.0 30.7 33.8 23.6 29.0 13.4 30.7 31.4 33.8 34.5 23.6 29.0 30.7 33.8 34.0 34.0 31.7 34.0 34.0 20.0 24.0 24.9 26.0 28.6 20.0 20.0 24.0 24.0 25.0 26.0 28.6 28.6 20.0 20.0 24.0 24.9 28.0 26.0 20.0 24.0 24.0 24.9 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 28 28 28 28 28 18 18 24 18 50 18 18 18 18 18 18 24 24 18 18 18 24 18 18 18 18 18 50 Features Available Safety Approvals 0 0 0,6 6 0,6 0,6 6 0,6 0,6 0,6 0,6 0 0,6 6 6 0,3 0,3 1 1 0 0,6 0,6 0 0,6 0 0,6 0,6 0 0,6 0,6 0,6 0 6 0 0 0,6 0 0 0,6 0,6 0,6 2 0 CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE CE TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,CE Units Per Box Box Wt. (lbs.) ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 10 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 Model Part Number Bearing Type AD0512HX-G70 HYPRO AD0512HX-G76(UT) HYPRO AD0512HX-G90 HYPRO AD0512LB-G70 BALL AD0512LB-G72 BALL AD0512LB-G73 BALL AD0512MB-G70(S) Bor1B1S AD0512MB-G73 BALL AD0512MB-G90(S) Bor1B1S AD0512MB-G96(S) 1B & 1S AD0512HB-G70(S) Bor1B1S AD0512HB-G72 BALL AD0512HB-G73(S) 1B & 1S AD0512HB-G76 BALL AD0512HB-G90(S) Bor1B1S AD0512LS-G70 S AD0512MS-G70 S AD0512MS-G90 S AD0512HS-G70 S AD0512HS-G70(T) S AD0512HS-G70(U) S AD0512HS-G90 S AD0512HS-G96 S AD0524LX-G70 HYPRO AD0524MX-G70 HYPRO AD0524HX-G70 HYPRO AD0524LB-G70 BALL AD0524LB-G70(S) 1B & 1S AD0524MB-G70(S) Bor1B1S AD0524MB-G90 BALL AD0524HB-G70 BALL AD0524HB-G70(S) 1B & 1S AD0524HB-G90 BALL AD0524LS-G70 S AD0524MS-G70 S AD0524HS-G70 S AD0505HX-D71 HYPRO AD0505MB-D71 BALL AD0505HB-D70 BALL AD0505HB-D71 BALL AD0505MS-D71 S AD0505HS-D70 S AD0505HS-D71 S NOTE B=Ball S=Sleeve X= Hypro Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 5 5 5 5 5 5 5 0.09 0.09 0.08 0.06 0.09 0.06 0.07 0.10 0.07 0.07 0.09 0.11 0.09 0.09 0.08 0.06 0.07 0.08 0.09 0.09 0.09 0.08 0.08 0.07 0.08 0.09 0.07 0.07 0.10 0.06 0.11 0.09 0.09 0.07 0.08 0.09 0.26 0.16 0.20 0.26 0.16 0.20 0.26 1.08 1.08 0.96 0.72 1.08 0.72 0.84 1.20 0.84 0.84 1.08 1.32 1.08 1.08 0.96 0.72 0.84 0.96 1.08 1.08 1.08 0.96 0.96 1.68 1.92 2.16 1.68 1.68 2.40 1.44 2.64 2.16 2.16 1.68 1.92 2.16 1.30 0.80 1.00 1.30 0.80 1.00 1.30 5000 5600 3800 3900 3700 3900 4600 4300 3300 3300 5200 5000 5200 5000 3800 3700 4600 3300 5200 5000 5600 3800 3800 3700 4300 5000 3700 3900 4300 3300 5000 5200 3800 3700 4300 5000 4600 3700 4600 4600 3700 4600 4600 11.2 12.4 9.8 9.4 9.0 9.4 10.5 10.5 8.5 8.5 11.9 11.2 11.9 11.2 9.8 9.0 10.5 8.5 11.9 11.2 12.4 9.8 9.8 9.0 10.5 11.2 9.0 9.4 10.5 8.3 11.2 11.8 9.8 9.0 10.5 11.2 12.0 9.7 12.0 12.0 9.7 12.0 12.0 0.130 0.112 0.082 0.060 0.060 0.067 0.100 0.100 0.068 0.068 0.130 0.130 0.130 0.130 0.082 0.060 0.100 0.068 0.130 0.130 0.112 0.082 0.082 0.060 0.100 0.130 0.060 0.060 0.100 1.650 0.130 0.130 0.082 0.060 0.100 0.130 0.166 0.106 0.166 0.166 0.106 0.166 0.166 AT= Terminals AW= Wires Noise Weight (dB/A) (g) 26.0 26.4 28.6 20.0 20.0 20.0 24.0 24.0 24.9 24.9 28.0 26.0 28.0 26.0 28.6 20.0 24.0 24.9 28.0 26.0 26.4 28.6 28.6 20.0 24.0 26.0 20.0 20.0 24.0 27.5 26.0 27.0 28.6 20.0 24.0 26.0 28.7 22.6 28.7 28.7 22.6 28.7 28.7 18 18 24 18 18 18 18 18 24 24 18 18 18 18 24 18 18 24 18 18 18 24 24 18 18 18 18 18 18 50 18 18 50 18 18 18 36 55 36 36 36 55 36 Features Available Safety Approvals 0,6 6 0 0,6 2 3 0,6 3 0 6 0 2 3 6 0 0,6 0,6 0,6 0 0,6 0,6 0 6 0,6 0,6 0,6 0,6 0,6 0,6 0 0,6 0,6 0 0,6 0 0,6 1 1 0 1 1 0 1 UL,CUL,TUV,CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE UL,CUL,CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CUL,UL,TUV,CE CUL,UL,TUV,CE CUL,UL,TUV,CE CUL,UL,TUV,CE CUL,UL,TUV,CE CUL,UL,TUV,CE Units Per Box Box Wt. (lbs.) 480 480 480 480 480 480 480 46.20 46.20 46.20 46.20 46.20 46.20 46.20 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 53 X 52 X 15 54 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 52 X 52 X 15 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0512MX-D70 AD0512MX-D71 AD0512MX-D72 AD0512HX-D71 AD0512HX-D76 AD0512LB-D70 AD0512MB-D70 AD0512MB-D71(S) AD0512MB-D72 AD0512HB-D70 AD0512HB-D71 AD0512HB-D73 AD0512UB-D71 AD0512UB-D72 AD0512MS-D70 AD0512MS-D71 AD0512HS-D70 AD0512HS-D71 AD0512HS-D76 AD0524HX-D71 AD0524HB-D71 AD0524HS-D71 AD0605LX-G90 AD0605LX-G70 AD0605MX-G70 AD0605LB-G70 AD0605MB-G70 AD0605HB-G90 AD0605LS-G70 AD0605LS-G90 AD0605MS-G70 AD0605HS-G90 AD0612LX-G70 AD0612LX-G76 AD0612MX-G70 AD0612MX-G90 AD0612MX-G96 AD0612HX-G70 AD0612HX-G90 AD0612LB-G70(S) AD0612LB-G90 AD0612LB-G96 AD0612MB-G70(S) HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL Bor1B1S BALL BALL Bor1B1S Bor1B1S BALL BALL S S S S S HYPRO BALL S HYPRO HYPRO HYPRO BALL BALL BALL S S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO Bor1B1S BALL BALL Bor1B1S 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 0.09 0.09 0.09 0.10 0.10 0.06 0.09 0.09 0.09 0.10 0.10 0.10 0.11 0.11 0.09 0.09 0.10 0.10 0.10 0.08 0.08 0.08 0.15 0.13 0.15 0.13 0.15 0.27 0.13 0.14 0.15 0.27 0.11 0.11 0.13 0.12 0.12 0.15 0.14 0.11 0.11 0.11 0.13 1.08 1.08 1.08 1.20 1.20 0.72 1.08 1.08 1.08 1.20 1.20 1.20 1.32 1.32 1.08 1.08 1.20 1.20 1.20 1.92 1.92 1.92 0.75 0.65 0.75 0.65 0.75 1.35 0.65 0.70 0.75 1.35 1.32 1.32 1.56 1.44 1.44 1.80 1.68 1.32 1.32 1.32 1.56 3700 3700 3700 4600 4600 2800 3700 3700 3700 4600 4600 4600 5300 5300 3700 3700 4600 4600 4600 4600 4600 4600 3000 3500 4200 3500 4200 4200 3500 3000 4200 4200 3500 3500 4200 3600 3600 4900 4200 3500 3000 3000 4200 9.7 9.7 9.7 12.0 12.0 6.3 9.7 9.7 9.7 12.0 12.0 12.0 13.0 12.5 9.7 9.7 12.0 12.0 12.0 12.0 12.0 12.0 11.9 10.0 12.0 10.0 12.0 16.6 10.0 11.9 12.0 16.6 11.7 11.7 12.0 14.1 14.1 14.5 16.6 11.7 11.9 11.9 12.0 0.106 0.106 0.106 0.166 0.166 0.059 0.106 0.106 0.106 0.166 0.166 0.166 0.200 0.200 0.106 0.106 0.166 0.166 0.166 0.166 0.166 0.166 0.060 0.060 0.090 0.060 0.090 0.115 0.060 0.060 0.090 0.115 0.050 0.050 0.090 0.086 0.086 0.108 0.115 0.050 0.060 0.060 0.090 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 22.6 22.6 22.6 28.7 28.7 14.4 22.6 22.6 22.6 28.7 28.7 28.7 35.0 33.3 22.6 22.6 28.7 28.7 28.7 28.7 28.7 28.7 23.1 23.0 28.0 23.0 28.0 32.8 23.0 23.1 28.0 32.8 23.0 23.0 28.0 28.5 28.5 32.0 32.8 23.0 23.1 23.1 28.0 55 36 36 36 36 55 55 36 36 55 36 36 36 36 55 36 55 36 36 36 55 36 30 30 23 30 23 30 23 30 23 30 30 30 23 30 30 23 30 30 30 30 23 Features Available Safety Approvals 0 1 2 1 6 0 0,6 1 2,3 0 1 3,6 1 2 0 1 0 1 6 1 1 1 0 0 0 0 0 0 0 0 0 0 0 6 0,6 0,6 6 0,6 0 0,6 0 6 0,6 UL,CUL,CE UL,CUL,TUV,CE CE+ UL,CUL,TUV,CE CE CE UL,CUL,CE UL,CUL,TUV,CE CE UL,CUL,CE UL,CUL,TUV,CE CE CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE CE CE CE CE UL,CUL,CE CE TUV,CE CE TUV,CE UL,CUL,CE TUV,CE UL,CUL,CE TUV,CE UL,CUL,TUV,CE TUV,CE CE TUV,CE UL,CUL,CE CE TUV,CE UL,CUL,TUV,CE TUV,CE UL,CUL,CE TUV,CE TUV,CE Units Per Box Box Wt. (lbs.) 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 480 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 46.20 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 10 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0612MB-G90(S) AD0612MB-GA6 AD0612HB-G70(S) AD0612HB-G90(S) AD0612HB-G96(S) AD0612HB-GA6(S) AD0612LS-G70 AD0612LS-G90 AD0612LS-G96 AD0612MS-G70 AD0612HS-G90 AD0612HS-G96 AD0612HS-G90 AD0612HS-G96 AD0605LB-D70GL AD0605MB-D71GL AD0605HB-D70GL AD0605HB-D71GL AD0605HB-D73GL AD0605MS-D71GL AD0605HS-D70GL AD0605HS-D71GL AD0612DX-D70GL AD0612LX-D70GL AD0612LX-D76GL AD0612MX-D70GL AD0612MX-D76GL AD0612HX-D70GL AD0612HX-D72GL AD0612DB-D70GL AD0612DB-D70(T) AD0612LB-D70GL AD0612LB-D76GL AD0612MB-D70GL AD0612MB-D76GL AD0612HB-D70GL AD0612UB-D71GL AD0612UB-D73GL AD0612UB-D96 AD0612LS-D70GL AD0612MS-D70GL AD0612MS-D72GL AD0612HS-D70GL Bor1B1S BALL Bor1B1S Bor1B1S 1B & 1S 1B & 1S S S S S S S S S BALL BALL BALL BALL BALL S S S HYPRO HYPRO HYPRO HYPRO B,S,or X HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S 12 12 12 12 12 12 12 12 12 12 12 12 12 12 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 0.12 0.19 0.15 0.14 0.14 0.25 0.11 0.11 0.11 0.13 0.15 0.15 0.14 0.14 0.20 0.25 0.25 0.37 0.37 0.25 0.25 0.37 0.07 0.09 0.09 0.11 0.11 0.13 0.13 0.07 0.07 0.09 0.09 0.11 0.11 0.13 0.16 0.16 0.31 0.09 0.11 0.11 0.13 1.44 2.28 1.80 1.68 1.68 3.00 1.32 1.32 1.32 1.56 1.80 1.80 1.68 1.68 1.00 1.25 1.25 1.85 1.85 1.25 1.25 1.85 0.84 1.08 1.08 1.32 1.32 1.56 1.56 0.84 0.84 1.08 1.08 1.32 1.32 1.56 1.92 1.92 3.72 1.08 1.32 1.32 1.56 3600 4000 4900 4200 4200 4600 3500 300 300 4200 4900 4900 4200 4200 3500 3900 4500 4500 4500 3900 4500 4500 3100 3500 3500 3900 3900 4500 4500 3100 3100 3500 3500 3900 3900 4500 5100 5100 6000 3500 3900 3900 4500 14.1 17.3 14.5 16.6 16.6 21.0 11.7 11.9 11.9 12.0 14.5 14.5 16.6 16.6 12.0 14.2 15.7 16.6 16.6 14.2 15.7 16.6 12.2 12.0 12.0 14.2 14.2 16.6 16.6 12.2 10.7 12.0 12.0 14.2 14.2 16.6 18.0 18.0 28.5 12.0 14.2 14.2 16.6 0.086 0.127 0.108 0.115 0.115 0.165 0.050 0.060 0.060 0.090 0.108 0.108 0.115 0.115 0.010 0.118 0.163 0.152 0.152 0.118 0.163 0.152 0.086 0.010 0.010 0.118 0.118 0.152 0.152 0.086 0.086 0.010 0.010 0.118 0.118 0.152 0.176 0.176 0.231 0.010 0.118 0.118 0.152 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 28.5 31.7 32.0 32.8 32.8 35.8 23.0 23.1 23.1 28.0 32.0 32.0 32.8 32.8 27.2 28.8 33.2 32.4 32.4 28.8 33.2 32.4 24.9 27.2 27.2 28.8 28.8 32.4 32.4 24.9 23.8 27.2 27.2 28.8 28.8 32.4 39.3 39.3 40.4 27.2 28.8 28.8 32.4 0,6 6 0,6 0 6 6 0 0 6 0,6 0 6 0 6 0,1 1,2,3 0 1,2 3 1 0 1 0,6 0 6 0,1,2,3 6 0,1,6 2,3 0,2 0,6 0,1 6 0,1,3 6 0,1,2,3,6 1,2,6 3 6 0,1 0,1,6 2 0,1,6 UL,CUL,TUV,CE UL,CUL,TUV,CE TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE TUV,CE UL,CUL,CE UL,CUL,TUV,CE TUV,CE TUV,CE UL,CUL,TUV,CE UL,CUL,CE CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE 30 30 23 30 30 30 23 30 30 23 23 23 30 30 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 Units Per Box Box Wt. (lbs.) 480 480 480 480 480 480 480 480 480 480 480 480 480 480 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 35.50 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 15 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0612HS-D73GL AD0624LX-D70GL AD0624MX-D71GL AD0624HX-D71GL AD0624MB-D70GL AD0624MB-D71GL AD0624MB-D72GL AD0624HB-D70GL AD0624HB-D71GL AD0624HB-D73GL AD0624LS-D70GL AD0624MS-D70GL AD0624MS-D71GL AD0624HS-D70GL AD0624HS-D71GL AD0605HX-C70GL AD0605MB-C70GL AD0605HB-C70GL AD0605HB-C72GL AD0605HS-C70GL AD0612DX-C76GL AD0612LX-C70GL AD0612MX-C70GL AD0612MX-C72GL AD0612HX-C70GL AD0612HX-C72GL AD0612HX-C73GL AD0612DB-C76GL AD0612LB-C70GL AD0612LB-C73GL AD0612LB-C76GL AD0612MB-C70GL AD0612MB-C72GL AD0612HB-C70GL AD0612HB-C72GL AD0612UB-C71GL AD0612LS-C70GL AD0612LS-C71GL AD0612LS-C76GL AD0612MS-C70GL AD0612MS-C72GL AD0612HS-C70GL AD0612HS-C72GL S HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL S S S S S HYPRO BALL BALL BALL HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S BALL BALL 12 24 24 24 24 24 24 24 24 24 24 24 24 24 24 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 0.13 0.05 0.07 0.09 0.07 0.07 0.07 0.09 0.09 0.09 0.05 0.07 0.07 0.09 0.09 0.25 0.24 0.30 0.30 0.30 0.07 0.08 0.13 0.13 0.16 0.16 0.16 0.07 0.08 0.08 0.08 0.13 0.13 0.16 0.16 0.17 0.08 0.08 0.08 0.13 0.13 0.16 0.16 1.56 1.20 1.68 2.16 1.68 1.68 1.68 2.16 2.16 2.16 1.20 1.68 1.68 2.16 2.16 1.25 1.20 1.50 1.50 1.50 0.84 0.96 1.56 1.56 1.92 1.92 1.92 0.84 0.96 0.96 0.96 1.56 1.56 1.92 1.92 2.04 0.96 0.96 0.96 1.56 1.56 1.92 1.92 4500 3500 3900 4500 3900 3900 3900 4500 4500 4500 3500 3900 3900 4500 4500 4500 3900 4500 4500 4500 3000 3500 3900 3900 4500 4500 4500 3000 3500 3500 3500 3900 3900 4600 4600 5100 3500 3500 3500 3900 3900 4500 4500 16.6 12.0 15.0 17.0 15.0 15.0 15.0 17.0 17.0 17.0 13.0 15.0 15.0 17.0 17.0 16.3 14.5 16.4 16.4 16.4 10.7 13.3 14.5 14.5 16.4 16.4 16.4 10.7 13.3 13.3 13.3 14.5 14.5 16.4 16.4 18.7 13.3 13.3 13.3 14.5 14.5 16.4 16.4 0.152 0.010 0.138 0.173 0.138 0.138 0.138 0.173 0.173 0.173 0.110 0.138 0.138 0.173 0.173 0.156 0.111 0.139 0.139 0.139 0.054 0.096 0.111 0.111 0.139 0.139 0.139 0.054 0.096 0.096 0.096 0.111 0.111 0.139 0.139 0.160 0.096 0.096 0.096 0.111 0.111 0.139 0.139 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 32.4 27.2 30.7 33.3 30.7 30.7 30.7 33.3 33.3 33.3 27.2 30.7 30.7 33.3 33.3 29.8 25.7 29.7 29.7 29.7 18.4 21.6 25.7 25.7 29.7 29.7 29.7 18.4 21.6 21.6 21.6 25.7 25.7 29.7 29.7 34.6 21.6 21.6 21.6 25.7 25.7 29.7 29.7 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 Features Available Safety Approvals 3 0 1 1 0 1 2 0,6 1,2 3 0 0 1 0 1 0 0 0 2 0 6 0,6 0 2,3,6 0 2 3,6 6 0,1 3 6 0,3 2,6 0,1,6 2,3 1 0 1 6 0,1,6 2,3 0,1,6 2,3 CE CE CE TUV,CE UL,CUL,CE CE TUV,CE UL,CUL,CE TUV,CE CE CE UL,CUL,CE TUV,CE UL,CUL,CE TUV,CE CE CE TUV,CE CE CE CE UL,CSA,CE UL,TUV,CSA,CE UL,CUL,CE UL,TUV,CSA,CE CE UL,CUL,CE CE UL,TUV,CSA,CE CE UL,CUL,CE UL,TUV,CSA,CE UL,CUL,CE UL,TUV,CSA,CE UL,CUL,CE CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CUL,CE UL,TUV,CSA,CE UL,CUL,CE UL,TUV,CSA,CE UL,CUL,CE Units Per Box Box Wt. (lbs.) 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 25.70 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 20 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0624MX-C70GL AD0624HX-C70GL AD0624MB-C70GL AD0624HB-C70GL AD0624HB-C70(T) AD0624MS-C70GL AD0624HS-C70GL AD0605MX-A70GL AD0605MB-A70GL AD0605HB-A70GL AD0605HB-A73GL AD0605MS-A70GL AD0605HS-A71GL AD0612LX-A70GL AD0612LX-A72GL AD0612MX-A70GL AD0612MX-A73GL AD0612HX-A70GL AD0612HX-A73GL AD0612UX-A70GL AD0612UX-A71GL AD0612UX-A72GL AD0612LB-A70GL AD0612LB-A70(T) AD0612MB-A70GL AD0612MB-A71GL AD0612MB-A72GL AD0612MB-A76GL AD0612HB-A70GL AD0612HB-A72GL AD0612UB-A70GL AD0612UB-A71GL AD0612UB-A72GL AD0612UB-A76GL AD0612XB-A71GL AD0612XB-A72/UP AD0612LS-A70GL AD0612LS-A73GL AD0612LS-A76GL AD0612MS-A70GL AD0612MS-A76GL AD0612HS-A70GL AD0612HS-A72GL HYPRO HYPRO BALL BALL BALL S S HYPRO BALL BALL BALL S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S S 24 24 24 24 24 24 24 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 0.08 0.09 0.08 0.09 0.09 0.08 0.09 0.32 0.32 0.45 0.45 0.32 0.60 0.08 0.08 0.14 0.14 0.23 0.23 0.25 0.27 0.27 0.08 0.08 0.14 0.14 0.14 0.14 0.23 0.23 0.25 0.25 0.25 0.25 0.38 0.65 0.08 0.08 0.08 0.14 0.14 0.23 0.23 1.92 2.16 1.92 2.16 2.16 1.92 2.16 1.60 1.60 2.25 2.25 1.60 3.00 0.96 0.96 1.68 1.68 2.76 2.76 3.00 3.24 3.24 0.96 0.96 1.68 1.68 1.68 1.68 2.76 2.76 3.00 3.00 3.00 3.00 4.56 7.80 0.96 0.96 0.96 1.68 1.68 2.76 2.76 3900 4500 3900 4500 4500 3900 4500 3500 3500 4500 4500 3500 4500 2500 2500 3500 3500 4500 4500 5000 5300 5300 2500 2300 3500 3500 3500 3500 4500 4500 5000 5000 5000 5000 6100 7400 2500 2500 2500 3500 3500 4500 4500 14.5 16.4 14.5 16.4 16.4 14.5 16.4 18.0 18.0 23.2 23.2 18.0 23.2 13.2 13.2 18.0 18.0 23.2 23.2 28.3 28.3 28.3 13.2 10.7 18.0 18.0 18.0 18.0 23.2 23.2 28.3 28.3 28.3 28.3 31.4 38.1 13.2 13.2 13.2 18.0 18.0 23.2 23.2 0.111 0.139 0.111 0.139 0.139 0.111 0.139 0.118 0.188 0.188 0.188 0.188 0.188 0.063 0.063 0.188 0.188 0.188 0.188 0.250 0.250 0.250 0.063 0.041 0.118 0.118 0.118 0.118 0.188 0.188 0.250 0.250 0.250 0.250 0.320 0.500 0.063 0.063 0.063 0.118 0.118 0.188 0.188 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 25.7 29.7 25.7 29.7 29.7 25.7 29.7 24.0 24.0 32.3 32.3 24.0 32.3 16.1 16.1 24.0 24.0 32.3 32.3 37.0 37.0 37.0 16.1 14.5 24.0 24.0 24.0 24.0 32.3 32.3 37.0 37.0 37.0 37.0 42.9 47.8 16.1 16.1 16.1 24.0 24.0 32.3 32.3 49 49 49 49 49 49 49 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 Features Available Safety Approvals 0 0 0 0,1 0,6 0 0 0 0 0,2 3 0 1 0 2,3 0,6 3 0,1,2 3,6 0 1 2,3 0,1 0,6 0 1 2,3 6 0,1 2,3,6 0 1 2,3 6 1,2,3 2 0,1 3 6 0 6 0,1 2,6 UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,TUV,CE TUV,CE CE UL,CUL,CE CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE CE UL,CUL,CE CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE UL,CUL,CE CE CE CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CSA,CE TUV,CE UL,CUL,TUV,CSA,CE CE Units Per Box Box Wt. (lbs.) 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 40.00 40.00 40.00 40.00 40.00 40.00 40.00 44.00 40.00 44.00 44.00 40.00 40.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 60 X 60 X 25 70 X 70 X 15 70 X 70 X 15 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 70 X 70 X 25 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0612HS-A73GL AD0612US-A70GL AD0612US-A71GL AD0612US-A73GL AD0624MX-A70GL AD0624MX-A76GL AD0624HX-A70GL AD0624HX-A72GL AD0624UX-A71GL AD0624LB-A70GL AD0624MB-A70GL AD0624HB-A70GL AD0624HB-A71GL AD0624HB-A72GL AD0624HB-A76GL AD0624UB-A70GL AD0624LS-A70GL AD0624MS-A70GL AD0624MS-A72GL AD0624HS-A70GL AD0624HS-A72GL AD0624HS-A73GL AD0624US-A71GL AD0712HB-DA6 AD0712UB-DA6 AD0705MX-A76GL AD0705MB-A76GL AD0712-LX-A70GL AD0712-MX-A70GL AD0712-HX-A70GL AD0712LB-A70GL AD0712MB-A70GL AD0712HB-A70GL AD0712UB-A76GL AD0712LS-A70GL AD0712MS-A70GL AD0712HS-A70GL AD0712US-A76GL AD0724HB-A70GL AD7512MX AD7512HX AD7512HX AD7512UX S S S S HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL S S S S S S S BALL BALL HYPRO BALL HYPRO HYPRO HYPRO BALL BALL BALL BALL S S S S BALL HYPRO HYPRO HYPRO HYPRO 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 12 12 5 5 12 12 12 12 12 12 12 12 12 12 12 24 12 12 12 12 0.23 0.25 0.27 0.27 0.08 0.08 0.15 0.15 0.16 0.05 0.08 0.15 0.15 0.15 0.15 0.16 0.05 0.08 0.08 0.15 0.15 0.15 0.16 0.27 0.30 0.30 0.30 0.12 0.16 0.19 0.12 0.16 0.19 0.24 0.12 0.16 0.19 0.24 0.13 0.20 0.30 0.30 0.55 2.76 3.00 3.24 3.24 1.92 1.92 3.60 3.60 3.84 1.20 1.92 3.60 3.60 3.60 3.60 3.84 1.20 1.92 1.92 3.60 3.60 3.60 3.84 3.24 3.60 1.50 1.50 1.44 1.92 2.28 1.44 1.92 2.28 2.88 1.44 1.92 2.28 2.88 3.12 2.40 3.60 3.60 6.60 4500 5000 5300 5300 3500 3500 4500 4500 5000 2500 3500 4500 4500 4500 4500 5000 2500 3500 3500 4500 4500 4500 5000 4200 4500 3800 3800 3300 3800 4200 3300 3800 4200 4500 3300 3800 4200 4500 4200 2600 3000 3000 4200 23.2 28.3 28.3 28.3 18.0 18.0 23.2 23.2 28.3 16.0 18.0 23.2 23.2 23.2 23.2 26.5 16.0 18.0 18.0 23.2 23.2 23.2 28.3 32.3 34.8 31.0 31.0 27.0 31.0 34.0 27.0 31.0 34.0 38.4 27.0 31.0 34.0 38.4 34.0 7.8 10.3 10.3 13.1 0.188 0.250 0.250 0.250 0.118 0.118 0.188 0.188 0.250 0.079 0.118 0.188 0.188 0.188 0.188 0.204 0.079 0.118 0.118 0.188 0.188 0.188 0.250 0.164 0.193 0.176 0.176 0.134 0.176 0.217 0.134 0.176 0.217 0.239 0.134 0.176 0.217 0.239 0.218 0.228 0.350 0.350 0.822 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 32.3 37.0 37.0 37.0 24.0 24.0 32.3 32.3 37.0 16.1 24.0 32.3 32.3 32.3 32.3 38.1 16.1 24.0 24.0 32.3 32.3 32.3 37.0 37.3 43.4 32.0 32.0 28.0 32.0 35.5 28.0 32.0 35.5 37.8 28.0 32.0 35.5 37.8 35.5 34.9 38.5 38.5 44.7 3 0,6 1 3 0 6 0,1 2 1,2 0 0,1 0 1 2,3 6 0,1,2,3 0 0,1 2 0,1 2 3 1 6 6 6 6 0 0 0 0 0,6 0,6 6 0 0 0,6 6 0 0 1 3 0,2,3 UL,CE CE TUV,CE CE UL,CUL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE CE CE UL,CUL,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CSA,TUV,CE UL,CUL,CE CE CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE CE UL,CE TUV,CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE CE UL,CUL,CE CE CE 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 54 54 61 61 61 61 61 61 61 61 61 61 61 61 61 61 80 80 80 80 Units Per Box Box Wt. (lbs.) 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 44.00 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 75 X 75 X 30 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 Model Part Number AD7512LB AD7512MB AD7512HB AD7512UB AD7512MS AD7512HS AD7524MX AD7524HX AD7524UX AD7524MB AD7524HB AD7524UB AD7524LS AD7524MS AD7524HS AD7524US AD0805MX-D71 AD0805HX-D71 AD0805MB-D71 AD0805HB-D70 AD0805HB-D71 AD0805MS-D71 AD0805HS-D70 AD0805HS-D71 AD0812LX-D70 AD0812MX-D70 AD0812MX-D71 AD0812MX-D73 AD0812HX-D70 AD0812HX-D71 AD0812HX-D73 AD0812LB-D70 AD0812LB-D73 AD0812MB-D70 AD0812MB-D71 AD0812MB-D73 AD0812MB-D74 AD0812HB-D70 AD0812HB-D71 AD0812HB-D72 AD0812HB-D73 AD0812HB-D74 AD0812LS-D70 NOTE B=Ball S=Sleeve X= Hypro Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) BALL BALL BALL BALL S S HYPRO HYPRO HYPRO BALL BALL BALL S S S S HYPRO HYPRO BALL BALL BALL S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 0.11 0.15 0.24 0.52 0.20 0.30 0.14 0.20 0.27 0.14 0.16 0.27 0.12 0.14 0.16 0.27 0.24 0.43 0.24 0.40 0.43 0.24 0.40 0.43 0.09 0.12 0.15 0.15 0.18 0.19 0.19 0.09 0.09 0.12 0.15 0.15 0.08 0.18 0.19 0.19 0.19 0.17 0.09 1.32 1.80 2.88 6.24 2.40 3.60 3.36 4.80 6.48 3.36 3.84 6.48 2.88 3.36 3.84 6.48 1.20 2.15 1.20 2.00 2.15 1.20 2.00 2.15 1.08 1.44 1.80 1.80 2.16 2.28 2.28 1.08 1.08 1.44 1.80 1.80 0.96 2.16 2.16 2.16 2.16 2.16 1.08 2200 2600 3000 4200 2600 3000 2600 3000 4200 2600 3000 4200 2200 2600 3000 4200 2440 3200 2440 3200 3200 2440 3200 3200 2000 2440 2440 2440 3200 3200 3200 2000 2000 2440 2440 2440 2440 3200 3200 3200 3200 3200 2000 6.9 7.8 10.3 13.1 7.8 10.3 7.8 10.3 13.1 7.8 10.3 13.1 6.9 7.8 10.3 13.1 22.4 29.9 22.4 29.9 29.9 22.4 29.9 29.9 20.0 22.4 22.4 22.4 29.9 28.0 28.0 20.0 20.0 22.4 22.4 22.4 22.1 29.9 29.9 29.9 29.9 29.9 20.0 0.190 0.228 0.350 0.822 0.228 0.350 0.228 0.350 0.822 0.228 0.350 0.822 0.190 0.228 0.350 0.822 0.083 0.129 0.083 0.129 0.129 0.083 0.129 0.129 0.050 0.083 0.083 0.083 0.129 0.107 0.107 0.050 0.050 0.083 0.083 0.083 0.087 0.129 0.129 0.129 0.129 0.129 0.050 AT= Terminals AW= Wires Noise Weight (dB/A) (g) 29.0 34.9 38.5 44.7 34.9 38.5 34.9 38.5 44.7 34.9 38.5 44.7 29.0 34.9 38.5 44.7 26.0 31.4 26.0 33.4 31.4 26.0 33.4 31.4 19.6 26.0 26.0 26.0 33.4 28.1 28.1 19.6 19.6 26.0 26.0 26.0 25.4 33.4 33.4 33.4 33.4 33.4 19.6 80 80 80 80 80 80 80 80 80 80 80 80 80 80 80 80 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 Features Available Safety Approvals 0 0,3 0,2,3 0,2,3 0 0,2 0 0 0 0 0 0 0 0 0 0 1 1 1 0 1 1 0 1 0 0,6 1 3 0,6 1 3 0,6 3 0,6 1 3 4 0,6 1 2 3 4 0,6 CE UL,CUL,CE UL,CUL,CE CE UL,CUL,CE UL,CUL,CE CE CE CE UL,CUL,CE UL,CUL,CE CE CE UL,CUL,CE UL,CUL,CE CE UL,CUL,CE UL,CUL,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 32.34 32.34 32.24 32.34 32.34 32.34 32.34 32.34 32.24 200 32.34 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 15 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0812MS-D70 AD0812MS-D71 AD0812MS-D73 AD0812HS-D70 AD0812HS-D71 AD0812HS-D73 AD0824MX-D71 AD0824HX-D71 AD0824MB-D71 AD0824HB-D70 AD0824HB-D71 AD0824MS-D70 AD0824MS-D71 AD0824HS-D71 AD0805HX-C72 AD0805HB-C70 AD0805HB-C71 AD0812LX-C70 AD0812MX-C70 AD0812MX-C76 AD0812HX-C70 AD0812HX-C72 AD0812UX-C72 AD0812LB-C70 AD0812LB-C76 AD0812MB-C70 AD0812MB-C71 AD0812MB-C72 AD0812HB-C70 AD0812HB-C71 AD0812HB-C72 AD0812UB-C72 AD0812LS-C70 AD0812LS-C76 AD0812MS-C70 AD0812MS-C71 AD0812MS-C72 AD0812MS-C76 AD0812HS-C70 AD0812HS-C70(UT) AD0812HS-C71 AD0812HS-C72 AD0824MX-C70 S S S S S S HYPRO HYPRO BALL BALL BALL S S S HYPRO BALL BALL HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S S S S S HYPRO 12 12 12 12 12 12 24 24 24 24 24 24 24 24 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 0.12 0.15 0.15 0.18 0.19 0.18 0.10 0.13 0.10 0.13 0.13 0.08 0.10 0.13 0.32 0.43 0.32 0.10 0.16 0.16 0.24 0.24 0.29 0.10 0.10 0.16 0.16 0.16 0.24 0.24 0.24 0.29 0.24 0.10 0.16 0.16 0.16 0.16 0.24 0.24 0.24 0.24 0.13 1.44 1.80 1.80 2.16 2.28 2.16 2.40 3.12 2.40 3.12 3.12 1.92 2.40 3.12 3.84 5.16 3.84 1.20 1.92 1.92 2.88 2.88 3.48 1.20 1.20 1.92 1.92 1.92 2.88 2.88 2.88 3.48 2.88 1.20 1.92 1.92 1.92 1.92 2.88 2.88 2.88 2.88 3.12 2440 2440 2440 3200 3200 3200 2440 3200 2440 3200 3200 2440 2440 3200 3010 3010 3010 2000 2440 2440 3010 3010 4200 2100 2100 2440 2440 2440 3100 3010 3010 4200 2040 2040 2440 2440 2440 2400 3010 3750 3010 3010 2440 22.4 22.4 22.4 29.9 29.9 29.9 21.0 29.0 21.0 32.0 32.0 22.4 21.0 29.0 27.3 27.3 27.3 18.9 22.1 21.8 27.3 27.3 38.9 19.3 27.3 22.1 22.1 22.1 28.8 27.3 27.3 38.9 27.3 27.3 22.1 22.1 22.1 21.8 27.3 33.5 27.3 27.3 22.1 0.083 0.083 0.083 0.129 0.129 0.129 0.070 0.116 0.070 0.131 0.131 0.083 0.070 0.116 0.128 0.128 0.128 0.059 0.087 0.085 0.128 0.128 0.234 0.067 0.128 0.087 0.087 0.087 0.138 0.128 0.128 0.234 0.128 0.128 0.087 0.087 0.087 0.085 0.128 0.194 0.128 0.128 2.210 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 26.0 26.0 26.0 33.4 33.4 33.4 27.0 33.5 27.0 33.6 33.6 26.0 27.0 33.5 31.4 31.4 31.4 17.7 25.4 25.0 31.4 31.4 40.7 22.4 31.4 25.4 25.4 25.4 32.4 31.4 31.4 40.7 31.4 31.4 25.4 25.4 25.4 25.0 31.4 34.0 31.4 31.4 25.4 0,6 1 3 0,6 1 3 1 1 1 0 1 0 1 1 2 0 1,2 0 0 6 0 2,3 2 0 6 0,6 1 2,3 0,6 1 2,3 2 0 6 0 1 2 6 0,6 0,6 1 2 0,1,2,3 UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE CE CE UL,CUL,CSA,CE CE UL,CUL,CSA,CE CE CE CE CE UL,CUL,TUV,CSA,CE UL,CSA,CE CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE CE CE UL,CE CE UL,CUL,TUV,CSA,CE UL,CSA,CE CE CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CSA,CE CE UL,CUL,TUV,CSA,CE 63 63 63 63 63 63 63 63 63 63 63 63 63 63 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 66 Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 32.34 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 20 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0824HX-C70 AD0824MB-C70 AD0824MB-C71 AD0824HB-C70 AD0824HB-C71 AD0824HB-C72 AD0824MS-C70 AD0824MS-C71 AD0824HS-C70 AD0824HS-C71 AD0812DX-A70GL AD0812LX-A70GL AD0812LX-A72GL AD0812LX-A73GL AD0812LX-A76GL AD0812MX-A70GL AD0812MX-A71GL AD0812MX-A76GL AD0812HX-A70GL AD0812HX-A71GL AD0812HX-A72GL AD0812UX-A70GL AD0812UX-A71GL AD0812UX-A72GL AD0812DB-A70GL AD0812LB-A70GL AD0812LB-A71GL AD0812LB-A72GL AD0812MB-A70GL AD0812MB-A70TS AD0812MB-A71GL AD0812MB-A73GL AD0812MB-A76GL AD0812HB-A70GL AD0812HB-A72GL AD0812HB-A74GL AD0812HB-A76GL AD0812UB-A70GL AD0812UB-A71GL AD0812UB-A72GL AD0812UB-A73GL AD0812DS-A70GL AD0812LS-A70GL HYPRO BALL BALL BALL BALL BALL S S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S 24 24 24 24 24 24 24 24 24 24 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 0.15 0.13 0.13 0.15 0.15 0.15 0.13 0.13 0.15 0.15 0.08 0.12 0.12 0.12 0.12 0.15 0.15 0.15 0.25 0.25 0.25 0.50 0.45 0.45 0.08 0.12 0.12 0.12 0.15 0.15 0.15 0.15 0.15 0.25 0.25 0.29 0.25 0.30 0.45 0.45 0.45 0.08 0.12 3.60 3.12 3.12 3.60 3.60 3.60 3.12 3.12 3.60 3.60 0.96 1.44 1.44 1.44 1.44 1.80 1.80 1.80 3.00 3.00 3.00 6.00 5.40 5.40 0.96 1.44 1.44 1.44 1.80 1.80 1.80 1.80 1.80 3.00 3.00 3.48 3.00 3.60 5.40 5.40 5.40 0.96 1.44 3010 2440 2440 3010 3010 3010 2440 2440 3010 3010 1600 2030 2030 2030 2030 2440 2450 2440 3010 3010 3010 3700 3900 3900 1600 2030 2030 2030 2440 2700 2440 2440 2440 3010 3010 3010 3010 3400 3900 3900 3900 1600 2030 27.3 22.1 22.1 27.3 27.3 27.3 22.1 22.1 27.3 27.3 20.5 25.0 25.0 26.2 25.0 31.4 31.5 31.4 38.6 38.6 38.6 48.3 50.0 50.0 20.5 26.2 26.2 26.2 31.4 33.0 31.4 31.4 31.4 38.6 38.6 38.6 38.6 43.8 50.0 50.0 50.0 20.5 26.2 0.128 0.087 0.087 0.128 0.128 0.128 0.087 0.087 0.128 0.128 0.051 0.090 0.090 0.078 0.090 0.114 0.115 0.114 0.160 0.160 0.160 0.268 0.279 0.279 0.050 0.078 0.078 0.078 0.114 0.130 0.114 0.114 0.114 0.160 0.160 0.160 0.160 0.190 0.279 0.279 0.279 0.050 0.078 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 31.4 25.4 25.4 31.4 31.4 31.4 25.4 25.4 31.4 31.4 14.0 22.0 22.0 22.5 22.0 28.3 27.6 28.3 34.4 34.4 34.4 40.0 41.0 41.0 15.0 22.5 22.5 22.5 28.3 29.0 28.3 28.3 28.3 34.4 34.4 34.4 34.4 40.0 41.0 41.0 41.0 15.0 22.5 70 70 70 70 70 70 70 70 70 70 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 Features Available Safety Approvals 0 0 1 0 1 2 0 1 0 1 0,1,2 0 2 3 6 0 1 6 0,6 1 2,3 0 1 2,3 0,1,3 0,6 1 2,3 0 0 1,2 3 6 0,1 2,3 4 6 0 1 2 3 0,6 0 UL,CUL,CSA,CE UL,CUL,TUV,CSA,CE UL,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE UL,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE CE UL,TUV,CSA,CE UL,CE UL,TUV,CE UL,CUL,TUV,CE UL,TUV,CSA,CE UL,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CSA,CE UL,CE UL,CUL,TUV,CE TUV,CE CE CE UL,TUV,CSA,CE UL,CSA,CE UL,TUV,CE UL,TUV,CSA,CE UL,TUV,CSA,CE UL,CSA,CE UL,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,TUV,CE TUV,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,CE CE UL,TUV,CSA,CE Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0812LS-A71GL AD0812LS-A73GL AD0812LS-A76GL AD0812MS-A70GL AD0812MS-A71GL AD0812MS-A73GL AD0812MS-A76GL AD0812HS-A70GL AD0812HS-A71GL AD0812HS-A72GL AD0812HS-A76GL AD0812US-A70GL AD0812US-A71GL AD0812US-A73GL AD0812US-A76GL AD0824LX-A70GL AD0824MX-A70GL AD0824MX-A72GL AD0824HX-A70GL AD0824HX-A71GL AD0824HX-A72GL AD0824UX-A71GL AD0824LB-A70GL AD0824LB-A71GL AD0824LB-A73GL AD0824MB-A70GL AD0824MB-A71GL AD0824MB-A73GL AD0824HB-A70GL AD0824HB-A71GL AD0824HB-A72GL AD0824HB-A73GL AD0824HB-A76GL AD0824UB-A71GL AD0824UB-A72GL AD0824UB-A73GL AD0824LS-A70GL AD0824LS-A76GL AD0824MS-A70GL AD0824MS-A71GL AD0824MS-A72GL AD0824MS-A76GL AD0824HS-A70GL S S S S S S S S S S S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S S 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 0.12 0.12 0.12 0.15 0.15 0.15 0.15 0.25 0.25 0.25 0.25 0.38 0.45 0.45 0.38 0.09 0.10 0.09 0.16 0.16 0.16 0.26 0.09 0.09 0.09 0.10 0.10 0.10 0.16 0.16 0.16 0.16 0.16 0.26 0.26 0.26 0.09 0.09 0.10 0.10 0.10 0.10 0.16 1.44 1.44 1.44 1.80 1.80 1.80 1.80 3.00 3.00 3.00 3.00 4.56 5.40 5.40 4.56 2.16 2.40 2.16 3.84 3.84 3.84 6.24 2.16 2.16 2.16 2.40 2.40 2.40 3.84 3.84 3.84 3.84 3.84 6.24 6.24 6.24 2.16 2.16 2.40 2.40 2.40 2.40 3.84 2030 2030 2030 2440 2440 2440 2440 3010 3010 3010 3010 3700 3900 3900 3700 2030 2440 2440 3010 3010 3010 3900 2030 2030 2030 2440 2440 2440 3010 3010 3010 3010 3200 3900 3900 3900 2030 2030 2440 2440 2440 2400 3010 26.2 26.2 26.2 31.4 31.4 31.4 31.4 38.6 38.6 38.6 38.6 46.7 50.0 50.0 46.7 26.2 31.4 31.4 38.6 38.6 38.6 50.0 26.2 26.2 26.2 31.4 31.4 31.4 38.6 38.6 38.6 38.6 40.0 50.0 50.0 50.0 26.2 26.2 31.4 31.4 31.4 30.0 38.6 0.078 0.078 0.078 0.114 0.114 0.114 0.114 0.160 0.160 0.160 0.160 0.226 0.279 0.279 0.226 0.078 0.114 0.114 0.166 0.166 0.166 0.279 0.078 0.078 0.078 0.114 0.114 0.114 0.160 0.160 0.160 0.160 0.171 0.279 0.279 0.279 0.078 0.078 0.114 0.114 0.114 0.100 0.160 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 22.5 22.5 22.5 28.3 28.3 28.3 28.3 34.4 34.4 34.4 34.4 38.5 41.0 41.0 38.5 22.5 28.3 28.3 34.0 34.0 34.0 41.0 22.5 22.5 22.5 28.3 28.3 28.3 34.4 34.4 34.4 34.4 35.0 41.0 41.0 41.0 22.5 22.5 28.3 28.3 28.3 27.0 34.4 1 3 6 0 1,2 3 6 0 1 2,3 6 0 1 3 6 0 0 2 0 1 2 0,1,2,3 0 1 3 0 1 3 0 1 2 3 6 1 2 3 0,1 6 0 1 2 6 0 UL,CSA,CE UL,TUL,CE UL,CUL,TUV,CE UL,TUV,CSA,CE UL,CSA,CE UL,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,TUL,CE UL,CE UL,CUL,TUV,CE CE TUV,CE CE UL,CUL,TUV,CE UL,CSA,CE UL,TUV,CSA,CE UL,CE UL,TUV,CSA,CE UL,CSA,CE UL,CE CE UL,TUV,CSA,CE UL,CSA,CE UL,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CE UL,TUV,CSA,CE UL,TUV,CSA,CE UL,TUV,CE UL,CE UL,CE UL,CUL,TUV,CE UL,CUL,CE CE UL,CSA,CE UL,CE UL,TUV,CSA,CE UL,CSA,CE UL,CE UL,CE UL,TUV,CSA,CE 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 80 X 80 X 25 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0824HS-A71GL AD0824US-A70GL AD0824US-A71GL AD0848HB-A71GL AD0848HB-A73GL AD0848XB-A76GL AD0848HS-A71GL AD0848HS-A73GL AD0912MX-C70 AD0912HX-C70 AD0912HX-C7 AD0912MB-C70 AD0912MB-C71 AD0912MB-C72 AD0912MB-C76 AD0912HB-C70 AD0912HB-C71 AD0912HB-C72 AD0912MS-C70 AD0912MS-C71 AD0912HS-C70 AD0912HS-C71 AD0912HS-C76 AD0924MX-C70 AD0924HX-C70 AD0924MB-C70 AD0924MB-C71 AD0924HB-C70 AD0924HB-C71 AD0924HB-C73 AD0924MS-C70 AD0924MS-C71 AD0924HS-C70 AD0924HS-C71 AD0912DX-A70GL AD0912DX-A71GL AD0912LX-A70GL AD0912LX-A72GL AD0912LX-A76GL AD0912MX-A70GL AD0912HX-A70GL AD0912HX-A76GL AD0912UX-A71GL S S S BALL BALL BALL S S HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL S S S S S HYPRO HYPRO BALL BALL BALL BALL BALL S S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO 24 24 24 48 48 48 48 48 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 12 12 12 12 12 12 12 12 12 0.16 0.29 0.26 0.11 0.11 0.13 0.11 0.08 0.16 0.25 0.25 0.16 0.16 0.16 0.16 0.25 0.25 0.25 0.16 0.16 0.25 0.25 0.25 0.10 0.14 0.10 0.10 0.14 0.14 0.14 0.10 0.10 0.14 0.14 0.09 0.07 0.12 0.13 0.13 0.17 0.25 0.25 0.39 3.84 6.96 6.24 5.28 5.28 6.24 5.28 3.84 1.92 3.00 3.00 1.92 1.92 1.92 1.92 3.00 3.00 3.00 1.92 1.92 3.00 3.00 3.00 2.40 3.36 2.40 2.40 3.36 3.36 3.36 2.40 2.40 3.36 3.36 1.08 0.84 1.44 1.56 1.56 2.04 3.00 3.00 4.68 3010 4100 3900 3010 3010 4500 3010 3010 2430 2740 2740 2430 2430 2430 2430 2740 2740 2740 2430 2430 2740 2740 2740 2430 2740 2430 2430 2740 2740 2740 2430 2430 2740 2740 1600 1600 2100 2200 2000 2400 2700 2700 3200 38.6 52.5 50.0 38.6 38.6 55.2 38.6 38.6 29.0 32.8 32.8 29.0 29.0 29.0 29.0 32.8 32.8 32.8 29.0 29.0 32.8 32.8 32.8 29.0 32.8 29.0 29.0 32.8 32.8 32.8 29.0 29.0 32.8 32.8 28.0 28.0 37.9 35.9 32.4 43.5 50.0 50.0 57.8 0.160 0.253 0.279 0.160 0.160 0.302 0.160 0.160 0.083 0.106 0.106 0.083 0.083 0.083 0.083 0.106 0.106 0.106 0.083 0.083 0.106 0.106 0.106 2.110 0.106 0.083 0.083 0.106 0.106 0.106 0.083 0.083 0.106 0.106 0.060 0.060 0.073 0.097 0.054 0.094 0.117 0.117 0.158 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 34.4 42.0 41.0 34.4 34.4 44.8 34.4 34.4 28.9 32.8 32.8 28.9 28.9 28.9 28.9 32.8 32.8 32.8 28.9 28.9 32.8 32.8 32.8 28.9 32.8 28.9 28.9 32.8 32.8 32.8 28.9 28.9 32.8 32.8 22.0 22.0 26.5 29.3 23.5 31.3 33.7 33.7 38.6 1,2 0 1 1 3,6 6 1 3,6 0 0 6 0 1 2 6 0,6 1 2,3 0 1 0 1 6 0,1,2,3 0 0 1 0 1 3 0 1 0 1 0 1 0 2 6 0,2,3 0,2,3 6 1,2 UL,CSA,CE CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE CE TUV,CSA,CE UL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE TUV,CE CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE TUV,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE 86 86 86 86 86 86 86 86 85 85 85 85 85 85 85 85 85 85 85 85 85 85 85 78 85 85 85 85 85 85 85 85 85 85 101 101 101 101 101 101 101 101 101 Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 35.20 35.20 35.20 35.20 35.20 35.20 35.20 35.20 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0912UX-A76GL AD0912DB-A71GL AD0912LB-A70GL AD0912LB-A702GL AD0912LB-A76GL AD0912MB-A70GL AD0912MB-A76GL AD0912HB-A70GL AD0912HB-A76GL AD0912UB-A71GL AD0912UB-A76GL AD0912XB-A71GL AD0912DS-A70GL AD0912DS-A71GL AD0912LS-A70GL AD0912LS-A73GL AD0912LS-A76GL AD0912MS-A70GL AD0912MS-A76GL AD0912HS-A70GL AD0912HS-A76GL AD0912US-A70GL AD0912US-A71GL AD0912US-A76GL AD0924LX-A70GL AD0924MX-A70GL AD0924MX-A71GL AD0924HX-A70GL AD0924UX-A71GL AD0924UX-A73GL AD0924LB-A70GL AD0924LB-A72GL AD0924LB-A76GL AD0924MB-A70GL AD0924HB-A70GL AD0924HB-A76GL AD0924UB-A72GL AD0924XB-A71GL AD0924LS-A70GL AD0924MS-A70GL AD0924HS-A70GL AD0924HS-A72GL AD0924HS-A73GL HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S S S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL S S S S S 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 0.30 0.07 0.13 0.12 0.12 0.17 0.17 0.25 0.25 0.39 0.39 0.55 0.09 0.07 0.13 0.13 0.13 0.17 0.17 0.25 0.25 0.39 0.39 0.30 0.08 0.12 0.17 0.15 0.21 0.21 0.08 0.08 0.08 0.12 0.15 0.15 0.21 0.25 0.08 0.12 0.15 0.20 0.20 3.60 0.84 1.56 1.44 1.44 2.04 2.04 3.00 3.00 4.68 4.68 6.60 1.08 1.08 1.56 1.56 1.56 2.04 2.04 3.00 3.00 4.68 4.68 3.60 1.92 2.88 2.04 3.60 5.04 5.04 1.92 1.92 1.92 2.88 3.60 3.60 5.04 6.00 1.92 2.88 3.60 4.80 4.80 3300 1600 2050 2300 2300 2600 2600 2900 2900 3300 3300 3800 1600 1600 2000 2100 2000 2350 2350 2700 2700 3200 3300 3300 2100 2400 2700 2700 3200 3200 2100 2300 2300 2600 2900 2900 3300 3800 2100 2400 2700 3000 3000 60.0 28.0 36.0 41.6 41.6 47.2 47.2 52.5 52.5 60.0 60.0 67.0 28.0 28.0 32.4 37.9 32.4 43.0 43.0 50.0 50.0 57.8 60.0 60.0 37.9 43.5 43.2 50.0 57.8 57.8 37.9 41.6 41.6 47.2 52.5 52.5 60.0 66.9 37.9 43.5 48.0 48.4 48.4 0.166 0.060 0.063 0.087 0.087 0.108 0.108 0.133 0.133 0.166 0.166 0.198 0.060 0.060 0.054 0.073 0.054 0.087 0.870 0.117 0.117 0.156 0.198 0.166 0.073 0.094 0.140 0.115 0.156 0.156 0.074 0.086 0.086 0.106 0.131 0.131 0.166 0.186 0.073 0.094 0.115 0.169 0.169 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 39.4 22.0 25.0 29.8 29.8 32.7 32.7 35.0 35.0 39.4 39.4 43.9 22.0 22.0 23.5 26.5 23.5 31.0 31.0 33.7 33.7 39.4 39.1 39.4 26.5 31.3 35.0 33.7 38.6 38.6 26.5 29.8 29.8 32.7 35.0 35.0 39.4 42.6 26.5 31.3 33.7 38.0 38.0 6 1 0 2,3 6 0,1,2,3 6 0,1,2,3 6 1,2,3 6 1 0 1 0 3 6 0,3 6 0,1,2,3 6 0 1,2 6 0 0,2 1 0 1,2 3 0 2 6 0,2 0,1,2,3 6 2 1,2 0,2 0,2 0 2 3 UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 25.36 52.36 52.36 52.36 52.36 52.36 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0924US-A70GL AD0924US-A71GL AD0924US-A72GL AD0948HB-A71GL AD0948UB-A71GL AD0948HS-A72GL AD1212LX-A71GL AD1212LX-A72GL AD1212MX-A71GL AD1212MX-A73GL AD1212HX-A71GL AD1212HX-A73GL AD1212UX-A71GL AD1212LB-A71GL AD1212LB-A73GL AD1212MB-A71GL AD1212MB-A72GL AD1212MB-A73GL AD1212HB-A71GL AD1212HB-A72GL AD1212HB-A73GL AD1212UB-A71GL AD1212UB-A72GL AD1212LS-A71GL AD1212MS-A71GL AD1212MS-A72GL AD1212HS-A71GL AD1212HS-A72GL AD1212HS-A73GL AD1212HS-A74GL AD1212US-A71GL AD1224LX-A71GL AD1224MX-A71GL AD1224HX-A71GL AD1224HX-A73GL AD1224UX-A72GL AD1224LB-A71GL AD1224MB-A71GL AD1224HB-A71GL AD1224UB-A71GL AD1224UB-A72GL AD1224LS-A71GL AD1224MS-A71GL S S S BALL BALL S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL S S 24 24 24 48 48 48 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 0.21 0.21 0.21 0.13 0.16 0.07 0.24 0.24 0.34 0.34 0.44 0.44 0.50 0.24 0.24 0.33 0.33 0.33 0.37 0.37 0.37 0.50 0.50 0.24 0.34 0.34 0.44 0.44 0.44 0.40 0.50 0.14 0.20 0.24 0.24 0.25 0.14 0.17 0.19 0.25 0.25 0.14 0.20 5.04 5.04 5.04 6.24 7.68 3.36 2.88 2.88 4.08 4.08 5.28 5.28 6.00 2.88 2.88 3.96 3.96 3.96 4.44 4.44 4.44 6.00 6.00 2.88 4.08 4.08 5.28 5.28 5.28 4.80 6.00 3.36 4.80 5.76 5.76 6.00 3.36 4.08 4.56 6.00 6.00 3.36 4.80 3300 3200 3200 2900 3300 2900 1800 1800 2050 2050 2200 2200 2500 1800 1800 2050 2050 2050 2200 2200 2200 2500 2500 1800 2050 2050 220 220 220 2200 2500 1800 2050 2200 2200 2500 1800 2050 2200 2500 2500 1800 2050 60.0 57.8 57.8 52.5 60.0 52.0 72.0 72.0 80.5 80.5 85.2 85.2 98.6 72.0 72.0 80.5 80.5 80.5 85.2 85.2 85.2 98.6 98.6 72.0 80.5 80.5 85.2 85.2 85.2 85.2 98.6 72.0 80.5 85.2 85.2 98.6 72.0 80.5 85.2 98.6 98.6 72.0 80.5 0.166 0.158 0.158 0.133 0.163 0.177 0.095 0.095 0.117 0.117 0.136 0.136 0.179 0.095 0.095 0.117 0.117 0.117 0.136 0.136 0.136 0.179 0.179 0.095 0.117 0.117 0.136 0.136 0.136 0.134 0.179 0.095 0.117 0.136 0.136 0.176 0.095 0.117 0.136 0.176 0.176 0.095 0.117 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 39.4 38.6 38.6 35.0 39.4 34.0 34.4 34.4 38.0 38.0 39.1 39.1 43.3 34.4 34.4 38.0 38.0 38.0 39.1 39.1 39.1 43.3 43.3 34.4 38.0 38.0 39.1 39.1 39.1 39.1 43.3 34.4 38.0 39.1 39.1 43.3 34.3 38.0 39.1 43.3 43.3 34.4 38.0 101 101 101 101 101 101 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 158 158 158 156 156 156 156 156 156 156 156 156 156 156 156 156 156 Features Available Safety Approvals 0 1 2 1 1 2 1 2 1 3 1 3 1 1,2 3 1 2 3 1 2 3 1 2,3 1,3 1,3 2 1 2 3 4 1,2,3 1 1 1,2 3 2 1,2 1 1,2,3 1 2,3 1 1 UL,CUL,TUV,CE UL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,CE CE TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE CE TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 52.36 52.36 52.36 52.36 52.36 52.36 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 Model Part Number AD1224HS-A71GL AD1224HS-A73GL AD1224US-A71GL AD1248HB-A71GL AD2512LX AD2512MX AD2512LB AD2512MB AD2512MB AD2512MB AD2512HB AD2512UB AD2512LS AD2512MS AD2512HS AD2512US AD2524MX AD2524MB AD2524HB AD2524UB AD2524MS AD2524US AD1212LX-F51 AD1212LX-F53 AD1212MX-F51 AD1212MX-F53 AD1212HX-F51 AD1212HX-F52 AD1212HX-Y51 AD1212LB-F51 AD1212LB-F52 AD1212MB-F51 AD1212MB-F52 AD1212HB-F51 AD1212HB-F52 AD1212HB-F57 AD1212HB-Y51 AD1212UB-F51 AD1212UB-F53 AD1212LS-F51 AD1212MS-F51 AD1212MS-F52 AD1212HS-F51 NOTE B=Ball S=Sleeve X= Hypro Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) S S S BALL HYPRO HYPRO BALL BALL BALL BALL BALL BALL S S S S HYPRO BALL BALL BALL S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S 24 24 24 48 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 0.24 0.24 0.25 0.25 0.15 0.60 0.15 0.60 0.60 0.60 0.65 1.00 0.15 0.60 0.65 1.00 0.40 0.40 0.43 0.50 0.40 0.50 0.24 0.24 0.35 0.35 0.50 0.50 0.40 0.24 0.24 0.35 0.35 0.50 0.50 0.50 0.40 0.07 0.07 0.24 0.35 0.35 0.50 5.76 5.76 6.00 9.60 1.80 7.20 1.80 7.20 7.20 7.20 7.80 8.00 1.80 7.20 7.80 8.00 9.60 9.60 9.80 9.80 9.60 9.80 2.88 2.88 4.20 4.20 6.00 6.00 4.80 2.88 2.88 4.20 4.20 6.00 6.00 6.00 4.80 0.84 0.84 2.88 4.20 4.20 6.00 2200 2200 2500 2200 1200 2300 1200 2300 2300 2300 2500 3200 1200 2300 2500 3200 2300 2300 2500 2800 2300 2800 1950 1950 2540 2540 2800 2800 2750 1950 1950 2540 2540 2800 2800 2800 2750 3200 3200 1950 2540 2540 2800 85.2 85.2 98.6 85.2 12.0 23.7 12.0 23.7 23.7 23.7 25.2 33.1 12.0 23.7 25.2 33.1 23.7 23.7 25.2 29.4 23.7 29.4 72.3 72.3 94.0 94.0 104.8 104.8 108.0 72.3 72.3 94.0 94.0 104.8 104.8 104.8 108.0 122.0 122.0 72.3 94.0 94.0 104.8 0.136 0.136 0.176 0.136 0.109 0.621 0.109 0.621 0.621 0.621 0.640 1.121 0.109 0.621 0.640 1.121 0.621 0.621 0.640 0.800 0.621 0.800 0.135 0.135 0.244 0.244 0.270 0.270 0.215 0.135 0.135 0.244 0.244 0.270 0.270 0.270 0.215 0.394 0.394 0.135 0.244 0.244 0.270 AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 39.1 39.1 43.3 39.1 34.3 51.1 34.3 51.1 51.1 51.1 51.0 55.8 34.3 51.1 51.0 55.8 51.1 51.1 51.0 52.5 51.1 52.5 32.9 32.9 41.0 41.0 42.8 42.8 43.3 32.9 32.9 41.0 41.0 42.8 42.8 42.8 43.3 48.0 48.0 32.9 41.0 41.0 42.8 1 3 1 1 0 0 0,3 0 2 3 0,3 0,2,3 0 0 0 0 0 0 0 0 0 0 1 3 1 3 1,4 2 1 1,3 2 1 2,3,4,7 1,3 2,4 7 1,3 1,2,4 3 1 1 2,3,4,7 1,4 UL,CUL,TUV,CE CE CE CE TUV,CE UL,CUL,CE TUV,CE UL,CUL,TUV,CE TUV,CE CE CE CE TUV,CE TUV,CE CE CE UL,TUV,CE UL,CUL,CSA,TUV,CE CE CE UL,CSA,TUV,CE CE UL,CUL,TUV,CE CE UL,CUL,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE CSA,CE CE UL,CUL,TUV,CE UL,CE UL,CUL,TUV,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE CSA,CE CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE 156 156 156 156 276 276 276 276 276 276 276 276 276 276 276 276 276 276 276 276 276 276 297 297 297 297 297 297 213 297 297 297 297 297 297 297 213 297 297 297 297 297 297 Units Per Box Box Wt. (lbs.) 90 90 90 90 30.80 30.80 30.80 30.80 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) Model Part Number 120 X 120 X 38 AD1212HS-F52 120 X 120 X 38 AD1212US-F51 120 X 120 X 38 AD1224MX-F51 120 X 120 X 38 AD1224HX-F51 120 X 120 X 38 AD1224UX-F51 120 X 120 X 38 AD1224UX-F52F 120 X 120 X 38 AD1224LB-F51 120 X 120 X 38 AD1224MB-F51 120 X 120 X 38 AD1224MB-F52 120 X 120 X 38 AD1224MB-F54 120 X 120 X 38 AD1224HB-F51 120 X 120 X 38 AD1224HB-F52 120 X 120 X 38 AD1224HB-F54 120 X 120 X 38 AD1224UB-F51 120 X 120 X 38 AD1224LS-F51 120 X 120 X 38 AD1224MS-F51 120 X 120 X 38 AD1224MS-F52 120 X 120 X 38 AD1224HS-F51 120 X 120 X 38 AD1224HS-F52 120 X 120 X 38 AD1224US-F51 120 X 120 X 38 AD1248MX-F52 120 X 120 X 38 AD1248HX-F51 120 X 120 X 38 AD1248HX-F52 120 X 120 X 38 AD1248LS-F51 120 X 120 X 38 AD1248MS-F51 120 X 120 X 38 AD1248MS-F52 120 X 120 X 38 AD1248LB-F51 120 X 120 X 38 AD1248MB-F51 120 X 120 X 38 AD1248MB-F52 120 X 120 X 38 AD1248HB-F51 120 X 120 X 38 AD1248HB-F53 120 X 120 X 38 AD1248HB-F54 120 X 120 X 38 AD1248HB-Y56 120 X 120 X 38 AD1248UB-F51 120 X 120 X 38 AD1248HS-F51 120 X 120 X 38 AD1248HS-F53 NOTE B=Ball S=Sleeve X= Hypro NOTE B=Ball S=Sleeve X= Hypro Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) S 12 0.50 6.00 S 12 0.70 8.40 HYPRO 24 0.23 5.52 HYPRO 24 0.32 7.68 HYPRO 24 0.40 9.60 HYPRO 24 0.40 9.60 BALL 24 0.14 3.36 BALL 24 0.23 5.52 BALL 24 0.23 5.52 BALL 24 0.23 5.52 BALL 24 0.32 7.68 BALL 24 0.32 7.68 BALL 24 0.32 7.68 BALL 24 0.40 9.60 S 24 0.14 3.36 S 24 0.23 5.52 S 24 0.23 5.52 S 24 0.32 7.68 S 24 0.32 7.68 S 24 0.40 9.60 HYPRO 48 0.14 6.72 HYPRO 48 0.20 9.60 HYPRO 48 0.20 9.60 S 48 0.10 4.80 S 48 0.14 6.72 S 48 0.14 6.72 BALL 48 0.10 4.80 BALL 48 0.14 6.72 BALL 48 0.14 6.72 BALL 48 0.20 9.60 BALL 48 0.20 9.60 BALL 48 0.20 9.60 BALL 48 0.13 6.24 BALL 48 0.23 9.80 S 48 0.20 9.60 S 48 0.20 9.60 AT= Terminals AW= Wires 2800 3200 2540 2800 3200 3200 1950 2540 2540 2540 2800 2800 2800 3200 1950 2540 2540 2800 2800 3200 2540 2800 2800 1950 2540 2540 1950 2540 2540 2800 2800 2800 2750 3200 2800 2800 104.8 122.0 94.0 104.8 122.0 122.0 72.3 94.0 94.0 94.0 104.8 104.8 104.8 122.0 72.3 94.0 94.0 104.8 104.8 122.0 94.0 104.8 104.8 72.3 94.0 94.0 72.3 94.0 94.0 104.8 104.8 104.8 108.0 122.0 104.8 104.8 0.270 0.394 0.244 0.270 0.394 0.394 0.135 0.244 0.244 0.244 0.270 0.270 0.270 0.394 0.135 0.244 0.244 0.270 0.270 0.394 0.244 0.270 0.270 0.135 0.244 0.244 0.135 0.244 0.244 0.270 0.270 0.270 0.215 0.394 0.270 0.270 AT= Terminals AW= Wires Noise Weight (dB/A) (g) 42.8 48.0 41.0 42.8 48.0 48.0 32.9 41.0 41.0 41.0 42.8 42.8 42.8 48.0 32.9 41.0 41.0 42.8 42.8 48.0 41.0 42.8 42.8 32.9 41.0 41.0 32.9 41.0 41.0 42.8 42.8 42.8 43.3 48.0 42.8 42.8 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 213 297 297 297 Features Available 2,3,7 1 1 1,2 1 2 1 1,3 2 4 1 2,3 4,7 1,2,3 1 1 2,3,4 1 2,3,4 1 2 1 2 1 1 2 1,3 1 2,3 1,2 3 4 6 1,3 1,2 3 Safety Approvals Units Per Box Box Wt. (lbs.) CSA,CE CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE UL,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE UL,CSA,TUV,CE CSA,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE CSA,CE UL,CUL,CE UL,CE UL,CUL,TUV,CSA,CE UL,CUL,CSA,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE UL,CE CE CE CE UL,CUL,TUV,CSA,CE CE ALL RIGHTS RESERVED 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 ALL RIGHTS RESERVED
AD1212LB-A71GL 价格&库存
很抱歉,暂时无法提供与“AD1212LB-A71GL”相匹配的价格&库存,您可以联系我们找货
