AK2582HB-AT
AK2582HB-AT
    ADDA(協禧電機)
AK2582HB-AT 数据手册
AK2582HB SA-0120120522007 2020.02.17 E 研發處 2020.02.17 發行章 (AT) DATA-SHEET Engineering Printed On: 20/02/17 BRUSHLESS AXIAL COOLING FANS Customer : Adda Model No : Samples attached : Safety Approval : Ref: AK2582HB P.S: (AT) Piece(s), TUV:EN 60335-1:2012+A11 EN 60335-2-80:2003+A1+A2 UL:UL 507 CE: EN 55014-1:2006+A1+A2 EN 55014-2:2015 EN 61000-3-2:2014 EN 61000-3-3:2013 UL,CUL, TUV,CE Specifications ITEM (RoHS) SPECIFICATION / CONDITION DIMENSIONS : 254x89 BEARING TYPE : TWO BALL RATED VOLTAGE : 230 VAC OPERATING VOLTAGE RANGE : 200 VAC - 240 : 50 / 60 Hz REAL CURRENT : 0.26 / 0.30 Amp REAL POWER : 55.40 / 62.80 Watt RATED CURRENT : 0.26 / 0.30 Amp RATED POWER : 59.80 / 69.00 Watt RATED SPEED : 2100 / 2000 RPM AIR FLOW : 680.000 / 630.000 CFM (min: 612.00 / 567.00 CFM) AIR FLOW : 19.244 / 17.829 (min: 17.32 / 16.05 CMM) / (In free air at rated voltage)   OPERATIONG FREQUENCY mm CMM VAC + 10% ± 10% STATIC AIR PRESSURE : 0.346 / 0.276 Inch H2O (min: 0.28 / 0.223 Inch H2O) STATIC AIR PRESSURE : 8.788 / 7.010 mm H2O (min: 7.12 / 5.68 mm H2O) / (In free air at rated voltage) / 62.0 / 66.0 dB(A)) NOISE LEVEL : 66.0 MOTOR PROTECTION : Thermal LIFE EXPECTANCY : 50000 Hours NET WEIGHT : 2000 Gram. PACKING : 6 pcs. Per Export Carton. dB(A) (max.: 70.0 25℃ / 65% RH Protect at Unless otherwise stated, the relative humidity is 65%, and the temperature is 25oC for the standard testing. Should you have any doubt, please refer to the environmental conditions specified in the acknowledgement document. ADDA CORPORATION Model No.: AK2582HB P.S: (AT) 研發處 2020.02.17 發行章 Page 1/4 SPECIFICATION :This documentation defines the mechanical & electrical charcterists of AC brushless fans. 2.0 Material : 1.0 Scope 2.1 Housing High quality aluminum die-casting frame flated with black paint. 2.2 Fan blade UL 94V - 0 Glass filled polyester ( P.B.T ) 2.3 RoHS wire 2.4 Connector UL 1015 , 20 AWG □ Not included in this fan □ Note as : _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _______________________________ 3.0 Dimension & construction : All dimension, direction of rotation and air flow, rated characteristics are specifide in drawing & data-sheet of enclosed. 4.0 Characteristics definition : 4.1 Rated current : Rated current shall be measured after 30 minutes continuous rotation at rated voltage. 4.2 Rated speed : Rated speed shall be measured after 30 minutes continuous rotation at rated voltage. 4.3 Start voltage : The voltages that enable to start the fan by sudden switch on. : Input power shall be measured after 30 minutes continuous rotation at rated voltage. 4.5 Locked current : Locked current shall be measured with in one minutes or rotor locked , After 30 minutes continuous rotation at rated voltage in clean air. 4.6 Air flow & static pressure : The air flow data and static pressures are determined in accordance with AMCA-210 standard in a double-chamber testing with intake-side measurement. 4.4 Input power 研發處 ADDA 10.05.13 發行章 研發處 2020.02.17 發行章 CORPORATION AC FAN SERIES Page 2/4 SPECIFICATION 4.7 Noise level : The measurement of noise level is carried out with reference to CNS8753 in a anechoic chamber with the microphone positioned 1 M from the air intake. Testing fan shall be hung in clear air. Feature of noise level measurement = = > microphone 5.0 Mechanical inspection air flow test fan 1.0 M 5.1 Rotation direction : Clockwise from the front face of the fan. A clear " = = > " ( arrow mark ) shall be found on the body of housing . 5.2 Safe design : All fans have intergrated protection against locked rotor condition so that there can be no damage on winding and / or any electrical components. Restart is automatic as soon as any constraint to running has been released. 5.3 Locked rotor protection : No damage shall be found for continuous 72 hours at condition of rotation locked. Restart is automatic as soon as constraint to running has be relessed. 5.4 Free drop shock : In minute package condition. The fan should withstand each one drop of three faces from 30 cm distance height onto 10 mm thickness of wooden board 6.0 Electrical inspection 6.1 Insulation resistance : 100 MΩ or more at 500 V megger. 6.2 Dielectric strength 研發處 2020.02.17 : 1 minute at 1500 VAC / 50-60Hz 發行章 7.0 Environmental 7.1 Operating Temperature : - 10℃ ~ + 70℃ 7.2 Humidity RH : 20 % ~ 85 % ( Max ) 7.3 Storage Temperature : Will satisfy performace standards after 500 hours storage at - 40 ℃ ~ 70 ℃ ( normal humidity ) with a 24 - hour recovery period at room temperature. ADDA CORPORATION AC FAN SERIES Page 3/4 SPECIFICATION 7.4 Humidity : After 96 hrs, 95 % RH, 40 ± 2 ℃ per MIL - STD - 202F, method 103B, Humidity test, The measured data of insulation resistance & dielectric strength should meet the specification listed in attach. 7.5 Theraml Shock : After thermal shock test per MIL - STD - 202F, method 107G, condition D, The measured data of insulation resistance & dielectric strength should the specification listed in datasheet. 7.6 Do not place or store the fan in the environment with high/low temperature/humidity. If the fan is stored for more than 6 months, functional test is highly recommended before using. 8.0 Remark 8.1 Material and construction are subject to change without advance notice. The changes should be within specification listed in this approved sheet. 8.2 All the fans shall meet the inspection under sampling plan MIL - STD - 105E, The AQL are as follow: Critical Major Minor AQL = 0 . 25 % AQL = 1 . 00 % AQL = 2 . 50 % 研發處 2020.02.17 發行章 ROTATION 9.0 Drawing AIR ADDA CORPORATION AC FAN SERIES Page 4/4 SPECIFICATION 10.0 Notes: 10.1 Please do not touch and push Fan Blade with fingers or others, fan blade and ball bearings may be damaged and it causes noise defect. 10.2 Do not carry the fan by its lead wires. 10.3. Every specific fan is designed for its certain application (project). Therefore, if you want to use this fan in other application (project), please inform ADDA first so that we can confirm whether there is any issue which might be incurred from the reason of this different application (project) or not. 10.4 The "Life Expectancy" of this fan has not been evaluated for use in combination with any end application. Therefore, the Life Expectancy in the Test Reports (L10 and MTTF Report) that relate to this fan is for reference only and shall not construe any kind of warranty of ADDA to the life of any specific fan,either expressed or implied. 10.5 The period of product warranty, unless otherwise agreed by ADDA in written, shall be 12 months staring from the date of production. 研發處 2020.02.17 發行章 ADDA CORPORATION AC FAN SERIES 2 0 1 0 . 0 4 . 0 7 發行章 AK2582HB(AW) 230V_50Hz 230V_60Hz 研發處 2020.02.17 發行章
AK2582HB-AT 价格&库存
很抱歉,暂时无法提供与“AK2582HB-AT”相匹配的价格&库存,您可以联系我们找货
