AD0605MB-A70GL
AD0605MB-A70GL
    ADDA(協禧電機)
AD0605MB-A70GL 数据手册
AD6025(T) SERIES Exter nal Dimensions Frame:Plastic(UL:94V-0) Impeller:Plastic(UL:94V-0) Lead wire:UL1007AWG24 Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size (mm) 60x60x25 Rated Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) 0.07 0.35 2500 0.360 Bearing Rated System Voltage Current Type (VDC) 5 AD06005LB257000 ◎※ ● (CFM) 12.710 (InAq) (mmAq) 0.080 1.930 *Noise Level Weight (dB/A) (g) 15.9 AD06005MB257000 ◎※ ● 5 0.14 0.70 3500 0.490 17.340 0.130 3.330 26.9 AD06005HB257000 ◎※ ● 5 0.28 1.40 4500 0.660 23.340 0.230 5.920 33.8 AD06012DB257000 ◎※ ● 12 0.03 0.36 2000 0.280 9.980 0.050 1.240 12.4 AD06012LB257000 ◎※ ● 12 0.04 0.48 2500 0.360 12.710 0.080 1.930 15.9 AD06012MB257000 ◎※ ● 12 0.06 0.72 3500 0.490 17.340 0.130 3.330 26.9 AD06012HB257000 ◎※ ● 12 0.12 1.44 4500 0.660 23.340 0.230 5.920 33.8 AD06012UB257000 ◎※ ● 12 0.18 2.16 5000 0.740 25.970 0.280 7.190 37.1 AD06024MB257000 ◎※ ● 24 0.03 0.72 3500 0.490 17.340 0.130 3.330 26.9 AD06024HB257000 ◎※ ● 24 0.06 1.44 4500 0.660 23.340 0.230 5.920 33.8 AD06024UB257000 ◎※ ● 24 0.08 1.92 5000 0.740 25.970 0.280 7.190 37.1 AD06024XB257000 ◎※ ● 24 0.14 3.36 6000 0.890 31.380 0.370 9.300 42.8 53.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) F a n P erformance Curve FLOWRATE(CMM) 0.000 10.0 0.198 0.396 0.594 0.792 0.991 0.394 X 風扇型號: U H 8.0 0.315 M *Motor protective circuit and third lead wire functions D 6.0 0.236 4.0 0.157 2.0 0.079 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) L 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 7 14 21 28 35 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0605MB-A70GL 价格&库存
很抱歉,暂时无法提供与“AD0605MB-A70GL”相匹配的价格&库存,您可以联系我们找货
