AD0924HB-A70GL
AD0924HB-A70GL
    ADDA(協禧電機)
AD0924HB-A70GL 数据手册
ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 20 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0912MX-C70 AD0912HX-C70 AD0912HX-C7 AD0912MB-C70 AD0912MB-C71 AD0912MB-C72 AD0912MB-C76 AD0912HB-C70 AD0912HB-C71 AD0912HB-C72 AD0912MS-C70 AD0912MS-C71 AD0912HS-C70 AD0912HS-C71 AD0912HS-C76 AD0924MX-C70 AD0924HX-C70 AD0924MB-C70 AD0924MB-C71 AD0924HB-C70 AD0924HB-C71 AD0924HB-C73 AD0924MS-C70 AD0924MS-C71 AD0924HS-C70 AD0924HS-C71 AD0912DX-A70GL AD0912DX-A71GL AD0912LX-A70GL AD0912LX-A72GL AD0912LX-A76GL AD0912MX-A70GL AD0912HX-A70GL AD0912HX-A76GL AD0912UX-A71GL AD0912UX-A76GL AD0912DB-A71GL AD0912LB-A70GL AD0912LB-A702GL AD0912LB-A76GL AD0912MB-A70GL AD0912MB-A76GL AD0912HB-A70GL AD0912HB-A76GL HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL S S S S S HYPRO HYPRO BALL BALL BALL BALL BALL S S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 0.16 0.25 0.25 0.16 0.16 0.16 0.16 0.25 0.25 0.25 0.16 0.16 0.25 0.25 0.25 0.10 0.14 0.10 0.10 0.14 0.14 0.14 0.10 0.10 0.14 0.14 0.09 0.07 0.12 0.13 0.13 0.17 0.25 0.25 0.39 0.30 0.07 0.13 0.12 0.12 0.17 0.17 0.25 0.25 1.92 3.00 3.00 1.92 1.92 1.92 1.92 3.00 3.00 3.00 1.92 1.92 3.00 3.00 3.00 2.40 3.36 2.40 2.40 3.36 3.36 3.36 2.40 2.40 3.36 3.36 1.08 0.84 1.44 1.56 1.56 2.04 3.00 3.00 4.68 3.60 0.84 1.56 1.44 1.44 2.04 2.04 3.00 3.00 2430 2740 2740 2430 2430 2430 2430 2740 2740 2740 2430 2430 2740 2740 2740 2430 2740 2430 2430 2740 2740 2740 2430 2430 2740 2740 1600 1600 2100 2200 2000 2400 2700 2700 3200 3300 1600 2050 2300 2300 2600 2600 2900 2900 29.0 32.8 32.8 29.0 29.0 29.0 29.0 32.8 32.8 32.8 29.0 29.0 32.8 32.8 32.8 29.0 32.8 29.0 29.0 32.8 32.8 32.8 29.0 29.0 32.8 32.8 28.0 28.0 37.9 35.9 32.4 43.5 50.0 50.0 57.8 60.0 28.0 36.0 41.6 41.6 47.2 47.2 52.5 52.5 0.083 0.106 0.106 0.083 0.083 0.083 0.083 0.106 0.106 0.106 0.083 0.083 0.106 0.106 0.106 2.110 0.106 0.083 0.083 0.106 0.106 0.106 0.083 0.083 0.106 0.106 0.060 0.060 0.073 0.097 0.054 0.094 0.117 0.117 0.158 0.166 0.060 0.063 0.087 0.087 0.108 0.108 0.133 0.133 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 28.9 32.8 32.8 28.9 28.9 28.9 28.9 32.8 32.8 32.8 28.9 28.9 32.8 32.8 32.8 28.9 32.8 28.9 28.9 32.8 32.8 32.8 28.9 28.9 32.8 32.8 22.0 22.0 26.5 29.3 23.5 31.3 33.7 33.7 38.6 39.4 22.0 25.0 29.8 29.8 32.7 32.7 35.0 35.0 0 0 6 0 1 2 6 0,6 1 2,3 0 1 0 1 6 0,1,2,3 0 0 1 0 1 3 0 1 0 1 0 1 0 2 6 0,2,3 0,2,3 6 1,2 6 1 0 2,3 6 0,1,2,3 6 0,1,2,3 6 TUV,CSA,CE UL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE TUV,CE CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE TUV,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE CE UL,CUL,TUV,CSA,CE TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,TUV,CSA,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE 85 85 85 85 85 85 85 85 85 85 85 85 85 85 85 78 85 85 85 85 85 85 85 85 85 85 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 41.30 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 92 X 92 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD0912UB-A71GL AD0912UB-A76GL AD0912XB-A71GL AD0912DS-A70GL AD0912DS-A71GL AD0912LS-A70GL AD0912LS-A73GL AD0912LS-A76GL AD0912MS-A70GL AD0912MS-A76GL AD0912HS-A70GL AD0912HS-A76GL AD0912US-A70GL AD0912US-A71GL AD0912US-A76GL AD0924LX-A70GL AD0924MX-A70GL AD0924MX-A71GL AD0924HX-A70GL AD0924UX-A71GL AD0924UX-A73GL AD0924LB-A70GL AD0924LB-A72GL AD0924LB-A76GL AD0924MB-A70GL AD0924HB-A70GL AD0924HB-A76GL AD0924UB-A72GL AD0924XB-A71GL AD0924LS-A70GL AD0924MS-A70GL AD0924HS-A70GL AD0924HS-A72GL AD0924HS-A73GL AD0924US-A70GL AD0924US-A71GL AD0924US-A72GL AD0948HB-A71GL AD0948UB-A71GL AD0948HS-A72GL AD1212LX-A71GL AD1212LX-A72GL AD1212MX-A71GL AD1212MX-A73GL BALL BALL BALL S S S S S S S S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S S S BALL BALL S HYPRO HYPRO HYPRO HYPRO 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 48 48 48 12 12 12 12 0.39 0.39 0.55 0.09 0.07 0.13 0.13 0.13 0.17 0.17 0.25 0.25 0.39 0.39 0.30 0.08 0.12 0.17 0.15 0.21 0.21 0.08 0.08 0.08 0.12 0.15 0.15 0.21 0.25 0.08 0.12 0.15 0.20 0.20 0.21 0.21 0.21 0.13 0.16 0.07 0.24 0.24 0.34 0.34 4.68 4.68 6.60 1.08 1.08 1.56 1.56 1.56 2.04 2.04 3.00 3.00 4.68 4.68 3.60 1.92 2.88 2.04 3.60 5.04 5.04 1.92 1.92 1.92 2.88 3.60 3.60 5.04 6.00 1.92 2.88 3.60 4.80 4.80 5.04 5.04 5.04 6.24 7.68 3.36 2.88 2.88 4.08 4.08 3300 3300 3800 1600 1600 2000 2100 2000 2350 2350 2700 2700 3200 3300 3300 2100 2400 2700 2700 3200 3200 2100 2300 2300 2600 2900 2900 3300 3800 2100 2400 2700 3000 3000 3300 3200 3200 2900 3300 2900 1800 1800 2050 2050 60.0 60.0 67.0 28.0 28.0 32.4 37.9 32.4 43.0 43.0 50.0 50.0 57.8 60.0 60.0 37.9 43.5 43.2 50.0 57.8 57.8 37.9 41.6 41.6 47.2 52.5 52.5 60.0 66.9 37.9 43.5 48.0 48.4 48.4 60.0 57.8 57.8 52.5 60.0 52.0 72.0 72.0 80.5 80.5 0.166 0.166 0.198 0.060 0.060 0.054 0.073 0.054 0.087 0.870 0.117 0.117 0.156 0.198 0.166 0.073 0.094 0.140 0.115 0.156 0.156 0.074 0.086 0.086 0.106 0.131 0.131 0.166 0.186 0.073 0.094 0.115 0.169 0.169 0.166 0.158 0.158 0.133 0.163 0.177 0.095 0.095 0.117 0.117 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 39.4 39.4 43.9 22.0 22.0 23.5 26.5 23.5 31.0 31.0 33.7 33.7 39.4 39.1 39.4 26.5 31.3 35.0 33.7 38.6 38.6 26.5 29.8 29.8 32.7 35.0 35.0 39.4 42.6 26.5 31.3 33.7 38.0 38.0 39.4 38.6 38.6 35.0 39.4 34.0 34.4 34.4 38.0 38.0 1,2,3 6 1 0 1 0 3 6 0,3 6 0,1,2,3 6 0 1,2 6 0 0,2 1 0 1,2 3 0 2 6 0,2 0,1,2,3 6 2 1,2 0,2 0,2 0 2 3 0 1 2 1 1 2 1 2 1 3 UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 156 156 156 156 Units Per Box Box Wt. (lbs.) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 90 90 90 90 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 25.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 52.36 30.80 30.80 30.80 30.80 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 25 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 Model Part Number Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) AD1212HX-A71GL AD1212HX-A73GL AD1212UX-A71GL AD1212LB-A71GL AD1212LB-A73GL AD1212MB-A71GL AD1212MB-A72GL AD1212MB-A73GL AD1212HB-A71GL AD1212HB-A72GL AD1212HB-A73GL AD1212UB-A71GL AD1212UB-A72GL AD1212LS-A71GL AD1212MS-A71GL AD1212MS-A72GL AD1212HS-A71GL AD1212HS-A72GL AD1212HS-A73GL AD1212HS-A74GL AD1212US-A71GL AD1224LX-A71GL AD1224MX-A71GL AD1224HX-A71GL AD1224HX-A73GL AD1224UX-A72GL AD1224LB-A71GL AD1224MB-A71GL AD1224HB-A71GL AD1224UB-A71GL AD1224UB-A72GL AD1224LS-A71GL AD1224MS-A71GL AD1224HS-A71GL AD1224HS-A73GL AD1224US-A71GL AD1248HB-A71GL AD2512LX AD2512MX AD2512LB AD2512MB AD2512MB AD2512MB AD2512HB HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S S S HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL S S S S S BALL HYPRO HYPRO BALL BALL BALL BALL BALL 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 48 12 12 12 12 12 12 12 0.44 0.44 0.50 0.24 0.24 0.33 0.33 0.33 0.37 0.37 0.37 0.50 0.50 0.24 0.34 0.34 0.44 0.44 0.44 0.40 0.50 0.14 0.20 0.24 0.24 0.25 0.14 0.17 0.19 0.25 0.25 0.14 0.20 0.24 0.24 0.25 0.25 0.15 0.60 0.15 0.60 0.60 0.60 0.65 5.28 5.28 6.00 2.88 2.88 3.96 3.96 3.96 4.44 4.44 4.44 6.00 6.00 2.88 4.08 4.08 5.28 5.28 5.28 4.80 6.00 3.36 4.80 5.76 5.76 6.00 3.36 4.08 4.56 6.00 6.00 3.36 4.80 5.76 5.76 6.00 9.60 1.80 7.20 1.80 7.20 7.20 7.20 7.80 2200 2200 2500 1800 1800 2050 2050 2050 2200 2200 2200 2500 2500 1800 2050 2050 220 220 220 2200 2500 1800 2050 2200 2200 2500 1800 2050 2200 2500 2500 1800 2050 2200 2200 2500 2200 1200 2300 1200 2300 2300 2300 2500 85.2 85.2 98.6 72.0 72.0 80.5 80.5 80.5 85.2 85.2 85.2 98.6 98.6 72.0 80.5 80.5 85.2 85.2 85.2 85.2 98.6 72.0 80.5 85.2 85.2 98.6 72.0 80.5 85.2 98.6 98.6 72.0 80.5 85.2 85.2 98.6 85.2 12.0 23.7 12.0 23.7 23.7 23.7 25.2 0.136 0.136 0.179 0.095 0.095 0.117 0.117 0.117 0.136 0.136 0.136 0.179 0.179 0.095 0.117 0.117 0.136 0.136 0.136 0.134 0.179 0.095 0.117 0.136 0.136 0.176 0.095 0.117 0.136 0.176 0.176 0.095 0.117 0.136 0.136 0.176 0.136 0.109 0.621 0.109 0.621 0.621 0.621 0.640 NOTE B=Ball S=Sleeve X= Hypro AT= Terminals AW= Wires Noise Weight (dB/A) (g) 39.1 39.1 43.3 34.4 34.4 38.0 38.0 38.0 39.1 39.1 39.1 43.3 43.3 34.4 38.0 38.0 39.1 39.1 39.1 39.1 43.3 34.4 38.0 39.1 39.1 43.3 34.3 38.0 39.1 43.3 43.3 34.4 38.0 39.1 39.1 43.3 39.1 34.3 51.1 34.3 51.1 51.1 51.1 51.0 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 158 158 158 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 156 276 276 276 276 276 276 276 Features Available Safety Approvals 1 3 1 1,2 3 1 2 3 1 2 3 1 2,3 1,3 1,3 2 1 2 3 4 1,2,3 1 1 1,2 3 2 1,2 1 1,2,3 1 2,3 1 1 1 3 1 1 0 0 0,3 0 2 3 0,3 UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE CE UL,CUL,TUV,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,CE CE TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,CE CE TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE TUV,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CE UL,CUL,TUV,CE CE CE CE TUV,CE UL,CUL,CE TUV,CE UL,CUL,TUV,CE TUV,CE CE CE Units Per Box Box Wt. (lbs.) 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 30.80 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 32 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 120 X 120 X 38 Model Part Number AD2512UB AD2512LS AD2512MS AD2512HS AD2512US AD2524MX AD2524MB AD2524HB AD2524UB AD2524MS AD2524US AD1212LX-F51 AD1212LX-F53 AD1212MX-F51 AD1212MX-F53 AD1212HX-F51 AD1212HX-F52 AD1212HX-Y51 AD1212LB-F51 AD1212LB-F52 AD1212MB-F51 AD1212MB-F52 AD1212HB-F51 AD1212HB-F52 AD1212HB-F57 AD1212HB-Y51 AD1212UB-F51 AD1212UB-F53 AD1212LS-F51 AD1212MS-F51 AD1212MS-F52 AD1212HS-F51 AD1212HS-F52 AD1212US-F51 AD1224MX-F51 AD1224HX-F51 AD1224UX-F51 AD1224UX-F52F AD1224LB-F51 AD1224MB-F51 AD1224MB-F52 AD1224MB-F54 AD1224HB-F51 AD1224HB-F52 NOTE B=Ball S=Sleeve X= Hypro Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) BALL S S S S HYPRO BALL BALL BALL S S HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL BALL BALL BALL BALL S S S S S S HYPRO HYPRO HYPRO HYPRO BALL BALL BALL BALL BALL BALL 12 12 12 12 12 24 24 24 24 24 24 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 1.00 0.15 0.60 0.65 1.00 0.40 0.40 0.43 0.50 0.40 0.50 0.24 0.24 0.35 0.35 0.50 0.50 0.40 0.24 0.24 0.35 0.35 0.50 0.50 0.50 0.40 0.07 0.07 0.24 0.35 0.35 0.50 0.50 0.70 0.23 0.32 0.40 0.40 0.14 0.23 0.23 0.23 0.32 0.32 8.00 1.80 7.20 7.80 8.00 9.60 9.60 9.80 9.80 9.60 9.80 2.88 2.88 4.20 4.20 6.00 6.00 4.80 2.88 2.88 4.20 4.20 6.00 6.00 6.00 4.80 0.84 0.84 2.88 4.20 4.20 6.00 6.00 8.40 5.52 7.68 9.60 9.60 3.36 5.52 5.52 5.52 7.68 7.68 3200 1200 2300 2500 3200 2300 2300 2500 2800 2300 2800 1950 1950 2540 2540 2800 2800 2750 1950 1950 2540 2540 2800 2800 2800 2750 3200 3200 1950 2540 2540 2800 2800 3200 2540 2800 3200 3200 1950 2540 2540 2540 2800 2800 33.1 12.0 23.7 25.2 33.1 23.7 23.7 25.2 29.4 23.7 29.4 72.3 72.3 94.0 94.0 104.8 104.8 108.0 72.3 72.3 94.0 94.0 104.8 104.8 104.8 108.0 122.0 122.0 72.3 94.0 94.0 104.8 104.8 122.0 94.0 104.8 122.0 122.0 72.3 94.0 94.0 94.0 104.8 104.8 1.121 0.109 0.621 0.640 1.121 0.621 0.621 0.640 0.800 0.621 0.800 0.135 0.135 0.244 0.244 0.270 0.270 0.215 0.135 0.135 0.244 0.244 0.270 0.270 0.270 0.215 0.394 0.394 0.135 0.244 0.244 0.270 0.270 0.394 0.244 0.270 0.394 0.394 0.135 0.244 0.244 0.244 0.270 0.270 AT= Terminals AW= Wires Noise Weight (dB/A) (g) Features Available Safety Approvals 55.8 34.3 51.1 51.0 55.8 51.1 51.1 51.0 52.5 51.1 52.5 32.9 32.9 41.0 41.0 42.8 42.8 43.3 32.9 32.9 41.0 41.0 42.8 42.8 42.8 43.3 48.0 48.0 32.9 41.0 41.0 42.8 42.8 48.0 41.0 42.8 48.0 48.0 32.9 41.0 41.0 41.0 42.8 42.8 0,2,3 0 0 0 0 0 0 0 0 0 0 1 3 1 3 1,4 2 1 1,3 2 1 2,3,4,7 1,3 2,4 7 1,3 1,2,4 3 1 1 2,3,4,7 1,4 2,3,7 1 1 1,2 1 2 1 1,3 2 4 1 2,3 CE TUV,CE TUV,CE CE CE UL,TUV,CE UL,CUL,CSA,TUV,CE CE CE UL,CSA,TUV,CE CE UL,CUL,TUV,CE CE UL,CUL,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE CSA,CE CE UL,CUL,TUV,CE UL,CE UL,CUL,TUV,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CE CSA,CE CE CE UL,CUL,CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE CSA,CE CE UL,CUL,TUV,CSA,CE UL,CUL,TUV,CSA,CE UL,CUL,CE CE UL,CUL,TUV,CE UL,CUL,TUV,CSA,CE UL,CSA,CE CSA,CE UL,CUL,TUV,CSA,CE UL,CSA,TUV,CE 276 276 276 276 276 276 276 276 276 276 276 297 297 297 297 297 297 213 297 297 297 297 297 297 297 213 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 Units Per Box Box Wt. (lbs.) 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 ALL RIGHTS RESERVED ADDA USA DC FAN SPECIFICATIONS Frame Dimensions (mm) Model Part Number 120 X 120 X 38 AD1224HB-F54 120 X 120 X 38 AD1224UB-F51 120 X 120 X 38 AD1224LS-F51 120 X 120 X 38 AD1224MS-F51 120 X 120 X 38 AD1224MS-F52 120 X 120 X 38 AD1224HS-F51 120 X 120 X 38 AD1224HS-F52 120 X 120 X 38 AD1224US-F51 120 X 120 X 38 AD1248MX-F52 120 X 120 X 38 AD1248HX-F51 120 X 120 X 38 AD1248HX-F52 120 X 120 X 38 AD1248LS-F51 120 X 120 X 38 AD1248MS-F51 120 X 120 X 38 AD1248MS-F52 120 X 120 X 38 AD1248LB-F51 120 X 120 X 38 AD1248MB-F51 120 X 120 X 38 AD1248MB-F52 120 X 120 X 38 AD1248HB-F51 120 X 120 X 38 AD1248HB-F53 120 X 120 X 38 AD1248HB-F54 120 X 120 X 38 AD1248HB-Y56 120 X 120 X 38 AD1248UB-F51 120 X 120 X 38 AD1248HS-F51 120 X 120 X 38 AD1248HS-F53 NOTE B=Ball S=Sleeve X= Hypro NOTE B=Ball S=Sleeve X= Hypro Bearing Type Volts (V) Current (A) Power (W) Speed (RPM) Air Flow (CFM) Pressure (Inches) BALL 24 0.32 7.68 BALL 24 0.40 9.60 S 24 0.14 3.36 S 24 0.23 5.52 S 24 0.23 5.52 S 24 0.32 7.68 S 24 0.32 7.68 S 24 0.40 9.60 HYPRO 48 0.14 6.72 HYPRO 48 0.20 9.60 HYPRO 48 0.20 9.60 S 48 0.10 4.80 S 48 0.14 6.72 S 48 0.14 6.72 BALL 48 0.10 4.80 BALL 48 0.14 6.72 BALL 48 0.14 6.72 BALL 48 0.20 9.60 BALL 48 0.20 9.60 BALL 48 0.20 9.60 BALL 48 0.13 6.24 BALL 48 0.23 9.80 S 48 0.20 9.60 S 48 0.20 9.60 AT= Terminals AW= Wires 2800 3200 1950 2540 2540 2800 2800 3200 2540 2800 2800 1950 2540 2540 1950 2540 2540 2800 2800 2800 2750 3200 2800 2800 104.8 122.0 72.3 94.0 94.0 104.8 104.8 122.0 94.0 104.8 104.8 72.3 94.0 94.0 72.3 94.0 94.0 104.8 104.8 104.8 108.0 122.0 104.8 104.8 0.270 0.394 0.135 0.244 0.244 0.270 0.270 0.394 0.244 0.270 0.270 0.135 0.244 0.244 0.135 0.244 0.244 0.270 0.270 0.270 0.215 0.394 0.270 0.270 AT= Terminals AW= Wires Noise Weight (dB/A) (g) 42.8 48.0 32.9 41.0 41.0 42.8 42.8 48.0 41.0 42.8 42.8 32.9 41.0 41.0 32.9 41.0 41.0 42.8 42.8 42.8 43.3 48.0 42.8 42.8 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 297 213 297 297 297 Features Available 4,7 1,2,3 1 1 2,3,4 1 2,3,4 1 2 1 2 1 1 2 1,3 1 2,3 1,2 3 4 6 1,3 1,2 3 Safety Approvals Units Per Box Box Wt. (lbs.) CSA,CE 40 UL,CUL,CE 40 UL,CUL,TUV,CE 40 UL,CUL,TUV,CSA,CE 40 CSA,CE 40 UL,CUL,TUV,CSA,CE 40 CSA,CE 40 UL,CUL,CE 40 UL,CE 40 UL,CUL,TUV,CSA,CE 40 UL,CUL,CSA,CE 40 UL,CUL,TUV,CSA,CE 40 UL,CUL,TUV,CSA,CE 40 UL,CE 40 UL,CUL,TUV,CSA,CE 40 UL,CUL,TUV,CSA,CE 40 CE 40 UL,CUL,TUV,CSA,CE 40 UL,CE 40 CE 40 CE 40 CE 40 UL,CUL,TUV,CSA,CE 40 CE 40 ALL RIGHTS RESERVED 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 33.66 ALL RIGHTS RESERVED
AD0924HB-A70GL 价格&库存
很抱歉,暂时无法提供与“AD0924HB-A70GL”相匹配的价格&库存,您可以联系我们找货
