AD0424HB-C50
AD0424HB-C50
    ADDA(協禧電機)
AD0424HB-C50 数据手册
AD4020 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve○=1B1S ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) 0.09 0.45 4200 Rated System Voltage Current Type (VDC) 5 (mm) 40x40x20 Rated Bearing AD0405DB-C50 (T1) ◎※ ● *Noise Level Weight (dB/A) (g) (CFM) (InAq) (mmAq) 0.127 4.489 0.080 2.032 17.5 30.0 AD0405LB-C50(T1) ◎※ ● 5 0.14 0.70 6200 0.198 6.999 0.165 4.191 AD0405MB-C50(T1) ◎※ ● 5 0.16 0.80 6900 0.219 7.741 0.200 5.080 33.0 AD0405HB-C50(T1) ◎※ ● 5 0.25 1.25 7800 0.249 8.802 0.280 7.112 36.0 AD0412DB-C50(T1) ◎※ ● 12 0.04 0.48 4200 0.127 4.489 0.080 2.032 17.5 AD0412LB-C50(T1) ◎※ ● 12 0.07 0.84 6200 0.198 6.999 0.165 4.191 30.0 AD0412MB-C50(T1) ◎※ ● 12 0.08 0.96 6900 0.219 7.741 0.200 5.080 33.0 AD0412HB-C50(T1) ◎※ ● 12 0.10 1.20 7800 0.249 8.802 0.280 7.112 36.0 AD0412UB-C50(T1) ◎※ ● 12 0.14 1.68 8500 0.271 9.579 0.320 8.128 37.5 AD0424DB-C50(T1) ◎※ ● 24 0.14 1.68 4200 0.127 4.489 0.080 2.032 17.5 AD0424LB-C50(T1) ◎※ ● 24 0.05 1.20 6200 0.198 6.999 0.165 4.191 30.0 AD0424MB-C50(T1) ◎※ ● 24 0.06 1.44 6900 0.219 7.741 0.200 5.080 33.0 AD0424HB-C50(T1) ◎※ ● 24 0.07 1.68 7800 0.249 8.802 0.280 7.112 36.0 28.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.000 10.0 0.068 0.136 0.204 0.272 風扇型號: 0.340 0.394 M L D H 0.315 6.0 0.236 4.0 0.157 2.0 0.079 0.0 0.0 2.4 4.8 7.2 9.6 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) U 8.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 12.0 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0424HB-C50 价格&库存
很抱歉,暂时无法提供与“AD0424HB-C50”相匹配的价格&库存,您可以联系我们找货
