AD0812LB-Y51
AD0812LB-Y51
    ADDA(協禧電機)
AD0812LB-Y51 数据手册
AD8032 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) 0.11 1.32 3000 1.120 39.578 Rated System Voltage Current Type (VDC) (mm) 80x80x32 Rated Bearing (CFM) *Noise Level Weight (dB/A) (g) (InAq) (mmAq) 0.187 4.749 35.5 36.7 AD0812LB-Y5B(N) ◎ 12 AD0812MB-Y5B (N) ◎ 12 0.16 1.92 3400 1.266 44.764 0.241 6.121 AD0812HB-Y5B (N) ◎ 12 0.19 2.28 3800 1.386 49.000 0.292 7.416 42.4 AD0812UB-Y5B (NCU) ◎ 12 0.23 2.76 4200 1.567 55.386 0.316 8.026 44.0 35.5 AD0824LB-Y53 (N) ◎ 24 0.07 1.68 3000 1.120 39.578 0.187 4.749 AD0824MB-Y53 (N) ◎ 24 0.10 2.40 3400 1.266 44.764 0.241 6.121 36.7 AD0824HB-Y53 (N) ◎ 24 0.12 2.88 3800 1.386 49.000 0.292 7.416 42.4 AD0824UB-Y53 (NCU) ◎ 24 0.15 3.60 4200 1.567 55.386 0.316 8.026 44.0 AD0848LB-Y53 ◎ 48 0.06 2.88 3000 1.120 39.578 0.187 4.749 35.5 AD0848MB-Y53 ◎ 48 0.07 3.36 3400 1.266 44.764 0.241 6.121 36.7 AD0848HB-Y53 ◎ 48 0.08 3.84 3800 1.386 49.000 0.292 7.416 42.4 AD0848UB-Y53 (CU) ◎ 48 0.11 5.28 4200 1.567 55.386 0.316 8.026 44.0 108.0 Specif ic atio ns subje ct to change wit hout notic e. Fan Performance Curve FLOWRATE(CMM) 0.000 9.0 0.339 0.678 1.017 1.356 1.695 0.354 M L H U 風扇型號: 7.2 0.283 5.4 0.212 3.6 0.142 1.8 0.071 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 12 24 36 48 60 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0812LB-Y51 价格&库存
很抱歉,暂时无法提供与“AD0812LB-Y51”相匹配的价格&库存,您可以联系我们找货
