AD1348UB-F51
AD1348UB-F51
    ADDA(協禧電機)
AD1348UB-F51 数据手册
AD12738 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Rated Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) (CFM) 0.25 3.00 2000 3.041 107.490 Bearing Rated System Voltage Current Type (VDC) (mm) *Noise Level Weight (InAq) (mmAq) (dB/A) (g) 0.162 4.114 41.0 AD1312LB-F5B ◎ 12 AD1312MB- F5B ◎ 12 0.38 4.56 2500 3.782 133.658 0.239 6.070 47.5 AD1312HB- F5B ◎ 12 0.65 7.80 2950 4.561 161.172 0.350 8.890 53.0 AD1312UB- F5B(CU) ◎ 12 1.06 12.72 3500 5.472 193.373 0.462 11.734 56.0 AD1312XB- F5B(M) ◎ 12 1.95 23.40 4100 6.413 226.628 0.557 14.147 62.0 AD1324LB- F5B ◎ 24 0.15 3.60 2000 3.041 107.490 0.162 4.114 41.0 AD1324MB- F5B ◎ 24 0.22 5.28 2500 3.782 133.658 0.239 6.070 47.5 AD1324HB- F5B ◎ 24 0.36 8.64 2950 4.561 161.172 0.350 8.890 53.0 AD1324UB- F5B(CU) ◎ 24 0.50 12.00 3500 5.472 193.373 0.462 11.734 56.0 AD1324XB-F5B(M) ◎ 24 0.94 22.56 4100 6.413 226.628 0.557 14.147 62.0 AD1324VB- F5B(M) ◎ 24 1.10 26.40 4500 6.852 242.146 0.630 16.002 64.5 AD1348LB- F5B ◎ 48 0.11 5.28 2000 3.041 107.490 0.162 4.114 41.0 AD1348MB- F5B ◎ 48 0.15 7.20 2500 3.782 133.658 0.239 6.070 47.5 AD1348HB- F5B ◎ 48 0.21 10.08 2950 4.561 161.172 0.350 8.890 53.0 AD1348UB- F5B(CU) ◎ 48 0.31 14.88 3500 5.472 193.373 0.462 11.734 56.0 AD1348XB- F5B(M) ◎ 48 0.50 24.00 4100 6.413 226.628 0.557 14.147 62.0 AD1348VB- F5B(M) ◎ 48 0.64 30.72 4500 6.852 242.146 0.630 16.002 64.5 127x127x38 370.0 Specif ic atio ns subje ct to change wit hout notic e. Fan Performance Curve FLOWRATE(CMM) 0.00 18.0 1.42 2.83 4.25 5.66 7.08 0.71 V X 15.0 0.59 U H M L *Motor protective circuit and third lead wire functions 0.47 9.0 0.35 6.0 0.24 3.0 0.12 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) 12.0 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.0 0.00 0 50 100 150 200 250 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD1348UB-F51 价格&库存
很抱歉,暂时无法提供与“AD1348UB-F51”相匹配的价格&库存,您可以联系我们找货
