AD5012HB-C71
AD5012HB-C71
    ADDA(協禧電機)
    ADDA - AD5012HB-C71 - AXIAL FAN, 50MM, 12VDC, 17.5CFM, 33.7DBA
AD5012HB-C71 数据手册
AD5020 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum AirFlow Pressure Rated Real System Voltage Current Power Speed Type (VDC) (A) (W) (rpm) (CMM) 12 0.08 0.96 3600 0.339 12.000 (mm) 50x50x20 Maximum Bearing (CFM) *Noise Level Weight (dB/A) (g) (InAq) (mmAq) 0.080 2.032 24.0 AD5012LB-C71 ◎ ● AD 5012MB-C71 ◎ ● 12 0.10 1.20 4300 0.424 15.000 0.110 2.794 29.0 AD 5012HB-C71 ◎ ● 12 0.13 1.56 5000 0.495 17.500 0.150 3.810 33.7 AD 5012UB-C71 ◎ ● 12 0.19 2.22 6000 0.566 20.000 0.210 5.334 38.4 AD 5024LB-C71 ◎ ● 24 0.06 1.44 3600 0.339 12.000 0.080 2.032 24.0 AD 5024MB-C71 ◎ ● 24 0.08 1.92 4300 0.424 15.000 0.110 2.794 29.0 AD 5024HB-C71 ◎ ● 24 0.11 2.64 5000 0.495 17.500 0.150 3.810 33.7 AD 5024UB-C71 ◎ ● 24 0.15 3.60 6000 0.566 20.000 0.210 5.334 38.4 32.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.135 0.270 0.405 0.540 STATIC PRESSURE(mmAq) 風扇型號: 0.675 0.275 M L H U 5.6 0.220 4.2 0.165 2.8 0.110 1.4 0.055 0.0 0.0 4.8 9.6 14.4 19.2 STATIC PRESSURE(InAq) 0.000 7.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 24.0 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD5012HB-C71 价格&库存
很抱歉,暂时无法提供与“AD5012HB-C71”相匹配的价格&库存,您可以联系我们找货
AD5012HB-C71
    库存:8
