AD5012MB-D70
AD5012MB-D70
    ADDA(協禧電機)
AD5012MB-D70 数据手册
AD5015 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) 0.13 0.65 3600 0.311 System Voltage Current Type (VDC) (mm) 50x50x15 Maximum Rated Model No. size Rated Bearing *Noise Level Weight (dB/A) (g) (CFM) (InAq) (mmAq) 11.000 0.070 1.778 25.0 AD5005LB-D70( T1 ) ◎※ ● 5 AD5005MB-D70 (T1) ◎※ ● 5 0.19 0.95 4300 0.367 13.000 0.100 2.540 30.0 AD5005HB-D7 1 ◎※ ● 5 0.21 1.05 4800 0.404 14.300 0.130 3.302 34.0 AD5012LB-D70( T1 ) ◎※ ● 12 0.07 0.84 3600 0.311 11.000 0.070 1.778 25.0 AD5012MB-D70 (T1) ◎※ ● 12 0.08 0.96 4300 0.367 13.000 0.100 2.540 30.0 AD5012HB-D70 (T1) ◎※ ● 12 0.11 1.32 4800 0.404 14.300 0.130 3.302 34.0 AD5012UB-D70 (T1) ◎※ ● 12 0.14 1.68 5500 0.466 16.500 0.180 4.572 37.5 AD5024LB-D71 ◎※ ● 24 0.04 0.96 3600 0.311 11.000 0.070 1.778 25.0 AD5024MB-D71 ◎※ ● 24 0.05 1.20 4300 0.367 13.000 0.100 2.540 30.0 AD5024HB-D71 ◎※ ● 24 0.06 1.44 4800 0.404 14.300 0.130 3.302 34.0 AD5024UB-D71 ◎※ ● 24 0.08 1.90 5500 0.466 16.500 0.180 4.572 37.5 AD5024XB-D7 1 ◎※ ● 24 0.10 2.40 6300 0.534 18.900 0.200 5.080 39.1 AD5024VB-D7 1 ◎※ ● 24 0.12 2.88 7000 0.631 22.300 0.268 6.807 42.3 27.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) F a n P erformance Curve FLOWRATE(CMM) 0.000 7.5 0.142 0.283 0.425 0.566 風扇型號: 0.708 0.295 V X U H 6.0 0.236 M *Motor protective circuit and third lead wire functions 4.5 0.177 3.0 0.118 1.5 0.059 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) L 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0.0 0 5 10 15 20 25 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD5012MB-D70 价格&库存
很抱歉,暂时无法提供与“AD5012MB-D70”相匹配的价格&库存,您可以联系我们找货
