AD5012HB-D71
AD5012HB-D71
    ADDA(協禧電機)
AD5012HB-D71 数据手册
研發處 研發處 2011.11.02 2011.11.02 2011.11.02 2011.11.02 簡文榮 盧廉清 莊鈺維 黃淑慧 AD5012HB-D71 DC FAN (RoHS) P.S. REV. A Y 2011.11.02 發行章 DATA-SHEET Engineering Printed On: 11/11/02 BRUSHLESS AXIAL COOLING FANS Customer : Adda Model No : AD5012HB-D71 Samples attached : Safety Approval : UL,CUL,TUV,CE Ref: (RoHS) Piece(s), TUV:EN 60950-1:2006+A11 UL:UL507 CE:EN 61000-6-1:2007 EN 61000-6-3:2007 Specifications ITEM SPECIFICATION / CONDITION DIMENSIONS : 50x50x15 BEARING TYPE : BALL RATED VOLTAGE : 12.0 VDC OPERATING VOLTAGE RANGE : 10.8 VDC - : 9.0 VDC , NORMAL REAL CURRENT : 0.11 Amp REAL POWER : 1.32 Watt RATED CURRENT : 0.17 Amp RATED POWER : 2.04 Watt RATED SPEED : 5000 AIR FLOW : 15.100 CFM (min.: 13.590 CFM) AIR FLOW : 0.427 CMM (min.: 0.384 CMM)  START-UP VOLTAGE STATIC AIR PRESSURE : 0.150 STATIC AIR PRESSURE : 3.810 mm + 13.2 10 VDC %MAX RPM ± 10 % (IN FREE AIR AT RATED VOLTAGE) (IN FREE AIR AT RATED VOLTAGE) Inch H2O (min.: 0.121 Inch H2O) mm H2O (min.: 3.086 mm H2O) (IN FREE AIR AT RATED VOLTAGE) NOISE LEVEL MOTOR PROTECTION : 31.4 : BY POLARITY PROTECTION : YES CONNECTION LEAD TYPE : WIRE, AWG# 26 LIFE EXPECTANCY : 70000 Hours at NET WEIGHT : 27 Gram. PACKING : 480 pcs. Per Export Carton. dB (A) (max.: IC 35.4 40℃ dB(A)) / 65% RH Unless otherwise stated, the relative humidity is 65%, and the temperature is 25℃ for the standard testing. Should you have any doubt, please refer to the environmental conditions specified in the 2011.11.02 acknowledgement document. 發行章 ADDA CORPORATION Model No.: AD5012HB-D71 Page 1/4 SPECIFICATION 1.0 SCOPE 1.1 If the information or other related document is inconsistent with this acknowledgement document, please refer to the acknowledge document. 1.2 This documentation defines the mechanical & electrical characteristics of DC brushless fans. 1.3 The specification of this product is described in details in the acknowledgement document. No guarantee is given to our product under the use of over specifications. 1.4 For any change or amendment to the specifications, such change will be noticed in writing beforehand. 1.5 If the product is used on the MIS system, please specify the specification in the purchase order. 2.0 MATERIAL 2.1 Frame : UL94V-0 Glass Filled polyester (P.B.T) 2.2 Fan Blade : UL94V-0 Glass Filled polyester (P.B.T) 2.3 Bearing Sys. : ( ) Sleeve, oil impregnated. (V ) Two Ball Bearing ( ) One Ball one Sleeve ( ) Hypro Bearing ( ) FDB Bearing 2.4 RoHS : (V ) YES HF : ( ) YES 3.0 DIMENSIONS & CONSTRUCTION All dimensions, Direction of rotation and air flow were specified as per drawing attached. 4.0 CHARACTERISTICS & DEFINITION 4.1 All rated characteristics were specified as per data sheet enclosed. 4.2 Rated Current:Rated Current shall be measured after 3 minutes of continuous rotation at rated voltage. 4.3 Rated Speed :Rated Speed shall be measured after 3 minutes. of continuous rotation at rated voltage. 4.4 Start Voltage :The voltage which is able to start the fan to operate by suddenly switching ’ON ’. 4.5 Input Power :Input Power shall be measured after 3 minutes of continuous rotation at rated voltage. 4.6 Locked Rotor Current:Locked current shall be measured within one minute of rotor locked, after 3 minutes of continuous rotation at rated voltage in clean air. 4.7 Air Flow & Static Pressure:The air flow data and static pressures should be determined in accordance with AMCA-210 standard or DIN24163 specification in a doublechamber testing with intake – side measurement. 4.8 Noise Level :The measurement of noise level is carried out with reference to CNS8753 in an anechoic chamber with the microphone positioned 1 meter from the air intake. Testing fan shall be hung in clean air . NOISE LEVEL MEASUREMENT Mic. 2011.11.02 Fan Direction of air flow >>>>>>>> 發行章 ADDA CORPORATION Model No.: AD5012HB-D71 Page 2/4 SPECIFICATION 5.0 MECHANICAL INSPECTION 5.1 Rotation Direction Counterclockwise when look into impeller side. 5.2 Protection All fans have integrated protection against locked rotor condition so that there will be no damage to winding or any electronic component. Restarting is automatic as soon as any constraint to rotation has been released. As fan placed at dead angle position, and the switch was changed from off to on. Restarting was automatic normal as soon as and proved that this fan is good fan. 5.3 Locked Rotor Protection No damage shall be found after 72 hours continuously at condition of rotation locked. Restarting is automatic as soon as constraint to running has been released. 5.4 Avoid the damage, check the correct voltage and proper polarity before connecting with power. 5.5 Free Drop Shock In minimum package condition, the fan should withstand drops on any three faces from a height of 30cm onto a wood board of 10mm thick. 5.6 Please do not stick a grease and/or an oil to the fan housing or blade which may have a harmful influence by a chemical reaction at high humidity. 5.7 If the fan is reinstalled, please pay special attention to the noise due to the vibration (or resonance). 5.8 During the testing of the fan, please make sure the finger guard is used for safety. 6.0 ELECTRICAL INSPECTION 6.1 Insulation Resistance Not less than 10M ohm between housing and positive end of lead wire (red) at 500V DC. 6.2 Dielectric Strength No damage should be found at 500 VAC for 60 seconds, measured with 1mA trip current between housing and positive end of lead wire. 6.3 Life Expectancy The continous duty life at given temperature after which, 90% of testing units shall still be running. 6.4 While the fan is running, do not intentionally lock the fan for a long time since the overheating of the motor produced by the long-time locking will damage the fan. 7.0 ENVIRONMENTAL 7.1 Improper use such as disassembling the fan, being covered with dust, or dipping the fan in water that results in defects is not covered in the warranty. Do not use the fan in the environment with corrosive air or liquid. 7.2 Operating Temperature / Humidity -10℃ to +70℃ at humidity 65%+/-20% RH. 7.3 Storage Temperature All function shall be normal after 500 hours storage at -40℃ to +70 ℃ with a 24 hour recovery period at room temperature. 7.4 Humidity After 96 hours, 95% RH, 40+/-2℃ per MIL-STD-202F, method 103B humidity test, the measured data on insulation resistance and dielectric strength shall meet the specificaiton. 7.5 Do not place or store the fan in the environment with high/low temperature/humidity. Do not store the fan for over 6 months; even if the fan is stored in room temperature for over 6 months, the fan may have the electric current leakage. 2011.11.02 發行章 ADDA CORPORATION Model No.: AD5012HB-D71 Page 3/4 SPECIFICATION 8.0 REMARKS 8.1 Material and construction are subject to change without advance notice. The changes should be within specification. 8.2 All fans shall meet the quality inspection under sampling plan MIL-STD-105E as follow: Critical Major Minor 9.0 0.25% 1.00% 2.50% OUTLINE STYLING & DIMENSIONS LEAD WIRES : UL 1007, AWG26 , L = 130 +/- 10 mm Red = positive ; Black = negative. 10.0 Notes: 10.1 Please do not touch and push Fan Blade with fingers or others, fan blade and ball bearings may be damaged and it causes noise defect. 10.2 Do not carry the fan by its lead wires. 10.3 lf the fan does not have the polarity protection function, the connection of the colored wires should be red + red, and black + black, or else the fan will be damaged in no time. 2011.11.02 10.4 For the models without reverse connection of polarity protection, please do not connect the lead wire in reverse 10.5 Please don't install this fan in series with 2x voltage inputs. For example, if a single fan rated at 12V, then don't install two of them in series with 24V input. 10.6.Every specific fan is designed for its certain application (project). Therefore, if you want to use this fan in other application (project), please inform ADDA first so that we can confirm whether there is any issue which might be incurred from the reason of this different application (project) or not. 發行章 ADDA CORPORATION Model No.: AD5012HB-D71 Page 4/4 2011.11.02 發行章 2011.11.02 發行章 2011.11.02 發行章
AD5012HB-D71 价格&库存
很抱歉,暂时无法提供与“AD5012HB-D71”相匹配的价格&库存,您可以联系我们找货
