AD0412LB-G70
AD0412LB-G70
    ADDA(協禧電機)
AD0412LB-G70 数据手册
AD4010 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) Rated System Voltage Current Type (VDC) (mm) 40x40x10 Rated Bearing (CFM) (InAq) (mmAq) *Noise Level Weight (dB/A) (g) AD0405DB-G70 (T) ◎※ ● 5 0.05 0.25 3300 0.093 3.300 0.044 1.117 14.0 AD0405LB-G70 (T) ◎※ ● 5 0.07 0.35 4200 0.119 4.200 0.060 1.524 21.0 AD0405MB-G70(T) ◎※ ● 5 0.11 0.55 4800 0.142 5.000 0.078 1.981 22.0 AD0405HB-G70(T) ◎※ ● 5 0.16 0.80 6000 0.175 6.200 0.100 2.540 26.0 AD0412DB-G70(T) ◎※ ● 12 0.04 0.48 3300 0.093 3.300 0.044 1.117 14.0 AD0412LB-G70(T) ◎※ ● 12 0.06 0.72 4200 0.119 4.200 0.060 1.524 21.0 AD0412MB-G70(T) ◎※ ● 12 0.06 0.72 4800 0.142 5.000 0.078 1.981 22.0 AD0412HB-G70(T) ◎※ ● 12 0.09 1.08 6000 0.175 6.200 0.100 2.540 26.0 AD0412UB-G70(T) ◎※ ● 12 0.09 1.08 6800 0.198 7.000 0.170 4.318 29.0 AD0424LB-G70(T) ◎※ ● 24 0.03 0.72 4200 0.119 4.200 0.060 1.524 21.0 AD0424MB-G70(T) ◎※ ● 24 0.04 0.96 4800 0.142 5.000 0.078 1.981 22.0 AD0424HB-G70(T) ◎※ ● 24 0.06 1.44 6000 0.175 6.200 0.100 2.540 26.0 AD0424UB-G70(T) ◎※ ● 24 0.08 1.92 6800 0.198 7.000 0.170 4.318 29.0 17.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.000 6.0 0.048 0.096 0.144 0.192 風扇型號: 0.240 0.236 M L D H *Motor protective circuit and third lead wire functions 0.189 3.6 0.142 2.4 0.094 1.2 0.047 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) U 4.8 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0.0 1.7 3.4 5.1 6.8 8.5 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0412LB-G70 价格&库存
很抱歉,暂时无法提供与“AD0412LB-G70”相匹配的价格&库存,您可以联系我们找货
