AD0912DB-A70GL
AD0912DB-A70GL
    ADDA(協禧電機)
AD0912DB-A70GL 数据手册
AD9225 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Rated Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) Bearing Rated System Voltage Current Type (VDC) (mm) (CFM) AD0912DB-A73GL(N) ◎※ ● 12 0.05 0.60 1600 0.858 30.303 (InAq) (mmAq) 0.034 0.877 *Noise Level Weight (dB/A) (g) 19.1 AD0912LB- A73GL(N) ◎※ ● 12 0.09 1.08 2300 1.245 43.993 0.093 2.370 30.0 AD0912MB- A73GL(N) ◎※ ● 12 0.14 1.68 2600 1.396 49.357 0.124 3.149 34.5 AD0912HB- A73GL(N) ◎※ ● 12 0.18 2.16 2900 1.587 56.069 0.146 3.721 37.5 AD0912UB- A73GL(N) ◎※ ● 12 0.27 3.24 3300 1.752 61.929 0.187 4.749 42.2 AD0924LB- A73GL(N) ◎※ ● 24 0.08 1.92 2300 1.245 43.993 0.093 2.370 30.0 AD0924MB- A73GL(N) ◎※ ● 24 0.09 2.16 2600 1.396 49.357 0.124 3.149 34.5 AD0924HB- A73GL(N) ◎※ ● 24 0.11 2.64 2900 1.587 56.069 0.146 3.721 37.5 AD0924UB- A73GL(N) ◎※ ● 24 0.16 3.84 3300 1.752 61.929 0.187 4.749 42.2 AD0948HB- A73GL ◎ 48 0.11 5.28 2900 1.587 56.069 0.146 3.721 37.5 92x92x25 92.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.000 6.0 0.396 0.792 1.188 1.584 風扇型號: 1.980 0.236 M L D H 0.189 3.6 0.142 2.4 0.094 1.2 0.047 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) U 4.8 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 14 28 42 56 70 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0912DB-A70GL 价格&库存
很抱歉,暂时无法提供与“AD0912DB-A70GL”相匹配的价格&库存,您可以联系我们找货
