AB3512HB-GA0
AB3512HB-GA0
    ADDA(協禧電機)
    BLOWER, 35X35X10MM, 12 VOLTS,
AB3512HB-GA0 数据手册
AB3510 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) (CFM) 0.076 0.380 5000 0.026 1.00 Rated System Voltage Current Type (VDC) (mm) 35x35x10 Rated Bearing (InAq) *Noise Level Weight (mmAq) (dB/A) (g) 2.79 30.5 31.0 AB3505LB-GA0(T) ◎ 5 AB3505MB- GA 0 (T) ◎ 5 0.090 0.450 6000 0.035 1.20 0.156 3.84 AB3505HB- GA 0 (T) ◎ 5 0.145 0.725 7000 0.041 1.40 0.200 4.98 35.0 AB3512MB- GA 0 (T) ◎ 12 0.062 0.744 6000 0.035 1.20 0.156 3.84 31.0 AB3512HB- GA 0 (T) ◎ 12 0.074 0.888 7000 0.041 1.40 0.200 4.98 35.0 0.110 16.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.011 0.023 0.034 0.045 L STATIC PRESSURE(mmAq) 4.8 0.057 0.236 M 0.189 H 3.6 0.142 2.4 0.094 1.2 0.047 0.0 STATIC PRESSURE(InAq) 0.000 6.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0.0 0.4 0.8 1.2 1.6 2.0 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AB3512HB-GA0 价格&库存
很抱歉,暂时无法提供与“AB3512HB-GA0”相匹配的价格&库存,您可以联系我们找货
