AA1752HB-AW
AA1752HB-AW
    ADDA(協禧電機)
AA1752HB-AW 数据手册
AA17251 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Bearing size Model No. System (mm) Type AA1751HB-AT 172x150X51 Freq. 230 50/60 Maximum Maximum AirFlow Pressure Current Power Speed (A) (W) (rpm) (CMM) (CFM) (InAq) 0.52/0.47 40.90/36.70 0.26/0.22 41.90/37.60 2500/2800 5.546/5.943 196.0/210.0 0.425/0.266 (VAC) (Hz) 115 ◎ AA1752HB-AT Volt. Rated (mmAq) *Noise Level Weight (dB/A) (g) 10.795/6.756 52.3/53.0 930 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) 60Hz 50Hz Fan Performance Curve Fan Performance Curve FLOWRATE(CMM) 0.846 1.692 2.538 3.384 4.230 FLOWRATE(CMM) 5.076 5.922 0.472 0.000 12.0 0.846 1.692 2.538 3.384 風扇型號: 4.230 0.236 3.0 0.0 60 90 120 150 FLOWRATE(CFM) C 180 210 9.0 0.354 6.0 0.236 0.118 3.0 0.118 0.000 0.0 STATIC PRESSURE(mmAq) 6.0 30 5.922 0.472 H 0.354 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) H 9.0 0 5.076 風扇型號: STATIC PRESSURE(InAq) 0.000 12.0 *Safety approvals 0.000 0 30 60 90 120 150 180 210 FLOWRATE(CFM) COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AA1752HB-AW 价格&库存
很抱歉,暂时无法提供与“AA1752HB-AW”相匹配的价格&库存,您可以联系我们找货
