AD0824HB-D71
AD0824HB-D71
    ADDA(協禧電機)
    0Z
AD0824HB-D71 数据手册
AD8015-7 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size (mm) 80x80x15 Rated Maximum Maximum Power Speed AirFlow Pressure (A) (W) (rpm) (CMM) 0.13 0.65 2440 0.617 21.805 Bearing Rated System Voltage Current Type (VDC) 5 (CFM) (InAq) (mmAq) 0.078 1.981 *Noise Level Weight (dB/A) (g) AD0805MB-D73(N) ◎※ ● AD0805HB-D7 3(N) ◎※ ● 5 0.22 1.10 3200 0.841 29.722 0.122 3.098 34.4 AD0812LB-D7 3(N) ◎※ ● 12 0.04 0.48 2000 0.518 18.335 0.052 1.320 18.8 AD0812MB-D7 3(N) ◎※ ● 12 0.05 0.60 2440 0.617 21.805 0.078 1.981 24.9 AD0812HB-D7 3(N) ◎※ ● 12 0.11 1.32 3200 0.841 29.722 0.122 3.098 34.4 24.9 AD0812UB-D7 3(N) ◎※ ● 12 0.16 1.92 3800 0.971 34.338 0.173 4.394 38.1 AD0824MB-D73 (N) ◎※ ● 24 0.05 1.20 2440 0.617 21.805 0.078 1.981 24.9 AD0824HB-D73 (N) ◎※ ● 24 0.08 1.92 3200 0.841 29.722 0.122 3.098 34.4 62.0 Specif ic atio ns subje ct to change wit hout notic e. The specification for bearing type is for reference only , for more bearing types information, please contact with your ADDA sales representative, thanks!! (網頁上呈現產品軸承資訊均以2Ball為主,若需其他產品資訊請聯絡您在ADDA的業務代表,謝謝!!) Fan Performance Curve FLOWRATE(CMM) 0.226 0.452 0.678 0.904 STATIC PRESSURE(mmAq) 風扇型號: 1.130 0.235 M L H U 4.8 0.188 3.6 0.141 2.4 0.094 1.2 0.047 0.0 STATIC PRESSURE(InAq) 0.000 6.0 *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.000 0 8 16 24 32 40 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD0824HB-D71 价格&库存
很抱歉,暂时无法提供与“AD0824HB-D71”相匹配的价格&库存,您可以联系我们找货
