AD17224LB-5151MO
AD17224LB-5151MO
    ADDA(協禧電機)
AD17224LB-5151MO 数据手册
AD17251 SERIES Specifications(Nominal) *:Noise is measured at the distance of one (1)meter from the axis of intake. Bearin g type: ◎=Ball ※=Sle eve ●=Hypro bearin g Frame Model No. size Maximum Maximum Power Speed AirFlow Pressure Level Weight (A) (W) (rpm) (CMM) (CFM) (InAq) (mmAq) (dB/A) (g) 12 1.65 19.80 3500 7.500 265.00 0.750 19.05 58.8 Rated System Voltage Current Type (VDC) (mm) AD17212DB5151M0(0CW) ◎ *Noise AD17212LB5151M0(0CW) ◎ 12 2.30 27.60 3900 8.350 295.00 0.890 22.60 60.6 AD17224DB5151M0(0CW) ◎ 24 0.83 19.92 3500 7.500 265.00 0.750 19.05 58.8 AD17224LB5151M0(0CW) ◎ 24 1.10 26.40 3900 8.350 295.00 0.890 22.60 60.6 AD17224MB5151M0(0CW) ◎ 24 1.45 34.80 4300 9.250 327.00 1.070 27.18 64.0 ◎ 24 1.95 46.80 4800 10.240 362.00 1.330 33.78 65.7 AD17224UB5151M0(0CW) ◎ 24 2.56 61.44 5300 11.800 417.00 1.690 42.93 67.9 AD17224HB5151M0(0CW) 172x150x51 Rated Bearing AD17248DB5151M0(0CW) ◎ 48 0.43 20.64 3500 7.500 265.00 0.750 19.05 58.8 AD17248LB5151M0(0CW) ◎ 48 0.57 27.36 3900 8.350 295.00 0.890 22.60 60.6 AD17248MB5151M0(0CW) ◎ 48 0.77 36.96 4300 9.250 327.00 1.070 27.18 64.0 AD17248HB5151M0(0CW) ◎ 48 1.05 50.40 4800 10.240 362.00 1.330 33.78 65.7 AD17248UB5151M0(0CW) ◎ 48 1.25 60.00 5300 11.800 417.00 1.690 42.93 67.9 762.0 Specif ic atio ns subje ct to change wit hout notic e. Fan Performance Curve 45.0 1.80 U 40.0 風扇型號: 1.60 M L D 35.0 1.40 H 30.0 1.20 25.0 1.00 20.0 0.80 15.0 0.60 10.0 0.40 5.0 0.20 0.0 STATIC PRESSURE(InAq) STATIC PRESSURE(mmAq) *Motor protective circuit and third lead wire functions 0 1 2 3 4 6 7 8 9 A B *Safety approvals 0.00 0 50 100 150 200 250 300 350 400 450 FLOWRATE(CFM) C COPYRIGHT 2008 ADDA CORPORATION.ALL RIGHTS RESERVED. ADDA CORPORATION AND ADDA CORPORATION LOGO ARE TRADEMARKS OR SERVICE MARKS OF ADDA CORPORATION.
AD17224LB-5151MO 价格&库存
很抱歉,暂时无法提供与“AD17224LB-5151MO”相匹配的价格&库存,您可以联系我们找货
