ECHO16/40MM/UFL/S/S/17
    SIRETTA
    SIRETTA - ECHO16/40MM/UFL/S/S/17 - Antenna, Internal Mount, UFL, 40mm
ECHO16/40MM/UFL/S/S/17 数据手册
Echo 16 18.5mm x 19mm GPS Ceramic Patch Antenna 16dB Gain Key Features • • • • • 16dB pre-amplifier Internally mounted UFL connector Ground plane independent RoHS compliant General Description Additional Considerations Siretta GPS patch antennas combine an excellent RF performance in a small form factor making them ideal for industrial and consumer equipment when combined with today’s GPS modules. • Improves signal to noise ratio for mobile applications Fitted with the latest generation preamplifier, the Echo 16 has been tuned to achieve 16dB gain for lower gain applications compared with the more standard 25dB+ gain. The gain is achieved from a current consumption between 10-14mA at 3.3V. • Meets all EU compliance criteria for electronic goods • Small size and self contained antenna ideal for space saving environments • Offers compatibility with many GPS engines • Comes with RF shielding and mounted on ground plane The Echo 16 comes with an RF shield, making it an ideal product for embedded applications and it’s built in ground plane makes it a simple to design in unit needing no additional circuitry. Supplied with 40mm co-axial cable and a UFL connector, it is an ideal antenna solution for many of today’s GPS receivers. Rev 1.2 A member of the Olancha Group Ltd Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.co.uk www.siretta.co.uk Echo 16 18.5mm x 19mm GPS Ceramic Patch Antenna 16dB Gain Key Specifications - Electrical Key Specifications - Mechanical Temperature range: Dimensions: -40 to +85°C Impedance: 50 ohm VSWR: Voltage and supply current: Operating frequency:
ECHO16/40MM/UFL/S/S/17 价格&库存
很抱歉,暂时无法提供与“ECHO16/40MM/UFL/S/S/17”相匹配的价格&库存,您可以联系我们找货
