ASMK015X174S11
ASMK015X174S11
    SIRETTA
    ASMK015X174S11
ASMK015X174S11 数据手册
About RF C a b l e s Siretta RF cable assemblies are generally used as an adaptor to connect two devices in RF signal transmission – typically a wireless module and antenna. Custom cable assemblies in 10 days Siretta is the top RF cable assembly manufacturer in the UK. We have several standard RF cable types and variations in stock. In just 10 days, we can assemble your customised requests and/or design a cable suited for your application. Meeting our customers needs For custom cables we will make a price quotation and after the price has been approved by you, we will provide technical drawings for your approval. Each RF cable assembly is 100% signal continuity tested in process and at completion. Our on-going quality control inspection guarantees every customer will receive the ultimate in quality cables. 57 RF Int e r nal C a b l e s Our Most Popular Range of RF Internal Cables Our internal RF cables are available in all cable styles as shown in the table on page 66. Some internal cables are more popular than others. The popular styles we strive to have high availability on and we are continuously manufacturing them. Other combinations are less popular but can be made quickly with low minimum order quantities. WE ONLY SUPPLY QUALITY CONNECTORS AND CABLES WITH ASSEMBLY TO MATCH AND AT A GREAT PRICE POINT. 58 RF Cables R F In t e r n a l C ab l e s Connector A Connector B Cable Type GSC / MCF SMA Female Bulkhead 0.81mm coax FME Male Bulkhead 0.81mm coax GSC / MCF 0.81mm coax GSC / MCF GSC / MCF uFL / IPEX uFL / IPEX MMCX Male RA RF Cables SMA Female Bulkead uFL / IPEX SMA Female Bulkhead 1.13mm coax 1.13mm coax RG174 Cable Length Part No 100mm ASMI010X081S11 150mm ASMI015X081S11 200mm ASMI020X081S11 100mm ASMI010Y081S11 150mm ASMI015Y081S11 200mm ASMI020Y081S11 50mm ASMI010I081S11 100mm ASMI015I081S11 150mm ASMI005I081S11 100mm ASMG010X113S11 150mm ASMG015X113S11 200mm ASMG020X113S11 300mm ASMG030X113S11 50mm ASMG010G113S11 100mm ASMG015G113S11 150mm ASMG005G113S11 100mm ASMK010X174S11 150mm ASMK015X174S11 200mm ASMK020X174S11 250mm ASMK025X174S11 59 RF Ex t ens io n C a b l e s RG58 and RG174 Standard and Low Loss Versions At Siretta we have produced a collection of off-the-shelf or short delivery RF extension cables in RG174 and RG58 standard and low-loss cable styles. These are high quality cables made to a high standard using quality components. Availability, quality and a great price point is the philosophy of Siretta RF cables. Extension cables are suitable for either direct connection to antennas that feature a pigtail and connector output - such as the Oscar range - or for extending existing cable runs to a longer distance. Our cables assemblies utilitise RG58 and RG174 cables, with a choice of SMA, FME, TNC and N-Type popular connector types. Standard cable lengths offered are 3m, 5m and 10m, although consideration should be given to minimising the overall cable length wherever possible to minimise losses. This is especially important in locations with limited reception. Please also review our low loss RF cables as we have the same philosophy of quality, availability and a great price point for this range too. 60 RF Cables The Siretta cable loss checker shows the difference in frequency loss between low loss cables, and standard RG58 cables. RF Cables 61 Lo w L oss L L C 1 00 A E x te ns i on C ab l es (RG174 replacement) Connector A Connector B SMA Male SMA Female SMA Male SMA Male SMA Male FME Male FME Female FME Female 62 FME Female MCX Male MMCX Male MCX Male FME Male MCX Male Cable Length Part No High Stock Availability 3m ASMA300B174L13 ü 5m ASMA500B174L13 ü 10m ASMA1000B174L13 3m ASMA300F174L13 ü 5m ASMA500F174L13 ü 10m ASMA1000F174L13 3m ASMA300T174L13 5m ASMA500T174L13 10m ASMA1000T174L13 3m ASMA300L174L13 5m ASMA500L174L13 10m ASMA1000L174L13 3m ASME300T174L13 5m ASME500T174L13 10m ASME1000T174L13 3m ASMF300E174L13 ü 5m ASMF500E174L13 ü 10m ASMF1000E174L13 3m ASMF300T174L13 5m ASMF500T174L13 10m ASMF1000T174L13 RF Cables L o w L oss L L C 2 0 0 A E x te ns i on C a bles (RG58 replacement) Connector A SMA Male SMA Male SMA Male FME Male TNC Male TNC Male RF Cables Connector B SMA Female FME Female N-Type Male FME Female SMA Male FME Female Cable Length Part No 3m ASMA300B058L13 5m ASMA500B058L13 10m ASMA1000B058L13 15m ASMA1500B058L13 20m ASMA2000B058L13 3m ASMA300F058L13 5m ASMA500F058L13 10m ASMA1000F058L13 15m ASMA1500F058L13 20m ASMA2000F058L13 3m ASMA300R058L13 5m ASMA500R058L13 10m ASMA1000R058L13 15m ASMA1500R058L13 20m ASMA2000R058L13 3m ASME300F058L13 5m ASME500F058L13 10m ASME1000F058L13 15m ASME15000F058L13 20m ASME2000F058L13 3m ASMZG300A058L13 5m ASMZG500A058L13 10m ASMZG1000A058L13 15m ASMZG1500A058L13 20m ASMZG2000A058L13 3m ASMZG300F058L13 5m ASMZG500F058L13 10m ASMZG1000F058L13 15m ASMZG1500F058L13 20m ASMZG2000F058L13 High Stock Availability 63 R G1 74 E xt e n si on C ab l e s Connector A Connector B SMA Male SMA Female SMA Male SMA Male SMA Male FME Male FME Female FME Female 64 FME Female MCX Male MMCX Male MCX Male FME Male MCX Male High Stock Availability Cable Length Part No 0.5m ASMA050B174S13 1m ASMA100B174S13 ü 3m ASMA300B174S13 ü 0.5m ASMA050F174S13 1m ASMA100F174S13 ü 3m ASMA300B174S13 ü 0.5m ASMA050T174S13 1m ASMA100T174S13 3m ASMA300T174S13 0.5m ASMA050L174S13 1m ASMA100L174S13 3m ASMA300L174S13 0.5m ASME050T174S13 1m ASME100T174S13 3m ASME300T174S13 0.5m ASMF050E174S13 1m ASMF100E174S13 ü 3m ASMF300E174S13 ü 0.5m ASMF050T174S13 1m ASMF100T174S13 3m ASMF300T174S13 RF Cables R G5 8 E xt e n si on C ab l e s Connector A Connector B SMA Male SMA Female SMA Male SMA Male FME Male TNC Male TNC male RF Cables Cable Length Part No High Stock Availability 3m ASMA300B058S13 ü 5m ASMA500B058S13 3m ASMA300F058S13 5m ASMA500F058S13 3m ASMA300R058S13 5m ASMA500R058S13 3m ASME300F058S13 5m ASME500F058S13 3m ASMZG300A058S13 ü 5m ASMZG500A058S13 ü 10m ASMZG1000A058S13 3m ASMZG300F058S13 5m ASMZG500F058S13 ü FME Female ü N-Type Male FME Female SMA Male ü FME Female 65 R F C able s Si z e s A Cable Type Connector types 0.81mm u.FL, IPEX, MHF2, GSC, HSSC 1.13mm Min Bend Radius B C D Dimensions (mm) Insulator Material A Core B Insulator C Shield D Jacket 3.24 0.15 0.4 0.65 0.81 PFA u.FL, GSC, IPEX, SMA, FME, SMB, TNC, TNX, MMCX 4.5 0.24 0.68 0.9 1.13 FEP 1.13mm * u.FL, GSC, IPEX, SMA, FME, SMB, TNC, TNX, MMCX 4.5 0.22 0.7 1.13 FEP 1.32mm IPEX, GSC, SMA, FME, SMB, TNC, MCX, MMCX 0.22 0.7 1.32 FEP 1.37mm u.FL, IPEX, GSC, SMA, FME, SMB, TNC, MCX, MMCX 9 0.32 0.92 1.37 FEP 1.48mm HFL, IPEX, GSC, SMA, MMCX, MCA, SMB, FME 9 0.31 0.86 1.48 FEP RG178 IPEX, MHF, MMCX, MCX, SSMB, SMA, FME 9 0.31 0.86 1.8 FEP RG316 MMCX, SMA, FME, SMB 0.53 1.53 2.53 FEP RG174 SMA, SMB, MMCX, MCX, FME, TNC, BNC 10.5 0.48 1.55 2.7 XLPE RG42 SMA 10 0.94 2.95 3.06 Solid PTFE RG58 SMA, SMB, BNC. TNC, UHF, N 20 19 x 0.18 2.95 4.95 PE Low Loss Cables LLC100A SMA, SMB, MMCX, MCX, FME, TNC, BNC 6.4 0.46 1.52 2.11 2.79 Solid PE LLC200A SMA, SMB, BNC. TNC, UHF. N 20 10.2 2.9 3.4 5 Foam PE RG213 N-type 2.3 7.24 10.3 PE 66 RF Cables PFA Cross linked poly ethylene u.FL, IPEX and GSC connectors: FEP Fluorinated ethylene propylene - similar to PTFE but flexy much higher temp before melting u.FL Four types depending on cable size. IPEX There are 4 sizes - MHF, MHF2, MHF3, MHF4 (smallest). Dictated by cable size. Std is MHF 2.5mm height. Poly Vinyl Chloride GSC Only one size. Polytetrafluoroethylene Check small connector guide details PFA PE PVC PTFE Perfluoroalkoxy - similar to PTFE but flex Polyethylene Jacket Material Loss dB/M @ 2GHz Frequency Range PFA 4.4 to 6GHz Internal antenna pigtails FEP 3.2 to 6GHz Most popular cable for internal use. Internal antenna pigtals, internal to bulkhead connector cable. FEP 2.2 to 6GHz * Low loss verison of the standard 1.13mm FEP 2.8 to 6GHz FEP 2.4 @2.5GHz to 6GHz Has same size conductor as 1.48mm and RG178 cable, but smaller overall diameter, similar cable loss but more flexible in limited space. to 6GHz 1.48mm is the most popular thin RF coaxial cable. FEP Comments FEP 2.6 @1.8GHz to 6GHz FEP 2.06 @2.4GHz to 3GHz Used internally instead of RG174. RG136 can go high temp and is more flexible. PVC 1.175 @1GHz to 6GHz This is the most popular cable for GPS and GSM antennas. Low temp spec. N/A 0.58 to 6GHz Outer jacket - tin soaked braid. Semi rigid cable PVC 1.06 @2.4GHz to 6GHz Standard RF cable for outside use. PVC 1.15 to 6GHz Low loss version of RG174 and much more flexible PVC 0.15 @200MHz to 6GHz *Low loss version of the standard RG58. PVC 0.25 @900MHz to 6GHz Low loss cable for the base station industry. RF Cables 67 sales +44 (0)118 976 9014 fax +44 (0)118 976 9020 accounts +44 (0)118 976 9069 email sales@siretta.co.uk www.siretta.co.uk Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW United Kingdom Company No. 08405712 VAT Registration No. GB163 04 0349 A member of the Olancha Group Ltd Rev 3.0
ASMK015X174S11 价格&库存
很抱歉,暂时无法提供与“ASMK015X174S11”相匹配的价格&库存,您可以联系我们找货
ASMK015X174S11
  • 1+99.906441+12.92557
  • 10+84.8953810+10.98349
  • 30+78.5623930+10.16415
  • 50+75.7811250+9.80431
  • 100+72.16390100+9.33633
  • 250+67.64882250+8.75218
  • 500+66.02597500+8.54223
ASMK015X174S11
  • 1+71.32437
  • 25+69.76230
  • 50+68.26271
库存:1
