ECHO14/200M/UFL/S/S/15
    SIRETTA
    SIRETTA - ECHO14/200M/UFL/S/S/15 - Antenna, PCB, Vertical, 4G, UFL, 0.2m
ECHO14/200M/UFL/S/S/15 数据手册
Echo 14 4G PCB Antenna Key Features • • • • • Flexible connector and cable options Groundplane independent Wide frequency range Compact size RoHS compliant General Description Additional Considerations Siretta multipurpose PCB antennas are based on an efficiently tuned element that is matched with a wide variety of RF & M2M modules operating on Cellular, 868 and 2.6GHz ISM band frequencies. It is designed for embedded applications. • Allows easy selection and quick integration into target application • Can be mounted on any surface • Works with quad band GSM / GPRS devices, 3G and 4G modules • 20 x 105mm allows easy integration into small devices • Meets all EU compliance criteria for electronic goods We are proud to present our first 4G PCB antenna, the Echo 14, measuring just 20mm x 105mm, The Echo 14 represents the latest technology, and is designed now to cover all frequencies from 800Mhz, to 2.6Ghz (4G) Already proven in many applications where space is at a premium, this product is ideal as it is ground plane independent and compact making it a popular choice where a small size combined with efficient performance is critical. Its wide ranging connector and cable options also makes it a viable antenna where a quick design in and fast time to market is important. Rev 1.1 Siretta is a division of Sequoia Technology Group Ltd Registered in England No. 4004881 VAT Registration No. GB614 5653 45 Siretta Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 info@siretta.co.uk www.siretta.co.uk Echo 14 4G PCB Antenna Key Specifications - Electrical Key Specifications - Mechanical Operating temperature range: -20 to +60°C Dimensions: Storage temperature range: -30 to +70°C Impendance: 50 ohm VSWR: Frequency: 20mm x 105mm x 1mm 3.2:1 800/900/1800/1900/ 2100MHz/ 2.6GHz Polarization: Vertical Ordering Details: Part Number Description ECHO14/200M/UFL/S/S/15 4G PCB Antenna, 200mm Cable, UFL Connector Siretta is a division of Sequoia Technology Group Ltd Registered in England No. 4004881 VAT Registration No. GB614 5653 45 Siretta Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 info@siretta.co.uk www.siretta.co.uk
ECHO14/200M/UFL/S/S/15 价格&库存
很抱歉,暂时无法提供与“ECHO14/200M/UFL/S/S/15”相匹配的价格&库存,您可以联系我们找货
