RF Cable Assembly Product Guide
Siretta RF cable assemblies are generally used as an extension to
connect two devices in RF signal transmission - typically a wireless
module and antenna.
Each RF cable assembly is 100% signal continuity tested; in process
and at completion. Our on-going quality control inspection guarantees
every customer will receive the ultimate in quality cables.
RF Cable Specifications
Type
Diameter (mm)
Min Bend
Cable
Connector types
Radius
(mm)
Insulator
Jacket
Loss dB/M @
Frequency
A
Core
B
Insulator
C
Shield
D
Jacket
Material
Material
2GHz
Range
Comments
0.81mm
u.FL, IPEX
3.24
0.15
0.4
0.65
0.81
PFA
PFA
4.4
to 6GHz
Internal antenna pigtails
1.13mm
u.FL, IPEX, SMA, FME,
SMB, TNC, MMCX
4.5
0.24
0.68
0.9
1.13
FEP
FEP
3.2
to 6GHz
Most popular cable for internal use. Internal antenna pigtails, internal to
bulkhead connector cable.
RG178
IPEX, MMCX, MCX, SMA,
FME
9
0.31
0.86
1.8
FEP
FEP
2.6 @1.8GHz
to 6GHz
RG174
SMA, SMB, MMCX, MCX,
FME, TNC
10.5
0.48
1.55
2.7
XLPE
PVC
1.175 @1GHz
to 6GHz
This is the most popular cable for GPS and GSM antennas. Low temp spec.
RG58
SMA, SMB, TNC, N-Type
19 x 0.18
2.95
4.95
PE
PVC
1.06 @2.4GHz
to 6GHz
Standard RF cable for outside use.
Low Loss Cables
LLC100A
FME, TNC
6.4
0.46
1.52
2.11
2.79
Solid PE
PVC
1.15
to 6GHz
Low loss version of RG174 and much more flexible
LLC200A
2.9
3.4
5
Foam PE
PVC
0.15 @200MHz
to 6GHz
Low loss version of the standard RG58.
FEP
PE
PFA
PTFE
PVC
XLPE
Fluorinated Ethylene Propylene
Polyethylene
u.FL and IPEX Connectors:
Perfluoroalkoxy
u.FL
Four types depending on cable size.
IPEX
There are 4 sizes - MHF, MHF2, MHF3, MHF4
(smallest). Dictated by cable size. Std is MHF
2.5mm height.
Polytetrafluoroethylene
Poly Vinyl Chloride
Cross Linked Poly Ethylene
See reverse for part numbering nomenclature.
A
+44 (0)118 976 9014
B
C
D
www.siretta.co.uk
sales@siretta.co.uk
Siretta RF Cable Assembly Part Numbering
XXX
X/XX
XXXX
X/XX
XXXX
XX
Cable Part Number
Connector 1
Cable Length
Connector 2
Cable Type
In House Use
ASM = Siretta Cable
A = SMA Male
B = SMA Female
C = SMA Male RP
D = SMA Female RP
E = FME Male
F = FME Female
G = uFL
H = Stripped and Tinned
K = MMCX Male RA
L = MMCX Male
M = SMB Female
N = N Type Female
R = N Type Male
S = SMA Male RA
T = MCX
V = Fakra Red
W = Fakra Blue
X = SMA Female Bulkhead
Y = FME Male Bulkhead
ZA = TNC Female Bulkhead
ZB = TNC Female
ZE = SMB Male Bulkhead
ZF = SMB Female Bulkhead
ZG = TNC Male
ZL = SMB Female RA
ZM = MMCX Female
0000 = Length in cm
A = SMA Male
B = SMA Female
C = SMA Male RP
D = SMA Female RP
E = FME Male
F = FME Female
G = uFL
K = MMCX Male RA
L = MMCX Male
M = SMB Female
N = N Type Female
R = N Type Male
S = SMA Male RA
T = MCX
V = Fakra Red
W = Fakra Blue
ZB = TNC Female
ZG = TNC Male
ZL = SMB Female RA
ZM = MMCX Female
ZN = SMA Female Bulkhead RP
ZS = Fakra Red Bulkhead
ZU = TNC Male RP Bulkhead
ZZ = SMB Male RA
ZY = IPEX
XΔ = SMA Female Bulkhead
with O Ring
174S = RG174 Cable
058S = RG58 Cable
113S = 1.13mm Cable
174L = LLC100 Low Loss Cable
058L = LLC200 Low Loss Cable
081S = 0.81mm Cable
178S = RG178 Cable
XX = In House Use
Assembly Parts
ZZ = SMB Male RA
ZY = IPEX
with O Ring
Example: ASM
+44 (0)118 976 9014
A
050
X
174S 11
SMA Male Connector to SMA Female Bulkhead Connector, 50cm RG174 Cable Assembly
www.siretta.co.uk
sales@siretta.co.uk
ASMA2000C058L13
SMA(M) TO SMA(M) REVERSE POLARITY 20M LOW LOSS (LLC200A) CABLE ASSEMBLY
ASMA300C058L13
SMA MALE TO SMA MALE REVERSE POLARITY 3000mm LOW LOSS RG58 CABLE
ASMA300E174L13
SMA(M) TO FME(M) 3M LOW LOSS RG174 Lifeline™ CABLE ASSY
ASMG025D11311
uFL TO SMA F BK REVERSE POLARITY 250mm 1.13 CABLE
ASMK025ZM174S11
MMCX RIGHT ANGLE TO MMCX FEMALE STRAIGHT 250MM RG174 CABLE
ASML010L178S11
MMCX StrPlug TO MMCX StrPlug 100mm RG178
ASMZG2500ZB058L13 TNC(M) TO TNC(F) 25 METRE LOW LOSS (LLC200A) CABLE ASSEMBLY
+44 (0)118 976 9014
www.siretta.co.uk
sales@siretta.co.uk
很抱歉,暂时无法提供与“ASMG025D11311”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+59.23391
- 50+58.04986
- 国内价格 香港价格
- 10+80.5286710+10.39558
