ALPHA17/2.5M/SMAM/S/S/20
    SIRETTA
    SIRETTA - ALPHA17/2.5M/SMAM/S/S/20 - Blade Antenna, 433MHz, 1.5 VSWR, 2.15dBi Gain, Vertical Polaris...
ALPHA17/2.5M/SMAM/S/S/20 数据手册
Alpha 17 433MHz ISM Flat Blade Antenna Key Features • • • • 2.15dBi peak gain Dedicated to 433MHz Mounts on any non metallic surface TETRA Compatible General Description Additional Considerations The Alpha 17 is a dedicated 433MHz ISM band antenna which combines good performance with a small size, enabling use with many of today’s remote control systems and 433MHz alarm systems. • Mounts discretely in installation, good for covert use • Meets all EU compliance criteria for electronic goods • Intended for internal equipment use Terminated with an SMA male connector, it is ideally suited to applications requiring quick antenna installation. Typical uses are alarm panel equipment, garage or gate remote controls and TETRA radio systems. The antenna has an adhesive mounting pad and can be supplied with a variety of connector types and varying cable lengths for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.0 Alpha 17 433MHz ISM Flat Blade Antenna Electrical Specifications Operating temperature range: Mechanical Specifications -20 - +65°C Impedance: 50 Ohm Gain: 2.15dBi VSWR: ≤1.5 Max input power: 60W 433MHz Polarization: Vertical L115 x W22 x H4mm Cable: RG174 Connector: SMA Male Mounting: Adhesive 22mm Frequency: Dimensions: 115mm RG174 4mm Radiation Patterns Horizontal Vertical Ordering Details Part Number Description ALPHA17/2.5M/SMAM/S/S/20 433MHz ISM Flat Blade Antenna Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.0
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离集成电路,用于红外发射和接收。
3. 引脚分配:EL817有6个引脚,分别为Vcc、Out、GND、Vo、RE和DE。
4. 参数特性:工作电压为3-15V,工作电流为10mA,响应频率为50kHz。
5. 功能详解:EL817通过红外信号实现电信号的隔离传输,具有抗干扰能力强、传输距离远等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表、通信设备等领域。
7. 封装信息:采用DIP-6封装。
ALPHA17/2.5M/SMAM/S/S/20 价格&库存
很抱歉,暂时无法提供与“ALPHA17/2.5M/SMAM/S/S/20”相匹配的价格&库存,您可以联系我们找货
  • 1+95.35951
  • 50+90.60039
  • 250+88.77796
库存:22
