DELTA1C/X/SMAM/S/S/25
    SIRETTA
    SIRETTA - DELTA1C/X/SMAM/S/S/25 - Antenna, Quad Band "Stubby", Direct Mount, SMA
DELTA1C/X/SMAM/S/S/25 数据手册
Delta 1C Quad Band “Stubby” Antenna Key Features • • • • Small size: 48mm x 8mm SMA male connector Groundplane independent RoHS compliant General Description Additional Considerations The Delta 1C is Siretta’s most compact stubby antenna, operating on quad band GSM. It combines good performance in a small size, enabling its use with many of today’s GSM / GPRS products. • Ensures antenna can be discretely mounted • Fits to many popular GSM / GPRS terminal equipment • Does not rely on mounting on metallic surface • Meets all EU compliance criteria for electronic goods Terminated with an SMA male connector, it is ideally suited to applications requiring a simple, cable free set up, such as Point of Sale, metering or alarm panel equipment; as well as being a popular addition to radio manufacturers evaluation kits. The omni directional, radiating element is over moulded in black high-grade rubber which allows flexibility and provides a rugged stylish finish, ensuring years of reliable use. The Delta 1C is a popular antenna for customers requiring a straightforward to fit, versatile product, that is qualified and used with many of today’s GSM & GPRS terminals and manufacturers of wireless communication equipment. Siretta is a division of Sequoia Technology Group Ltd Registered in England No. 4004881 VAT Registration No. GB614 5653 45 Rev 1.0 Siretta Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 info@siretta.co.uk www.siretta.co.uk Delta 1C Quad Band “Stubby” Antenna Key Specifications - Electrical Key Specifications - Mechanical Operating temperature: -45 to +75 °C Dimensions: Temperature range: -45 to +75 °C Connector: Impedance: 50 ohm Gain: 2.15dBi Voltage and supply current: Passive Operating frequences: 48mm x 8mm SMA male Mounting method: Direct connect 890 - 960MHz @
DELTA1C/X/SMAM/S/S/25 价格&库存
很抱歉,暂时无法提供与“DELTA1C/X/SMAM/S/S/25”相匹配的价格&库存,您可以联系我们找货
