ADAPT/SMAM/SMAM
ADAPT/SMAM/SMAM
    SIRETTA
    ADAPT/SMAM/SMAM
ADAPT/SMAM/SMAM 数据手册
Antennas, RF Cables & Adaptors a i r CONNECT A n t e n n a M o u n t i n g Sty le s Siretta antennas started as a necessity – they say that necessity is the mother of invention – so it was with Siretta and antennas. With many years of wireless knowledge and ‘know-how’ in designing Cellular and related wireless data modems and routers, having to add antennas proved difficult. It’s somewhat a black art and we found very few suppliers of antennas and those that there were did not know the ‘art’ and could not advise beyond their ‘odd’ part number and a long lead time. Consequently, we grasped the nettle ten years ago and set about ‘making life easier’ for us and our customers by designing our own and understanding the performance of them. That’s the history of our antenna range – probably the widest range – where the use and performance of each antennas is clear and with test figures to demonstrate. We have also created a part number system that describes each antenna accurately and is easily remembered. ‘An antenna is just a piece of wire….’ The notion that we find many people have is that an antenna is just a convenient sized piece of wire in air. We would love that to be the case, however the reality of wireless is that antennas have to conform to a set of physics suitable to the application that they are to be used in. It is the understanding of the physics of what is required in an antenna, coupled with the equipment it is to be used with, that needs careful consideration before the overall equipment design is done. Why doesn’t my antenna work well?? - this is a very common question for us and as the ‘black art’ that it is the reasons could be manifold. But central to the question is generally a few considerations that will ensure the right type of antenna is used for the design – or modification of the design to accommodate the limitations or characteristics of the chosen antenna. Our success in Antenna design and supply is the unbeatable combination of advising customers on antenna selection or customized antenna design and how to use them – and also offering volume supply via our distributors at an unbeatable price. 2 C u s tomer S e r v i c e s We w a n t to t alk t o you abou t your antennas… Technical and solution advice… Whether you want to find out why your current antenna solutions is not working the way you think it should or to ask us about an antenna solution for a new project you are working on - we welcome your call. Competitive products….. Put us to the test on how competitive we are for our quality antennas and RF cables – call us with your product requirement for a quote – whether you want technical advice or not. Antenna and RF cable hotline… +44 (0)118 976 9014 Broc hure C o n t e n t s airCONNECT Antennas About airCONNECT Antennas airCONNECT Antenna Ranges Breakdown of airCONNECT Antennas by Range 7 8 GSM / UMTS / LTE 19 GPS / GLONASS 33 Combined GSM / GPS & WiFi 37 ISM Bands 41 WiFi / Bluetooth 47 RF Cables About RF Cables RF Internal Cables Our Most Popular Range of RF Internal Cables RF Extension Cables Our Most Popular Range of RF Extension Cables RF Cable Sizes 57 58 60 66 For more information contact: +44 (0)118 976 9014 RF Connectors & Adaptors About RF Connectors & Adaptors RF Connectors Our Most Popular Range of RF Connectors RF Adaptors Our Most Popular Range of RF Adaptors For more information contact: +44 (0)118 976 9014 69 70 71 About airC O N N E C T A n t e n n a s Siretta is the partner of choice when it comes to advice and supply of quality antenna systems and solutions. Our airCONNECT antenna solutions are tested for high performance and have proven endurance when used in service. All antennas can be customized to individual customer requirements The airCONNECT range offers the largest range of high performance antennas operating at the widest range of frequencies - 2G, 3G, 4G, WiFi, GPS, Bluetooth, ISM. For more information contact: +44 (0)118 976 9014 7 ai r CONNECT A n t e n n a M o u n t i n g Sty le s To simplify selection and to aid identification we have organised our antennas into different physical mounting ranges and given them an easily remembered name: ALPHA Self-adhesive range of antennas, great for attaching anywhere you wish. Alpha antennas can be for inside mounting or external – open to the elements - mounting depending on actual type. DELTA Direct connect antennnas with no cable. These can be miniature antennas to large knuckle jointed or flexi whip antennas but they all connect directly with your equipment. ECHO ECHO antennas are embedded types that are either placed on your PCB or within your equipment’s enclosure. Mostly PCB or ceramic types. MIKE MIKE antennas have a magnetic base range and can be used for any temporary application or where ‘re-siting’ the antenna is important. OSCAR OSCAR antennas are wall mounted or pole mounted external antennas and comprise omni, dipole and yagi types. TANGO TANGO antennas are through hole mounted antennas with a stud and nut, suitable for most external applications where an antenna has to be fitted to a panel or equipment box. Within these ranges you will find different variations of antennas including sizing and frequencies. See Antenna finder for frequency band way of selecting an antenna. All of our antennas can be customized to fit your requirements, whether it is changing the connector type or increasing the length of cable or other element of the design – Siretta are here to help. 8 Antenna Finder Al p h a R a n g e - Self Adh es ive Antenna GSM UMTS LTE GPS ISM WiFi • • • • • • Combined Alpha 1A Page/s 19 47 Alpha 3A 19 47 Alpha 4A • 33 Alpha 6 • • • 37 • • • 37 Alpha 7 Alpha 8 • • 19 • 41 Alpha 9 • • • 37 Alpha 10 • 47 Alpha 11 • • • • • • • • • Alpha 14 Alpha 15 20 20 41 20 41 9 Antenna Finder Antenna GSM UMTS LTE GPS ISM WiFi Combined Page/s Alpha 16 • 48 Alpha 18 GPS Active • Antenna Specification (Model NO.:RY-GPS-11) • 21 Alpha 19 • Alpha 20 900/1800MHz/2.1GHz Adhesive Mount Narrow Flat Blade Antenna Alpha 20 (1) Dieletric Antenna Center Frequency V.S.W.R Band Width Impendence Peak Gain Gain Coverage Polarization 33 Key Features • Blade dimensions: 106 x 14.8 x 5mm • RoHS compliant • 3dB gain • Quad band cellular and 2.1GHz 50 ohm >1dBic Based on 7×7cm ground plane • Mounts on any non metallic surface >-4dBic at –90°<0<+90°(over 75% Volume) • Adhesive RHCP • Narrower blade than most 1575.42MHz±3 MHz 1.5:1 ±5 MHz • • 21 (2) LNA/Filter LNA Gain (Without cable) 26dB Typical Noise Figure 1.5dB Filter Out Band Attenuation (f0=1575.42 MHZ) 7dB Min f0+/-20MHZ ; 20dB Min f0+/-50MHZ; General Description Additional Considerations 30dB Min f0+/-100MHZ V.S.W.R <2.0 • Mounts discretely in installation, good for covert use The Siretta Alpha 20 GSM and 3G 3.0V to 5.0V antenna isDCa Voltage small dimension blade • Operates on all cellular networks and 3G DC Current antenna with a width of 14.8mm11mA Max Alpha 40 • - smaller than most popular blade anntenas. • • 21 • Meets all EU compliance criteria for electronic goods • Intended for internal to equipment use The Alpha(3)Mechanical 20 is a competant performer at 3dBi gain for GSM. It is also a robust design, waterproof and at home in most environments. The Alpha 20 will suit the cost conscious volume applications where a quality product and good performance are required.  1      Antenna  With an endfed cable and measuring 106 x 14.8mm this version comes with its own adhesive mounting pad and is available with any length cable and connectors. See popular types over page.  Del t a R a n g e - D i rect Co n n ect GSM UMTS LTE  GPS ISM WiFi Combined Page/s    Delta 1A A member of the Olancha Group Ltd • Registered in England No. 08405712 VAT Registration No. GB163 04 0349 • Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW 22 sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.co.uk www.siretta.co.uk 42 Rev 1.0 Delta 1C • 22 Delta 2A • 22 • 42 Delta 2C • 23 Delta 5 • 10 42 Antenna Finder Antenna GSM UMTS LTE GPS ISM WiFi Combined Page/s Delta 5A • 43 Delta 6A • • 23 Delta 6B • 48 • 48 • 49 Delta 6C Delta 7A Delta 7B • • 23 Delta 8A • 49 • 49 Delta 10A Delta 11 • 43 • 43 • 44 Delta 12 Delta 12A 11 Antenna Finder Antenna GSM UMTS LTE GPS ISM WiFi Combined Page/s Delta 12B • 44 • 44 Delta 12C Delta 14 • 50 • 50 Delta 15 Delta 40 • • • 24 • • • 24 Delta 41 Echo Ra n g e - Embedded Antenna GSM UMTS • • • • LTE GPS ISM WiFi Combined Page/s Echo 1A 24 Echo 2 25 • • 45 50 Echo 5 • 33 Echo 11 • 12 51 Antenna Finder Antenna GSM UMTS • • • • LTE GPS ISM WiFi Combined Page/s Echo 12 25 Echo 14 • 25 • 45 Echo 17 • 51 • 51 Echo 18 Echo 19 • 34 • 34 • 34 Echo 26 Echo 27 Echo 28 • 52 • 52 Echo 29 Echo 30 • • 26 Echo 32 • 35 13 Antenna Finder Mik e R a n g e - Ma g n et ic M o u n t Antenna GSM UMTS • • LTE GPS ISM WiFi Combined Page/s Mike 1A 26 Mike 1B • • 45 Mike 2A • • 26 Mike 3A • 35 Oscar R a n g e - Wall M o u n t Antenna GSM UMTS • • LTE GPS ISM WiFi Combined Page/s Oscar 1A 27 Oscar 3A • 27 Oscar 17 • • • • • • 27 Oscar 18 • 28 52 Oscar 20 14 • 28 Antenna Finder Antenna GSM UMTS LTE GPS ISM WiFi • • • • • • • • Combined Oscar 40 Page/s 28 53 Oscar 41 28 53 Tan g o R a n g e - T h rou g h Hole Antenna GSM UMTS LTE GPS ISM WiFi Combined Page/s • • 29 • • 29 Tango 1 Tango 3 Tango 6A • • • • • 38 • 38 Tango 6B • Tango 11A • • 30 • • 30 Tango 14 Tango 15 • • • 38 • • • 39 Tango 16 15 Antenna Finder Antenna GSM UMTS LTE GPS GNSS ISM WiFi Combined Page/s • • 30 • • 31 Tango 17 Tango 18 Tango 19 • • • 39 Tango 20 • 35 Tango 20A • • 36 Tango 21 • 36 Tango 22 • • • • • 39 Tango 23 • 53 • 54 • 54 • 54 Tango 24 Tango 25 Tango 25A 16 Antenna Finder Antenna GSM UMTS LTE GPS ISM WiFi Combined Page/s Tango 26 • 55 Tango 27 • • 31 • • 31 Tango 33 Tango 34 • 53 ognaT 32 .DTL ,.OC LLEC-ORP annetnA tnuoM eloH hguorhT zHG5384.2 - 4.2 noitartsullI D3 Tango 35 • lacinahceM - snoitacfiicepS yeK lacirtcelE - snoitacfiicepS yeK Tango 40 mm55 x 59ø :snoisnemiD 51 ± g011 :thgieW 001-ORP m1 C°06+ ot 03- :erutarepmet gnitarepO 5 ± mho05 :elbaC 0.2≤ SR elaM AMS :rotcennoC iBd5 SBA :emodaR :lairetaM :ecnadepmI :RWSV :niaG zHG5384.2 - 4.2 :egnar ycneuqerF .DTL ,.OC LLEC-ORP etihW :roloC )fooR / eloH( wercS :gnitnuoM °6.16 :E / °6.97 :H :htdiw maeB W01 :gnildnah rewoP ralucriC / lacitreV 59Ø 0.1 veR selas xaf liame bew dtL atteriS daoR ekotsgnisaB dooW srecnepS gnidaeR WP1 7GR erihskreB • • 32 • • • 32 .DTL ,.OC LLEC-ORP 7/3 :snoitacificepS lacidrtLtcpueorlGEahcnalO eht fo rebmem A Tango 43 zHG5384.2~4.2 0.2 ≤ : egnaR ycn2e17u5q04e8r0F.oN dnalgnE ni deretsigeR 9430 40 361BG .oN noitartsigeR TAV : RWSV Ω5 ± Ω05 iBd5 ralucriC/lacitreV ttaW 01 °6.16 :E / °6.97 :H SR ELAM AMS ℃06+~℃03M1 001-ORP SBA:emodaR mm 55*59Ø • :noitaziraloP .C.O.R .nawiaT ,nauyoaT ,gnaisH nauy-aT ,daoR iJ-ouG ,1.ceS ,331 enaL ,6.oN 9828583-3-688+ :xaF 8828583-3-688+ :leT wt.moc.annetna.www//:ptth wt.moc.annetna@selas :liam-E Tango 41 4109 679 811)0(44+ 0209 679 811)0(44+ ku.oc.atteris@selas ku.oc.atteris.www 55 : ecnadepmI : niaG drawroF : noitaziraloP : gnildnaH rewoP : HTDIW MAEB • • 40 • 40 :snoitacificepS lacinahceM Tango 44 : rotcennoC : pmeT noitarepO : htgneL & elbaC : lairetaM : )H*W*L( noisnemiD g51 ± g011 ETIHW .C.O.R .nawiaT ,nauyoaT ,gnaisH nauy-aT ,daoR iJ-ouG ,1.ceS ,331 enaL ,6.oN 9828583-3-688+ :xaF 8828583-3-688+ :leT wt.moc.annetna.www//:ptth wt.moc.annetna@selas :liam-E : thgieW : roloC .DTL ,.OC LLEC-ORP • • 7/2 17 Learn more about our antennas at www.siretta.co.uk/antennas or call us on +44 (0)118 976 9014 GSM / UMTS / LTE ADHESIVE Alpha 1A - T-Bar Antenna Frequencies 850, 900, 1800, 1900MHz, 2.1, 2.4GHz Operating temp -40 to +85°C Impedance 50 ohm Gain 2dBi VSWR 2 max Polarization Vertical Size 130 x 11 x 4mm Cable RG174 Cable length and connector as required ADHESIVE Alpha 3A - Small Flat Blade Antenna Frequencies 850, 900, 1800, 1900MHz, 2.1, 2.4GHz Operating temp -40 to +85°C Impedance 50 ohm Gain 2.15dBi VSWR
ADAPT/SMAM/SMAM 价格&库存
很抱歉,暂时无法提供与“ADAPT/SMAM/SMAM”相匹配的价格&库存,您可以联系我们找货
ADAPT/SMAM/SMAM
    • 1+49.30952
    • 10+45.36268
    • 25+39.99955
    库存:75
