ASMA300E058S13
ASMA300E058S13
    SIRETTA
    CABLE ASSY SMA-FME PLUG-PLUG 3M
ASMA300E058S13 数据手册
RF Cable Assembly Product Guide Siretta RF cable assemblies are generally used as an extension to connect two devices in RF signal transmission - typically a wireless module and antenna. Each RF cable assembly is 100% signal continuity tested; in process and at completion. Our on-going quality control inspection guarantees every customer will receive the ultimate in quality cables. RF Cable S pe c ifi c at i o ns Diameter (mm) Min Bend Radius (mm) A Core B Insulator C Shield D Jacket u.FL, IPEX 3.24 0.15 0.4 0.65 1.13mm u.FL, IPEX, SMA, FME, SMB, TNC, MMCX 4.5 0.24 0.68 0.9 RG178 IPEX, MMCX, MCX, SMA, FME 9 0.31 RG174 SMA, SMB, MMCX, MCX, FME, TNC 10.5 RG58 SMA, SMB, TNC, N-Type Cable Type Connector types 0.81mm Insulator Material Jacket Material Loss dB/M @ 2GHz Frequency Range Comments 0.81 PFA PFA 4.4 to 6GHz Internal antenna pigtails 1.13 FEP FEP 3.2 to 6GHz Most popular cable for internal use. Internal antenna pigtails, internal to bulkhead connector cable. 0.86 1.8 FEP FEP 2.6 @1.8GHz to 6GHz 0.48 1.55 2.7 XLPE PVC 1.175 @1GHz to 6GHz This is the most popular cable for GPS and GSM antennas. Low temp spec. 20 19 x 0.18 2.95 4.95 PE PVC 1.06 @2.4GHz to 6GHz Standard RF cable for outside use. Low Loss Cables LLC100A SMA, SMB, MMCX, MCX, FME, TNC 6.4 0.46 1.52 2.11 2.79 Solid PE PVC 1.15 to 6GHz Low loss version of RG174 and much more flexible LLC200A SMA, SMB, TNC, N-Type 20 10.2 2.9 3.4 5 Foam PE PVC 0.15 @200MHz to 6GHz Low loss version of the standard RG58. FEP PE PFA PTFE PVC XLPE A +44 (0)118 976 9014 B C Fluorinated Ethylene Propylene Polyethylene u.FL and IPEX Connectors: Perfluoroalkoxy u.FL Four types depending on cable size. IPEX There are 4 sizes - MHF, MHF2, MHF3, MHF4 (smallest). Dictated by cable size. Std is MHF 2.5mm height. Polytetrafluoroethylene Poly Vinyl Chloride Cross Linked Poly Ethylene See reverse for part numbering nomenclature. D www.siretta.co.uk sales@siretta.co.uk Siretta RF Cable Assembly Part Numbering XXX X/XX XXXX X/XX XXXX XX Cable Part Number Connector 1 Cable Length Connector 2 Cable Type In House Use ASM = Siretta Cable Assembly Parts A = SMA Male B = SMA Female C = SMA Male RP D = SMA Female RP E = FME Male F = FME Female G = uFL H = Stripped and Tinned K = MMCX Male RA L = MMCX Male M = SMB Female N = N Type Female R = N Type Male S = SMA Male RA T = MCX V = Fakra Red W = Fakra Blue X = SMA Female Bulkhead Y = FME Male Bulkhead ZA = TNC Female Bulkhead ZB = TNC Female ZE = SMB Male Bulkhead ZF = SMB Female Bulkhead ZG = TNC Male ZL = SMB Female RA ZM = MMCX Female ZN = SMA Female Bulkhead RP ZS = Fakra Red Bulkhead ZU = TNC Male RP Bulkhead ZZ = SMB Male RA ZY = IPEX XΔ = SMA Female Bulkhead with O Ring 0000 = Length in cm A = SMA Male B = SMA Female C = SMA Male RP D = SMA Female RP E = FME Male F = FME Female G = uFL H = Stripped and Tinned K = MMCX Male RA L = MMCX Male M = SMB Female N = N Type Female R = N Type Male S = SMA Male RA T = MCX V = Fakra Red W = Fakra Blue X = SMA Female Bulkhead Y = FME Male Bulkhead ZA = TNC Female Bulkhead ZB = TNC Female ZE = SMB Male Bulkhead ZF = SMB Female Bulkhead ZG = TNC Male ZL = SMB Female RA ZM = MMCX Female ZN = SMA Female Bulkhead RP ZS = Fakra Red Bulkhead ZU = TNC Male RP Bulkhead ZZ = SMB Male RA ZY = IPEX XΔ = SMA Female Bulkhead with O Ring 174S = RG174 Cable 058S = RG58 Cable 113S = 1.13mm Cable 174L = LLC100 Low Loss Cable 058L = LLC200 Low Loss Cable 081S = 0.81mm Cable 178S = RG178 Cable XX = In House Use Example: ASM A 050 X 174S 11 - SMA Male Connector to SMA Female Bulkhead Connector, 50cm RG174 Cable Assembly +44 (0)118 976 9014 www.siretta.co.uk sales@siretta.co.uk
ASMA300E058S13 价格&库存
很抱歉,暂时无法提供与“ASMA300E058S13”相匹配的价格&库存,您可以联系我们找货
