ALPHA16/3M/SMAM/S/RP/17
    SIRETTA
    SIRETTA - ALPHA16/3M/SMAM/S/RP/17 - Plate Antenna Antenna, 2.4GHz to 2.483GHz, 2 VSWR, 2dBi Gain, 50...
ALPHA16/3M/SMAM/S/RP/17 数据手册
Alpha 16 2.4GHz WiFi / WLAN Adhesive Antenna Key Features • • • • 2.4GHz WiFi Antenna Miniature footprint – 39.9 x 33.5mm Adhesive Base 2dBi Gain General Description Additional Considerations The Alpha 16 is a slim, WiFi dedicated antenna. Its miniature design with a footprint size of 35.5 x 39.9mm. This antenna will fit discreetly onto most surfaces, whether that is on a work top or side of a wireless modem. It is supplied with a 3M™ adhesive base, making this antenna perfect for quick, simple installations onto a number of different surface materials such as: metal, glass, wood and plastic. • Miniature footprint size allows for internal / embedded integration • Strong adhesive base for simple installation • Omni directional radiation to ease installation • Helps to clear up WiFi dead spots The Alpha 16 is tuned to operate within the 2.4 to 2.5GHz frequencies, making this antenna perfect for WiFi, Bluetooth and Zigbee applications. The Alpha 16 achieves a reputable peak gain of 4.73dBi, helping to improve the short range signal transmission/reception of WiFi modems, Bluetooth gadgets or even low power ZigBee sensors. Custom cable lengths and alternative connector types can be supplied for volume orders. A member of the Olancha Group Ltd Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.co.uk www.siretta.co.uk Rev 1.5 Alpha 16 2.4GHz WiFi / WLAN Adhesive Antenna Electrical Specifications Operating Temperature: Mechanical Specifications -40 - +60°C Impedance: 50 Ohm Dimensions: Cable: Gain: 2dBi Connector: VSWR: ≤2.0 Mounting Frequency Range: 2400 - 2483MHz Polarization: L39.9 x W33.5 x H5.5mm RG174 SMA Adhesive Method: Linear Gain WiFi 2400MHz 4.73dBi 2500MHz 2.98dBi Ordering Details Part Number Description ALPHA16/1M/SMAM/S/RP/17 2.4GHz WIFI / WLAN ADHESIVE ANTENNA ALPHA16/3M/SMAM/S/RP/17 2.4GHz WIFI ADHESIVE ANTENNA A member of the Olancha Group Ltd Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.co.uk www.siretta.co.uk Rev 1.5
ALPHA16/3M/SMAM/S/RP/17 价格&库存
很抱歉,暂时无法提供与“ALPHA16/3M/SMAM/S/RP/17”相匹配的价格&库存,您可以联系我们找货
