AE-1500-12
AE-1500-12
    COTEK
    AE-1500-12
AE-1500-12 数据手册
AE-1500 1500W Programmable Single Output series Features: Universal AC input / Full range Programmable output Voltage (0% ~ 105%) Programmable output Current (0% ~ 105%) Forced current sharing at parallel operation Refer to pg. 5 for connection diagram) Constant current limit Selectable +5V / 0.5A or +9V / 0.3A auxiliary output Global control via RS232 Remote setting multiple PSU via RS232, RS485 & I²C Power OK signal Remote ON / OFF , Remote sense function Protection: OVP , OLP, OTP, Fan failure Built-in active PFC Function MODEL Output Input DC Voltage Rated Rated Current Current Range Rated Power Ripple & Noise (Max.) Voltage Adj. Range Voltage Tolerance Current Tolerance Line Regulation Load Regulation Setup, Rise Time Hold Up Time (Typ.) Voltage Range Frequency Range Power Factor (Typ.) Efficiency (Max.) AC Current (Max.) Inrush Current (Typ.) Leakage Current Over Load Protection Function Environment Safety & EMC Note.6 Others Note Over Voltage Over Temperature Auxiliary Power Remote ON / OFF Control Power OK Signal Output Voltage Trim Output Current Trim Parallel (Current Sharing) Working Temp. Working Humidity Storage Temp. & Humidity Temp. Coefficient Vibration Safety Standards Withstand Voltage Isolation Resistance EMI Conduction & Radiation Power Harmonic & Voltage Fluctuation and Flicker EMS Immunity Cooling Dimension (WxHxD) Packing AE-1500-12 12V AE-1500-15 15V AE-1500-24 24V AE-1500-30 30V AE-1500-36 36V AE-1500-48 48V AE-1500-60 60V 125A 100A 62.5A 50A 41.7A 31.3A 25A 0 ~ 125A 0 ~ 100A 0 ~ 62.5A 0 ~ 50A 0 ~ 41.7A 0 ~ 31.3A 0 ~ 25A 1500W 1500W 1500W 1500W 1500W 1500W 1500W 150mVp-p 240mVp-p 300mVp-p 360mVp-p 480mVp-p 600mVp-p 92% 93% Note.2 150mVp-p ±5.0% Typical adjustment by potentiometer. Via V-Adj from PSU front panel) Note.3 ±2.0% rated output voltage of single unit) ±3.0% rated output current of single unit) ±1.0% ±1.0% 800ms, 100ms at full load 14ms / 230VAC at full load Note.4 90 ~ 264VAC, 127 ~ 370VDC (Refer to de-rating curve) 47 ~ 63Hz 0.95 / 230VAC, 0.99 / 115VAC at full load 89% 90% 92% 92% 92% 18A / 115VAC, 9A / 230VAC 30A / 115VAC, 45A / 230VAC < 3.5mA / 240VAC 105% rated output power Protection type: Constant current limit Variable OVP Refer to VCI VS OVP curve.(OVP Tolerance 7%) Protection type: Latch-style (Recovery after reset AC power ON or inhibit) 85 ±5°C detect on NTC, Protection type: Auto recovery after temperature goes down Selectable +5V / 0.5A or +9V / 0.3A auxiliary output By external switch Open drain signal low when PSU turns on, Max. sink current: 20mA, Max. drain voltage: 40V. Adjustment of output voltage is between 0 ~ 105% of rated output Adjustment of output current is between 0 ~ 105% of rated output Note.5 Please refer to page 5 -25 ~ +60°C (Refer to load de-rating curve) 20 ~ 90% RH non-condensing -40 ~ +85°C, 10 ~ 95% RH ±0.02% / °C (0 ~ 50°C) 10 ~ 500Hz, 2G 10min. / 1cycle, period for 60min. each along X, Y, Z axes Compliance to IEC60068-2-6; IEC60068-2-64 Certified UL 60950-1; EN 60950-1 Note.7 I/P-O/P: 3KVAC (4242VDC), I/P-FG: 1.5KVAC (2121VDC), O/P-FG: 0.5KVAC (707VDC) I/P-O/P, I/P-FG, O/P-FG: 100M Ohms / 500VDC (25°C / 70% RH) Certified EN 55032 Certified EN 61000-3-2; EN 61000-3-3 Certified EN 55024; IEC 61000-4-2,3,4,5,6,8,11 Load and temperature control fan 127x64x280 mm / 5.00x2.52x11.02 inch 2.6kg; 6pcs / 16.6kg / 1.86CUFT 1. All parameters NOT specially mentioned are measured at 230VAC input, rated load and 25°C of ambient temperature. 2. Ripple & noise are measured at 20MHz of bandwidth by using a 12" twisted pair-wire terminated with a 0.1uF & 47uF parallel capacitor. 3. Tolerance: includes setup time tolerance, line regulation and load regulation. 4. De-rating may apply in low input voltage. Please check the de-rating curve for more details. 5. In parallel connection only one unit will operate if the total output load is less than 5% of the rated power. 6. The power supply is considered a component which will be installed into a final equipment. The final equipment must be re-confirmed that it still meets EMC directives. 7. This test is done without enclosure: I/P-O/P 4242VDC. If with enclosure: I/P-O/P 2121VDC,I/P-FG:2121VDC, O/P-FG: 707VDC REV. C4 19/01/17 1 AE-1500 series 1500W Programmable Single Output Mechanical Drawings: 14.5[0.57] Unit:mm / inch 280[11.02] 250.0[9.84] 15.0[0.59] 64[2.52] 127[5.00] 98.0[3.86] 4-M4 L=3.0[0.12]max. 313[12.32] 237.0[9.33] 2 4 6 8 10 12 14 16 18 20 22 24 34.0[1.34] 35.0[1.38] 14.5[0.57] 3 5 7 9 11 13 15 17 19 21 CN2 8-M4(Both Sides) L=3.0[0.12]max. Recommended screw length is measured from the power supply surface AC Input Terminal Pin No. Assignment Pin No. Assignment L ACL N CAN CN2 Function Description: Function Description Pin No. Function Description 1 VS+ Remote sense (+) 13 ACI I Program 2 VO+ Positive output voltage 14 GND Ground 3 VS- Remote sense (-) 15 VCI V Program Pin No. Mating Housing / Contact 4 VO- Negative output voltage 16 GND Ground 5 POK Power OK 17 AUX +5V / 0.5A or +9V / 0.3A Auxiliary power 6 GND Ground 18 GND Ground 7 PAR Parallel operation current share 19 SCL Serial Clock used in the I C interface 8 VSET Aux output setting 20 SDA Serial Data used in the I C interface +5V / 0.5A or +9V / 0.3A Auxiliary power 2 JST PHDR-24VS JST SPHD-002T-P0.5 or equivalent or equivalent 2 9 EN- Inhibit ON/OFF (-) 21 AUX 10 GND Ground 22 GND Ground 11 EN+ Inhibit ON/OFF (+) 23 RX For RS232 Receiver function 12 AUX +5V / 0.5A or +9V / 0.3A Auxiliary power 24 TX For RS232 Transmission function REV. C4 19/01/17 2 AE-1500 series 1500W Programmable Single Output LED Status: LED Status LED Signal Solid(Green) Power OK (Local mode) Solid(Orange) Power OK (Remote mode) Slow Blink(Green) Fast Blink(Red) Power Standby Over Voltage Protection ( OVP ) Solid(Red) Over Load Protection ( OLP ) Slow Blink(Red) Over Temperature Protection ( OTP ) Intermittent Blink(Red) Fan Failure Interlace Blink(Red) Power Failure *Local mode : Use ACI/VCI to control output current and voltage. Remote mode : Use RS-232 or I²C command to control output current and voltage. De-rating Curve: Load V.S I/P Voltage Load V.S Temp. 100 100 90 80 Load (%) Load (%) 80 60 70 60 40 50 20 40 -25 0 10 20 30 40 50 60 70 90 100 110 264 120 Input Voltage (Vac) Ambient Temperature (°C) CMD VS Output Curve: VCI VS OVP Curve: OVP 200% 196% 120% 114% VCI V/ K 4.5V 4.8V 4.5V (Output 100%) 0.5V 0.75V 0.75V (Output 5%) I. SDA GND RX SCL AUX GND TX AUX GND III. IC≒1mA I-Shrink MIN 1mA VCI / ACI 24 ACI VCI GND EN- EN+ AUX PAR VSET GND VS- POK GND VS+ VO- II. IC≒1mA CTRL VO+ RX TX 24 CN2 SCL AUX GND GND AUX GND SDA ACI VCI GND EN- EN+ AUX PAR VSET GND VS- POK GND VS+ VO- CN2 VO+ 23 23 To ensure the power supply output voltage and current could be accurately adjusted, please make sure to adjust the output voltage and current > 10% vs. the rated voltage and current. (e.g. for a 24V unit, please adjust the DC output voltage above 2.4V to ensure accuracy; same applies to the output current) A/D PWM IC≒1mA 220R CTRL VCI / ACI 0~5Vdc CTRL VCI / ACI R=5K Power Supply Power Supply Power Supply REV. C4 19/01/17 3 AE-1500 series 1500W Programmable Single Output Remote ON/OFF: (A) Default Setting (C) (B) AUX AUX 2KO SW EN+ 2KO AUX 2KO EN+ EN+ SW External DC source AUX (MAX=9V dc) AUX AUX AUX EN- EN- GND GND EN- Tr Ctrl sw OFF Power OFF ON GND Ctrl Power ON (A) Using internal 5V auxiliary source L Power OFF H Power ON sw OFF Power OFF ON Power ON (C) Using external voltage source (B) ON / OFF Control by NPN transistor *GND shown in above diagram is referring to the GND of CN2, not the Grounding from main power(NEG-).* Power OK Signal & Auxiliary Power Setting: *Place an additional capacitor to have a better *The grounding of "AUX" power and P.OK signal should be connected to "GND" port. If " VO-" is connected as Grounding, make sure to short the GND and VO- ports. performance of auxiliary power operation. AUX Open drain signal low when PSU turns on, Max. P.OK sink current: 20mA, Max. drain voltage: 40V. * 470μ F 16V AUX. LOAD GND Do NOT exceed 5V/0.5A or 9V/0.3A DC / DC 5V/0.5A or 9V/0.3A AUX VSET VSET Open(Default Setting) 5V 9V Short To GND GND AUX and P.OK Signal *GND shown in above diagram is referring to the GND of CN2, not the Grounding from main power(NEG-).* 1. Remote Sense 2. Local Sense (Default setting) CN2 CN2 2 VO+ - + Load VS-,VS+ Compensation Voltage < 0.5V 1 2 VS+ 1 VO+ VS+ VO- VS- VO- VS- GND POK GND POK VSET PAR VSET PAR GND EN- AUX EN+ - + GND EN- AUX EN+ GND ACI GND ACI GND VCI GND VCI GND AUX GND AUX SDA SCL SDA SCL GND AUX GND AUX TX RX TX RX 24 Load 23 24 23 REV. C4 19/01/17 4 AE-1500 series 1500W Programmable Single Output 3. Current Sharing with Remote Sensing(Parallel Connection) b a a a VS+ a b b VO+ a VO+ VS+ b VO+ VS+ b VO+ VS+ VO- VS- VO- VS- VO- VS- VO- VS- GND POK GND POK GND POK GND POK VSET PAR VSET PAR VSET PAR VSET PAR GND EN- GND EN- GND EN- GND EN- AUX EN+ AUX EN+ AUX EN+ AUX EN+ GND ACI GND ACI GND ACI GND ACI GND VCI GND VCI GND VCI GND VCI GND AUX GND AUX GND AUX GND AUX SDA SCL SDA SCL SDA SCL SDA SCL GND AUX GND AUX GND AUX GND AUX TX RX TX RX TX RX TX RX 24 23 24 23 24 23 24 23 Please connect PAR pins together for current sharing function For Series connection, make sure to isolate CN2 control signals 4. Current Sharing with Local Sensing VO+ VS+ VO+ VS+ VO+ VS+ VO+ VO- VS- VO- VS- VO- VS- VO- VS- GND POK GND POK GND POK GND POK VSET PAR VSET PAR VSET PAR VSET PAR GND EN- GND EN- GND EN- GND EN- AUX EN+ AUX EN+ AUX EN+ AUX EN+ GND ACI GND ACI GND ACI GND ACI GND VCI GND VCI GND VCI GND VCI GND AUX GND AUX GND AUX GND AUX SDA SCL SDA SCL SDA SCL SDA SCL GND AUX GND AUX GND AUX GND AUX TX RX TX RX TX RX TX RX 24 23 24 23 Please connect PAR pins together for current sharing function 24 23 24 VS+ 23 REV. C4 19/01/17 5 1500W Programmable Single Output AE-1500 series Installation Instruction: 1. Mounting Directions 1-1 Recommended standard mounting methods: (a) (b) 4-M4 L=3.0[0.12]max. 4-M4 L=3.0[0.12]max. 4-M4 L=3.0[0.12]max. 4-M4 L=3.0[0.12]max. 4-M4 L=3.0[0.12]max. Recommended screw length is measured from the power supply surface 2. Mounting Method 2-1 There are ventilating holes on the front and back side panels, do not obstruct; allow 50mm at least for air flow. 2-2 Recommended the torque of mounting screw: M4 screw: 1.27N • m (13.0kgf • cm) More than 50mm More than 50mm FAN Air flow FAN REV. C4 19/01/17 6
AE-1500-12 价格&库存
很抱歉,暂时无法提供与“AE-1500-12”相匹配的价格&库存,您可以联系我们找货
AE-1500-12
  • 1+4986.92622
库存:4
