AES-ATT-M18Q2FG-SK-G 数据手册
AT&T IoT Starter Kit
2nd generation
KIT DESCRIP TION
AT&T IoT Starter Kit (2nd Generation) provides an innovative new System-onModule IoT solution, enabling the design of cellular connected edge devices,
certified for operation in the United States. Powered by AT&T IoT services
available through Avnet, this kit provides a complete development environment
for sensor-to-cloud applications and services.
Designed to be used for both prototyping and production, the slim formfactor LTE system board is fully compliant with FCC, PTCRB, and AT&T network
certifications, thereby reducing development risk and speeding IoT deployments.
The Starter Kit features a small (79.5 mm x 30 mm) development board built
around Wistron NeWeb Corporation (WNC) M18Q2FG-1 LTE Cat-4 modem
module. The M18Q2FG-1 module provides cellular modem functionality plus user
application code support via a dedicated Arm® Cortex™-A7 processor, thus
eliminating the need for an external host processor. A rich set of embedded
system peripherals, controllable through the user’s application code, are easily
accessible through a 60-pin expansion connector or a 2x6 peripheral module
header. This enables easy system customization with application specific
sensors and I/O interfaces through the addition of user created or off-the-shelf
plug-in boards. The development board also includes an ambient light sensor,
temperature sensor, and 3-axis accelerometer for out-of-box demonstration
examples.
User application code runs directly on the M18Q2FG-1 module, leveraging the
OpenEmbedded software framework for Linux application development. A
Software Development Kit (SDK) specific to the M18Q2FG-1 module provides
the necessary API calls to access hardware peripherals and system resources.
Application code built with the SDK is loaded into the M18Q2FG-1 module
through a USB interface on the development board, eliminating the need for
external proprietary JTAG cables.
AT&T services facilitate Cloud based application development and deployment:
M2X - a cloud-based, fully managed IoT device management and time-series
data storage service for network connected devices, and Flow Designer - a visual
IoT application development and data orchestration environment, with run-time
support for complex nonstandard protocol translation, data processing and
integrations, to help developers create IoT applications fast.
FEATURE LIST
Development Board
-- North America SoC Module (M18Q2FG-1)
-- Ambient Light Sensor
-- Temperature Sensor
-- 3-Axis Accelerometer
-- USB Interface
-- 60-pin Expansion Connector (1.8V levels)
-- 2x6 Peripheral Module Connector (3.3V levels)
-- Power Regulation
Pulse Electronics LTE+GNSS and LTE Antenna
-- 2G/3G/4G MIMO
-- GNSS (GPS, Glonass)
-- Two piece, three antenna FPC assembly
-- Foldable
KIT INCLUDES
-- LTE Development Board
-- LTE and LTE+GNSS Antennas
-- SIM Card
-- USB Cable
-- Power Supply (AC to 5V DC)
TARGET APPLICATIONS
-- Cellular IoT Devices
-- Remote Access
-- Smart City
-- Smart Agriculture
-- Asset Tracking
-- Building Automation
-- Factory Automation
To purchase this kit, visit
http://cloudconnectkits.org/product/lte-starter-kit-2
WNC M18Q2FG-1 North America Module
-- Global Band Support
-- Cat-4 LTE
-- 2G/3G Fallback
-- GNSS (GPS and GLONASS)
-- Based on Qualcomm MDM9207
-- Arm Cortex-A7 Quad Core
-- Single A7 Core is Dedicated to User Application
-- Rich Peripheral Features
BLOCK DIAGRAM
FEATURED SUPPLIERS
PARTS
Part Number
Description
REL ATED PARTS
Part Number
Description
AES-ATT-M18Q2FG-M1-G
North America LTE M18Q2FG-1 Production Board (M1)
AES-ATT-M18Q-CAR-G
LTE IoT Breakout Carrier (Click Module expansion board for system-level prototyping)
W3906B0100
LTE + GNSS Antenna (certified)
W3907B0100
LTE Antenna (certified)
W6113B0100
LTE+GNSS MIMO Combo Antenna
ASP-197278-01
Samtec ERM8 Series Matching Connector (7mm mated connector height)
ASP-197278-02
Samtec ERM8 Series Matching Connector (10mm mated connector height)
ASP-197278-04
Samtec ERM8 Series Matching Connector (14mm mated connector height)
CONTACT
INFORMATION
Americas
2211 South 47th Street
Phoenix, Arizona 85034
United States of America
eval.kits@avnet.com
1-800-585-1602
Copyright © 2017 Avnet, Inc. AVNET, “Reach Further,” and the AV logo are registered trademarks of Avnet, Inc.
All other brands are the property of their respective owners. C1244r201712
Avnet
2211 S. 47th Street
Phoenix, AZ 85034
1-800-332-8638
avnet.com
AES-ATT-M18Q2FG-SK-G 价格&库存
很抱歉,暂时无法提供与“AES-ATT-M18Q2FG-SK-G”相匹配的价格&库存,您可以联系我们找货
