AF1206F3.00TM
AF1206F3.00TM
    AEM
    一次性保险丝(熔断) 3A 65V
AF1206F3.00TM 数据手册
Revision of May 2019 AirMatrix® Surface Mount Fuses AF Series, 1206 Size Features: • • • • • • • Fast acting at 250% overload current level Excellent inrush current withstanding capability Extremely thin body for space saving Much safer with wire-in-air design Fiberglass enforced epoxy fuse body Copper termination with nickel and tin plating Operating temperature range: -55°C to +125 °C (with derating) • 100% lead-free Application Fields: • • • • • Shape and Dimensions: Notebook, Ultrabook Backlight Driver DC/DC Converter Low voltage lighting power Automotive electronics Clearing Time Characteristics: Clearing Time at 25°C % of Current Rating Min. 100% 250% Unit Inch mm L 0.126 ± 0.008 3.20 ± 0.20 W 0.063 + 0.012 / -0.004 1.60 + 0.30 / -0.20 T 0.042 ± 0.006 1.08 ± 0.15 B 0.033 ± 0.012 0.85 ± 0.30 W Max. L B 4 hour 5 seconds T Agency Approval: • • Recognized Under the Components Program of Underwriters Laboratories. File Number: E232989 TUV File Number: 50425087 (1.5-8A), 50425128 (1015A) Website: www.aemchina.com & www.aemcomponents.com Revision of May 2019 AirMatrix® Surface Mount Fuses AF Series, 1206 Size Ordering Information: Nominal DCR (Ω) Nominal I2t (A2s) Agency Approval (TUV) Part Number Current Rating (A) AF1206F1.50TM 1.50 G 0.050 0.37 √ AF1206F1.60TM 1.60 T 0.043 0.52 √ AF1206F2.00TM 2.00 I 0.032 0.88 √ AF1206F2.50TM 2.50 J 0.028 1.1 √ Marking Voltage Rating ( White ) (VDC) 65 Interrupting Rating 50A@65VDC AF1206F3.00TM 3.00 K 0.022 1.9 √ AF1206F3.15TM 3.15 V 0.020 2.2 √ AF1206F3.50TM 3.50 L 0.018 2.6 AF1206F4.00TM 4.00 M 0.016 3.3 √ AF1206F5.00TM 5.00 N 0.013 5.4 √ AF1206F6.30TM 6.30 O 0.010 8.9 √ AF1206F7.00TM 7.00 P 0.0092 10.4 AF1206F8.00TM 8.00 R 0.0084 13.5 √ AF1206F10.0TM 10.0 Q 0.0050 11.2 √ AF1206F12.0TM 12.0 X 0.0041 15.0 AF1206F15.0TM 15.0 Y 0.0035 24.5 32 50A@32VDC 1. Resistance is measured at ≤10% of rated current and 25℃ ambient. 2. Melting l2t is calculated at 0.001 second pre-arcing time. Website: www.aemchina.com & www.aemcomponents.com √ Revision of May 2019 AirMatrix® Surface Mount Fuses AF Series, 1206 Size 15.0A 12.0A 10.0A 8.00A 7.00A 6.30A 5.00A 4.00A 3.50 A 3.15 A 3.00 A 2.50 A 2.00 A 1.60 A 1.50 A Average Pre-arcing Time Curves: 10 Pre-arcing Time (s) 1 0.1 0.01 0.001 0.0001 1 10 100 Current (A) Website: www.aemchina.com & www.aemcomponents.com 1000 Revision of May 2019 AirMatrix® Surface Mount Fuses AF Series, 1206 Size Average I2t vs. t Curves: 15.0A 12.0A 10.0A 8.00A 7.00A 6.30A 5.00A 4.00A 3.50A 3.15A 3.00A 2.50A 2.00A 1.60A 1.50A 10000 I2t (A2s) 1000 100 10 1 0.1 0.0001 0.001 0.01 0.1 1 Time (s) Website: www.aemchina.com & www.aemcomponents.com 10 Revision of May 2019 AirMatrix® Surface Mount Fuses Product Identification: AF2 1.00 V125 T M (1) (2) (3) (4) (5) (1) Series Code: AF2 (2) Current Rating Code: 1.00—1.00A (3) Voltage Rating Code: V125—125VDC (4) Package Code: T - Tape & Reel, B - Bulk (5) Marking Code: M - With Marking AF 1206 F 2.00 T M (1) (2) (3) (4) (5) (6) (1) Series Code: AF—AF Series, MF—MF Series (2) Size Code: Standard EIA Chip Sizes (3) Time/Current Characteristic: F (4) Current Rating: 2.00—2.00A (5) Package Code: T - Tape & Reel, B - Bulk (6) Marking Code: M - With Marking Recommended Land Pattern: AF2 AF1206 MF2410 MF1210 Inch mm Inch mm Inch mm Inch mm L 0.338 8.60 0.173 4.40 0.338 8.60 0.170 4.40 G 0.118 3.00 0.059 1.50 0.118 3.00 0.070 1.70 H 0.124 3.15 0.071 1.80 0.110 2.80 0.110 2.70 Packaging: Chip Size Parts on 7 inch (178 mm) Reel 2410 (6125) 2,000 1210 (3225) 2,500 1206 (3216) 3,500 Storage: The maximum ambient temperature shall not exceed 35°C . Storage temperatures higher than 35°C could result in the deformation of packaging materials. The maximum relative humidity recommended for storage is 75%. High humidity with high temperature can accelerate the oxidation of the solder plating on the termination and reduce the solderability of the components. Sealed vacuum foil bags with desiccant should only be opened prior to use. Website: www.aemchina.com & www.aemcomponents.com Revision of May 2019 AirMatrix® Surface Mount Fuses Fuse Selection and Temperature De-rating Guideline: Temperature Effect On Current Rating 110 105 100 95 % De-rating The ambient temperature affects the current carrying capacity of fuses. When a fuse is operating at a temperature higher than 25oC, the fuse shall be “derated”. To select a fuse from the catalog, the following rule may be followed: Catalog Fuse Current Rating = Nominal Operating Current / 0.75 / % De-rating at the maximum operating temperature. Example: At maximum operating temperature of 65oC, % De-rating is 90%. The nominal operating current is 4 A. The current rating for fuse selected from the catalog shall be: 90 85 80 75 70 65 60 55 50 -55 -35 -15 5 25 45 65 85 105 125 Maximum Operating Temperature(℃) Environmental Tests: Reliability Test Test Condition and Requirement Test Reference Reflow & Bend 3 reflows at 245°C followed by a 2 mm bend, 20% DCR change Refer to AEM QIQ034 ,QIQ048 max. (10% for ≤ 1 A), no mechanical damage Solderability 245°C, 5 seconds, new solder coverage 90% minimum MIL-STD-202 Method 208 Soldering Heat Resistance 260°C, 10 seconds, 20% DCR change max. (10% for ≤ 1 A), new solder coverage 75% minimum MIL-STD-202 Method 210 Life 25°C, 2000 hours, 80% rated current (75% for < 1 A), voltage drop change≤ ±20% Refer to AEM QIQ106 Thermal Shock -65°C to +125°C, 100 cycles, 10% DCR change max., no mechanical damage MIL-STD-202 Method 107 Mechanical Vibration 5 – 3000 Hz, 0.4 inch double amplitude or 30 G peak, 10% DCR change max., no mechanical damage MIL-STD-202 Method 204 Mechanical Shock 1500 G, 0.5 milliseconds, half-sine shocks, 10% DCR change max., no mechanical damage MIL-STD-202 Method 213 Salt Spray 5% salt solution, 48 hour exposure, 10% DCR change max., no excessive corrosion MIL-STD-202 Method 101 Moisture Resistance 10 cycles, 15% DCR change max., no excessive corrosion MIL-STD-202 Method 106 Website: www.aemchina.com & www.aemcomponents.com Revision of May 2019 AirMatrix® Surface Mount Fuses Soldering Temperature Profile: * Recommended Temperature Profile for Reflow Soldering Profile Feature Preheat/Soak Temperature Min (Tsmin) Temperature Max(Tsmax) Time(ts) from (Tsmin to Tsmax) Pb-Free Assembly 150°C 200°C 60~120 seconds Ramp-uprate (TL to Tp) 3°C/second max. Liquidous temperature(TL) Time(tL) maintained above TL 217°C 60~150 seconds Peak package body temperature (Tp) 260°C Time (tp)*within 5°C of the specified classification temperature (Tc) 30 seconds * Ramp-down rate (Tp to TL) 6°C/second max. Time 25°C to peak temperature 8 minutes max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum * Recommended Temperature Profile for Wave Soldering Website: www.aemchina.com & www.aemcomponents.com Revision of May 2019 Disclaimer Specifications are subject to change without notice. AEM products are designed for specific applications and should not be used for any purpose (including, without limitation, automotive, aerospace, medical, life-saving applications, or any other application which requires especially high reliability for the prevention of such defect as may directly cause damage to the third party’s life, body or property) not expressly set forth in applicable AEM product documentation. It is the customer’s responsibility to validate that a particular product with the properties described in the product specification is suitable for use in a particular application. Warranties granted by AEM shall be deemed void for products used for any purpose not expressly set forth in applicable AEM product documentation. AEM shall not be liable for any claims or damages arising out of products used in applications not expressly intended by AEM as set forth in applicable AEM product documentation. The sale and use of AEM products is subject to AEM terms and conditions of sale. Please refer to AEM’s website for updated catalog and terms and conditions of sale. Website: www.aemchina.com & www.aemcomponents.com
AF1206F3.00TM 价格&库存
很抱歉,暂时无法提供与“AF1206F3.00TM”相匹配的价格&库存,您可以联系我们找货
