F1206FA7000V024TM
F1206FA7000V024TM
    AEM
    一次性保险丝(熔断) 7A 24V
F1206FA7000V024TM 数据手册
Product Specification 产 品 规 格 书 Product Name : Fast Acting Surface Mount Chip Fuse AEM Part Number : F1206FA7000V024TM Customer : 深圳宝龙达信息技术股份有限公司 Revision: 2 Date: 2011-11-09 AEM Components (Suzhou) Co., Ltd 458 Shenhu Road, Suzhou Industrial Park Jiangsu, P.R China, 215122 TEL: 86-512-6258-0028 FAX: 86-512-6258-0018 www.aemchina.com *.The specification are the property of AEM Components Co.Ltd and shall not be copied or used as commercial purposes without permission. *.此规格书归AEM科技(苏州)有限公司所有,未经许可,不得复制及用于其它商业用途 Prepared by Checked by Approved by Accepted by customer Lingling Li Yan Ma Yan Ma 深圳宝龙达信息技术股份有限公司 Signature Page: 1/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse 快断片式熔断器 F1206FA7000V024TM AEM Part Number: 1 Operating Temperature Range -55℃ ~ +125℃ 2 Ratings AEM Part Number Current Rating (A) F1206FA7000V024TM 7.0 Voltage Rating (VDC) Nominal Cold DCR (Ω)1 24 0.011 1. Measured at ≤10% rated current and 25℃ambient. 3 Clear-Time Characteristics(Fast Acting): % of current rating Clear-time at 25 ℃ 100% 4 hours ( min ) 250% 5 seconds ( max ) 400% 0.05 seconds ( max ) 4 Interrupting Ratings: 7.0A 45A at rated voltages 5 Marking(Optional): Black Marking Character Code 7.0A:P 6 Agency Approval: Recognized Under the Components Program of Underwriters Laboratories. File Number: E232989 Page: 2/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse 快断片式熔断器 F1206FA7000V024TM AEM Part Number: 7 Shape and Dimensions: Inch (mm) Size L W T BW 1206 (3216) 0.126±0.008 (3.20±0.20) 0.063±0.008 (1.60±0.20) 0.043±0.008 (1.10±0.20) 0.020±0.010 (0.51±0.25) 8 Product Identification F 1206 FA 7000 V024 (1) (2) (3) (4) (1) Series code: F - Chip Fuse (2) Dimension code: L x W (inch) (5) T M (6) (7) The first two digits - L (length) The last two digits - W (width) (3) Characteristic code: FA - Fast Acting (4) Current rating code: 7000 - 7000 mA (5) Voltage rating code: V024 - 24 VDC (6) Package code: T - Tape & Reel B - Bulk (7) Marking code: M - with mark Page: 3/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse AEM Part Number: 9 快断片式熔断器 F1206FA7000V024TM Clear Time Curves: F1206FA7000V024TM 10 Clear-Time (s) 1 0.1 0.01 0.001 0.0001 Upper curve represents the maximum clear-times Middle curve repersents the average clear-times Lower curve represents the minimum clear-times 0.00001 0.1 1 10 100 Current (A) Page: 4/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse 快断片式熔断器 F1206FA7000V024TM AEM Part Number: 10 I2t vs .t Curves: F1206FA7000V024TM 10000 1000 I2t (A2s) 100 10 1 0.1 0.01 Upper curve represents the maximum I²t Middle curve repersents the average I²t Lower curve represents the minimum I²t 0.001 0.0001 0.00001 0.0001 0.001 0.01 0.1 1 10 Time (s) Page: 5/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse AEM Part Number: 快断片式熔断器 F1206FA7000V024TM 11 Features 11.1 Mutilayer monolithic structure with glass ceramic body and silver fusing element 11.2 Silver termination with nickel and solder plating (lead free), providing excellent solderability 11.3 Compatible with both wave and reflow soldering processes 12 Typical Applications 12.1 Consumer Electronics, e.g. CD-/LD-Disc drives, portable sets (drives) 12.2 Communication Technology, e.g. ISDN-line card protection, PCM-cards, mobile phones tuner input, satellite receivers, cards in GSM-base stations 12.3 Data-Processing, e.g. disc drives, keyboard/mouse ports, LAN-/PC-cards, modems 12.4 Measurement and Control Technology, e.g. communication ports, measurement inputs/ probes/sensors, analysis units, PLCs 12.5 Medical Technology, e.g. communication ports, measurement in & out probes 12.6 Power Supply Technology, e.g. low voltage section of power-supplies/chargers 13 Temperature De-rating Guideline The ambient temperature affects the current carrying capacity of fuses. When a fuse is operating at a temperature higher than 25℃, the fuse shall be “de-rated” according to the de-rating curve. Page: 6/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse 快断片式熔断器 AEM Part Number: F1206FA7000V024TM 14 Recommended PC Board Land Pattern Chip Size L INCH (mm) G INCH (mm) H INCH (mm) 1206 (3216) 0.173 (4.40) 0.059 (1.50) 0.071 (1.80) 15 Recommended Temperature Profile for Reflow Soldering Page: 7/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse AEM Part Number: 快断片式熔断器 F1206FA7000V024TM 16 Special Measuring Equipment 16.1 Clear Time Clear time is measured with clear time tester. 16.2 DC Resistance DC resistance is measured with Keithley 580/Keithley 2010. 16.3 Interrupting Capability Interrupting capability is measured with short circuit tester. 17 Reliability Tests Reliability Test Test Condition and Requirement Bending Board: 94x94x1.6 mm, 2 mm bend for 5 seconds, 20% DCR change max. Solderability 255ºC, 5 seconds, 95% coverage min. Soldering Heat Resistance 260ºC, 60 seconds, 10% DCR change max. Terminal Strength 1206 – 1.5 kg 30 second hanging, no damage Life 25ºC, 2000 hours, 80% rated current, no open circuit, voltage drop change≤±20%. Thermal Shock -65ºC to +125ºC, 100 cycles, no mechanical damage, 10% DCR change max. Mechanical Vibration 5 – 3000 Hz, 0.4 inch double amplitude or 30 G peak, 10% DCR change max. Mechanical Shock 1500 G, 0.5 milliseconds, half-sine shocks 10% DCR change max. Salt Spray 5% salt solution, 48 hour exposure Moisture Resistance 10 cycles, 15% DCR change max., no excessive corrosion Page: 8/10 Product Specification CUSTOMER:深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse AEM Part Number: 快断片式熔断器 F1206FA7000V024TM 18 Packaging 18.1 Surface mount chip fuses are provided on tape-and-reel for use in pick-and-place machines or in bulk for special applications. Both tape-and-reel and bulk products are sealed in plastic bags with desiccant. The reel size is 7 inches. 18.2 Tape Dimensions: INCH (mm) Size 1206 (3216) E1 F Ao Bo Ko 0.071+0.004 0.138+0.004 0.050+0.004 (1.80+0.10) (3.50+0.10) (1.27+0.10) Type Plastic W P1 P0 P2 D0 0.069+0.004 0.138+0.002 0.315+0.004 0.157+0.004 0.157+0.004 0.079+0.002 0.059+0.004 (1.75±0.10) (2.00+0.05) (3.50±0.05) (8.00±0.10) (4.00+0.10) (4.00+0.10) D1 t 0.039max 0.009+0.001 (1.50+0.10/-0.00) (1.00max) (0.23+0.02) Page: 9/10 Product Specification CUSTOMER: 深圳宝龙达信息技术股份有限公司 Fast Acting Surface Mount Chip Fuse AEM Part Number: 快断片式熔断器 F1206FA7000V024TM 18.3 Quantity Per Reel Chip Size Parts on 7 inch (178 mm) Reel 1206 (3216) 3,000 Other sizes and chip quantities can be provided upon customer's request. 19 Storage 19.1 The maximum ambient temperature shall not exceed 35℃. Storage temperature higher than 35℃ could result in the deformation of packaging materials. 19.2 The maximum relative humidity recommended for storage is 75%. High humidity with high temperature could accelerate the oxidation of the solder plating on the termination and reduce the solderability of the components. 19.3 Sealed plastic bags with desiccant shall be used to reduce the oxidation of the termination and shall only be opened prior to use. 19.4 The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present. Page: 10/10
F1206FA7000V024TM 价格&库存
很抱歉,暂时无法提供与“F1206FA7000V024TM”相匹配的价格&库存,您可以联系我们找货
F1206FA7000V024TM
    • 5+1.78978
    • 50+1.43057
    • 150+1.27656
    • 500+1.08454
    库存:1007
