F0603HI3000V032T
F0603HI3000V032T
    AEM
    一次性保险丝(熔断) 3A 32V
F0603HI3000V032T 数据手册
Product Specification 产 品 规 格 书 Product Name : High Inrush Current Surface Mount Chip Fuse AEM Part Number : F0603HI3000V032T Customer : 元晖光电有限公司 Revision: 5 Date: 2014-01-13 AEM Components (Suzhou) Co., Ltd 138 West Shenhu Road, Suzhou Industrial Park Jiangsu, P.R China, 215122 TEL: 86-512-6258-0028 FAX: 86-512-6258-0018 www.aemchina.com *.The specification are the property of AEM Components Co.Ltd and shall not be copied or used as commercial purposes without permission. *.此规格书归AEM科技(苏州)有限公司所有,未经许可,不得复制及用于其它商业用途 Prepared by Checked by Approved by Accepted by customer Lingling Li Dongming Tan Dongming Tan 元晖光电有限公司 Signature Page: 1/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse 耐浪涌片式熔断器 F0603HI3000V032T AEM Part Number: 1 Operating Temperature Range -55℃ ~ +125℃ (with de-rating) 2 Ratings AEM Part Number Current Rating (A) Voltage Rating (VDC) Nominal Cold DCR 1 (Ω) DCR Min (Ω) DCR Max (Ω) Nominal I2t (A2s)2 F0603HI3000V032T 3.0 32 0.030 0.021 0.039 0.72 1. Measured at ≤10% of rated current and 25℃ ambient. 2. Melting I2t at 1000% current rating 3 Clearing Time Characteristics: % of current rating Clearing Time at 25 ℃ 100% 4 hours ( min ) 200% 1 second ( min ) 1000% 0.0002 seconds ( min )0.02 seconds ( max ) 60 seconds ( max ) 4 Interrupting Rating: 50A at rated voltage 5 Marking(Optional): Without marking 6 Agency Approval: Recognized Under the Components Program of Underwriters Laboratories. File Number: E232989 Page: 2/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse 耐浪涌片式熔断器 F0603HI3000V032T AEM Part Number: 7 Shape and Dimensions: Inch (mm) Size 0603 (1608) L W T BW 0.063±0.006 0.031±0.006 0.031±0.006 0.014±0.006 (1.60±0.15) (0.80±0.15) (0.80±0.15) (0.36±0.15) 8 Product Identification F 0603 HI 3000 V032 (1) (2) (3) (4) (5) (1) Series code: F - Chip Fuse (2) Dimension code: L x W (inch) T (6) The first two digits - L (length) (3) (4) (5) (6) The last two digits - W (width) Characteristic code: HI - High Inrush Current rating code: 3000 - 3000 mA Voltage rating code: V032 - 32 VDC Package code: T - Tape & Reel B - Bulk Page: 3/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse AEM Part Number: 耐浪涌片式熔断器 F0603HI3000V032T 9 Clearing Time Curves: F0603HI3000V032T 100 10 Clearing Time(s) 1 0.1 0.01 0.001 Upper curve represents the maximum clear-times Middle curve repersents the average clear-times Lower curve represents the minimum clear-times 0.0001 0.00001 1 10 100 Current (A) Page: 4/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse AEM Part Number: 耐浪涌片式熔断器 F0603HI3000V032T 10 I2t vs t Curves: F0603HI3000V032T 10000 1000 I2t (A2s) 100 10 1 Upper curve represents the maximum I²t Middle curve repersents the average I²t Lower curve represents the minimum I²t 0.1 0.01 0.000001 0.00001 0.0001 0.001 0.01 0.1 1 10 100 Time (s) Page: 5/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse AEM Part Number: 耐浪涌片式熔断器 F0603HI3000V032T 11 Features 11.1 High inrush current withstanding capability 11.2 Mutilayer monolithic structure with glass ceramic body and silver fusing element 11.3 Silver termination with nickel and solder plating (lead free), providing excellent solderability 11.4 Compatible with both wave and reflow soldering processes 12 Typical Applications 12.1 Consumer Electronics, e.g. CD-/LD-Disc drives, portable sets (drives) 12.2 Communication Technology, e.g. ISDN-line card protection, PCM-cards, mobile phones tuner input, satellite receivers, cards in GSM-base stations 12.3 Data-Processing, e.g. disc drives, keyboard/mouse ports, LAN-/PC-cards, modems 12.4 Measurement and Control Technology, e.g. communication ports, measurement inputs/ probes/sensors, analysis units, PLCs 12.5 Medical Technology, e.g. communication ports, measurement in & out probes 12.6 Power Supply Technology, e.g. low voltage section of power-supplies/chargers 13 Temperature De-rating Guideline The ambient temperature affects the current carrying capacity of fuses. When a fuse is operating at a temperature higher than 25℃, the fuse shall be “de-rated” according to the de-rating curve. Page: 6/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse AEM Part Number: 耐浪涌片式熔断器 F0603HI3000V032T 14 Recommended PC Board Land Pattern Chip Size L INCH (mm) G INCH (mm) H INCH (mm) 0603 (1608) 0.087 (2.20) 0.031 (0.80) 0.039 (1.00) 15 Recommended Temperature Profile for Reflow Soldering Recommended conditions for hand soldering: 1. Appropriate temperature (max.) of soldering iron tip/soldering time (max.): 280°C /10 s or 350°C / 3 s 2. Using hot air rework station with tip that can melt the solder on both terminations at the same time is strongly recommended. Do not directly contact the chip termination with the tip of soldering iron. Page: 7/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse AEM Part Number: 耐浪涌片式熔断器 F0603HI3000V032T 16 Special Measuring Equipment 16.1 Clear Time Clear time is measured with clear time tester. 16.2 DC Resistance DC resistance is measured with Keithley 580/Keithley 2010. 16.3 Interrupting Capability Interrupting capability is measured with short circuit tester. 17 Reliability Tests Reliability Test Test Condition and Requirement Bending Board: 94x94x1.6 mm, 2 mm bend for 5 seconds, 20% DCR change max. Solderability 255ºC, 5 seconds, 95% coverage min. Soldering Heat Resistance 260ºC, 60 seconds, 10% DCR change max. Terminal Strength 0603 – 0.5 kg 30 second hanging, no damage Life 25ºC, 2000 hours, 80% rated current, no open circuit,voltage drop change≤±10%. Thermal Shock -65ºC to +125ºC, 100 cycles, no mechanical damage, 10% DCR change max. Mechanical Vibration 5 – 3000 Hz, 0.4 inch double amplitude or 30 G peak, 10% DCR change max. Mechanical Shock 1500 G, 0.5 milliseconds, half-sine shocks 10% DCR change max. Salt Spray 5% salt solution, 48 hour exposure Moisture Resistance 10 cycles, 10% DCR change max., no excessive corrosion Page: 8/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse AEM Part Number: 耐浪涌片式熔断器 F0603HI3000V032T 18 Packaging 18.1 Surface mount chip fuses are provided on tape-and-reel for use in pick-and-place machines or in bulk for special applications. The reel size is 7 inches. 18.2 Tape Dimensions: Inch (mm) Size 0603 (1608) E1 F Ao Bo Ko Type 0.039 ± 0.004 0.071 ± 0.004 0.037 ± 0.003 (1.00 ± 0.10) (1.80 ± 0.10) (0.95 ± 0.08) Paper W P1 P0 P2 D0 0.069 ± 0.004 0.138 ± 0.002 0.319+0.008 0.157 ± 0.004 0.157 ± 0.004 0.079 ± 0.002 0.059 + 0.004/-0.00 (1.75 ± 0.10) (3.50 ± 0.05) (8.10±0.20) (4.00 ± 0.10) (4.00 ± 0.10) (2.00 ± 0.05) D1 t N/A N/A (1.50 + 0.10/-0.00) Page: 9/10 Product Specification CUSTOMER: 元晖光电有限公司 High Inrush Current Surface Mount Chip Fuse AEM Part Number: 耐浪涌片式熔断器 F0603HI3000V032T 18.3 Quantity Per Reel Chip Size Parts on 7 inch (178 mm) Reel 0603 (1608) 4,000 Other sizes and chip quantities can be provided upon customer's request. 19 Storage 19.1 The maximum ambient temperature shall not exceed 35℃.Storage temperature higher than 35℃ could result in the deformation of packaging materials. 19.2 The maximum relative humidity recommended for storage is 75%.High humidity with high temperature could accelerate the oxidation of the solder plating on the termination and reduce the solderability of the components. 19.3 The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present. Page: 10/10
F0603HI3000V032T 价格&库存
很抱歉,暂时无法提供与“F0603HI3000V032T”相匹配的价格&库存,您可以联系我们找货
