ALF1205
ALF1205
    ELC
    ELC - ALF1205 - POWER SUPPLY, 1CH, 15V, 5A, ADJUSTABLE
ALF1205 数据手册
SWITCHING REGULATED POWER SUPPLY 12V EAN CODE : 3760244880154 ALF1205 PRATICAL : ON/OFF switch. - Power-on indicator. PRECISE : Output ripple < 3mV rms. - Output voltage adjustable from 10 to 15V. PROTECTED : against Short circuit. RESISTANT TO SHOCK                  60 WATTS 12V (Adj. 10 to 15V) 5A   Specifications • Floating outputs on 4  mm safety sockets. • Output voltage : adjustable from 10 to 15V. • Regulation : < 15mV for a load variation from 0 to 100% < 2mV for a line variation from 198 to 264V. • Ripple : < 3mV rms including: < 3mV peak to peak of the signal at 100 KHz < 5mV peak to peak of the signal at 100 Hz < 12mV peak to peak of switching spikes • Hold-up time : 25 ms at half load and 12 ms at full load (198V line input). • Indicator : green power-on LED indicator. Overheat or overcurrent red LED "status" indicator. Current • Max I : 5,5A in short circuit condition. 5A from 10 to 12V 4A to 15V                    Voltage                     Other specifications • Safety : Class II, Safety Extra Low Voltage (SELV) according to EN 61010-1. • EMC : Complies with EN 61326-1, performance criteria B, and EN 55011, ISM Group I, Class B. • Protection level : IP 30. • Input voltage : 198 to 264 Volts, 50 / 60 Hz. • Mains input : C8 socket with CEI320 C7 removable cable (2 poles double insulation). • Power consumption : 74 W max. • ON/OFF control : toggle switch • Dielectric strength : 3000 Vac between input and output. • Presentation : polycarbonate case screenprinted. Power • Max output power : 60W. Protection • Agains short circuit protection, by current limit. • Against overtemperature by thermal shutdown. • Agains overcurrent on main inpout, by fuse. 35 | www.elc.fr
ALF1205 价格&库存
很抱歉,暂时无法提供与“ALF1205”相匹配的价格&库存,您可以联系我们找货
