OEM REGULATED POWER SUPPLY
ALE1225
PRECISE : Output ripple < 3mV rms.
COMPLIE : EN 61000-3-2 Built in actif power corrector (PFC).
DIAGNOSTIS : Alarm by Relay with invert contact.
PRACTICAL : Output voltage adjustable from 10 to 15V.
UNIVERSAL : 190 to 440V main input voltage.
POWERFUL : To cumulate n+1 (Parallel active mode).
PROTECTED : against short circuit.
EASY : Direct DIN rail mounting
- Spring terminal block.
12V PRIM 190 TO 440V + ACTIVE PFC
300 WATTS
12V (Adj. 10 to 15V)
25A
Specifications
Voltage
• Floating outputs on dual spring terminal blocks with levers for 2,5 mm²
(AWG 12) wire.
• Output voltage : adjustable from 10 to 15 V.
• Regulation
: < 100 mV for a load change from 0 to 100%.
< 10 mV for a line change from 190 to 440 V.
• Ripple
: < 3mV rms including :
< 5 mV peak to peak of the signal at 100 KHz
< 5 mV peak to peak of the signal at 100 Hz
< 10 mV peak to peak of switching spikes
• Internal resistance : 4 mΩ
• Hold-up time
: 25 ms at half load and 12 ms at full load
(190 V line input).
• Indicator
: green power-on LED indicator.
overheat or overvoltage red LED indicator.
• Information Relay : Invert contact, 250VAC (30VDC) 1A.
Current
• Max I
Other specifications
• Safety
: Class I, complies with EN 60950.
• EMC
: Complies with EN 61000-6-2 and EN 61000-6-4.
• Protection level : IP 30.
• Input voltage
: 190 to 440 Volts, 50 / 60 Hz.
• Mains input
: Dual spring terminal blocks for 1,5mm² (AWG 16) wire.
• Power consumption : 360 W max.
• Power factor
: 0,99 (built in PFC).
• Dielectric strength : 4000 V between input and output.
• Presentation
: galvanized steel case and front panel with epoxy finish.
• Mounting
: Integral symmetrical DIN rail clips.
Paralleling
: 25,5 A in short circuit condition.
25 A from 10 to 12 V, 20 A 15 V
• Load share controller (1 wire) on dual spring terminal blocks for 1,5 mm²
wire (AWG 16).
Power
• Max output power : 300 W from 12 to 15 V, 250 W at 10 V.
Protections
• Against short circuits by current limit.
• Against overcurrent on primary circuit by internal fuse.
• Against output overload by voltage limiting to 17 V.
• Against current reverse power surges on the output, by fuse.
300W 600W 900W
55 | www.elc.fr
很抱歉,暂时无法提供与“ALE1225”相匹配的价格&库存,您可以联系我们找货
