ALF1202
ALF1202
    ELC
    ELC - ALF1202 - Bench Power Supply, Adjustable, Fixed, 1 Output, 10 V, 15 V, 2 A, 3 A
ALF1202 数据手册
SWITCHING REGULATED POWER SUPPLY EAN CODE : 3760244880147 ALF1202 12V PRATICAL : ON/OFF switch. - Power-on indicator. PRECISE : Output ripple < 3mV rms. - Output voltage adjustable from 10 to 15V. PROTECTED : against Short circuit. RESISTANT TO SHOCK               30 WATTS                    12V (Adj. 10 to 15V) 2,5A                          Specifications Voltage • Floating outputs on 4  mm safety sockets. • Output voltage : adjustable from 10 to 15V. Delivered to 12V ±1% • Regulation : < 25mV for a load variation from 0 to 100% < 5mV for a line variation from 190 to 264V. • Ripple : < 3mV rms including: < 3mV peak to peak of the switching signal < 8mV peak to peak of the signal at 100 Hz < 10mV peak to peak of switching spikes • Dynamic regulation : 80% at the full power (30W in ouptut) Protection • Agains short circuit, by current limit. • Agains overcurrent on main input, by fuse. • Against transient pulse on the primary by varistor. 33 | www.elc.fr
ALF1202 价格&库存
很抱歉,暂时无法提供与“ALF1202”相匹配的价格&库存,您可以联系我们找货
ALF1202
  • 1+761.38892
库存:5
