ALE2412
ALE2412
    ELC
ALE2412 数据手册
OEM REGULATED POWER SUPPLY 24V PRIM 190 TO 440V + ACTIVE PFC ALE2412 PRECISE :Output ripple < 3mV rms. COMPLIE : EN 61000-3-2 Built in actif power corrector (PFC). DIAGNOSTIS : Alarm by Relay with invert contact. PRACTICAL : Output voltage adjustable from 20 to 30V. UNIVERSAL : 190 to 440V main input voltage. POWERFUL : to cumulate n+1(Parallel active mode). PROTECTED : against short circuit. EASY : Direct DIN rail mounting - Spring terminal block.                          24V (Adj. 20 to 30V) 12,5A    300 WATTS                              Specifications Voltage • Floating outputs on dual spring terminal blocks with levers for 2,5 mm² (AWG 12) wire. • Output voltage : adjustable from 20 to 30 V. • Regulation : < 50 mV for a load change from 0 to 100%. < 10 mV for a line change from 190 to 440 V. • Ripple : < 3 mV rms including : < 5 mV peak to peak of the signal at 100 KHz < 5 mV peak to peak of the signal at 100 Hz < 10 mV peak to peak of switching spikes • Internal resistance : 4 m Ω • Hold-up time : 25 ms at half load and 12 ms at full load (190V line input). • Indicator : green power-on LED indicator. overheat or overvoltage red LED indicator. • Information Relay : Invert contact, 250VAC (30VDC) 1A. Current • Max I            Other specifications • Safety : Class I, complies with EN 60950. • EMC : Complies with EN 61000-6-2 and EN 61000-6-4. • Protection level : IP 30. • Input voltage : 190 to 440 Volts, 50 / 60 Hz. • Mains input : Dual spring terminal blocks for 1,5 mm² (AWG 16) wire. • Power consumption : 360 W max. • Power factor : 0,99 (built in PFC). • Dielectric strength : 4000 V between input and output. • Presentation : galvanized steel case and front panel with epoxy finish. • Mounting : Integral symmetrical DIN rail clips. Paralleling : 15,5 A in short circuit condition. 15 A at 20 V, 12,5 A at 24 V, 10 A at 30 V. • Load share controller (1 wire) on dual spring terminal blocks with level for 1,5 mm² wire (AWG 16). Power • Max output power : 300 W from 20 to 30 V. Protections • Against short circuits by current limit. • Against primary circuit overcurrent, by internal fuse. • Against output overload by voltage limiting to 33 V. • Against current reverse power surges on the output, by fuse. 300W 600W 900W 65 | www.elc.fr ...
ALE2412 价格&库存
很抱歉,暂时无法提供与“ALE2412”相匹配的价格&库存,您可以联系我们找货
