ALR3203
ALR3203
    ELC
    ELC - ALR3203 - Bench Power Supply, Programmable, 1 Output, 0 V to 32 V, 0 A to 6 A
ALR3203 数据手册
PROGRAMMABLE POWER SUPPLY EAN CODE : 3760244880925 COMPACT 1 output Compact ALR3203 VISUAL : Large graphic display SOFT-TOUCH : Sensitiv keypad CONNECTED : USB isolated, LabVIEW™ drivers and executable provided FUNCTIONS : Arbitrary, square, positive and negative ramp, rise or fall time ELEGANT : New design and feathery SPACE-SAVING : vertical case, COMPACT DESIGN PRACTICAL : Lightweight with built-in handle and cord storage area. QUIET : Without fan. LOCKING : configuration & stand-by                ULTRA-COMPACT LabVIEW™                 96 WATTS LabVIEW™    0 - 32 V 0 - 6 A (96 WATTS MAX.)                    Voltage Protections • Floating outputs : on 4 mm safety terminals. • Automatic constant voltage operation. • Adjustable from 0 to 32,00 Volts (0 to ±10 mV) ; resolution : 10 mV. • Setting accuracy : < 0,03% that to say ±10 mV. • Regulation : < 20 mV for a load change from 10 to 90%. < 1 mV for a ±10% line change. •Ripple : < 1,5 mV rms including : < 5 mV peak to peak of noise (BP 20 MHz) < 10 mV peak to peak of switching spikes • Internal resistance : < 4 mΩ. • Display : 4 digits on graphic LCD. • Accuracy measurement : < 0,03% that to say ±10 mV. Current    Specifications         • Against short-circuits, by current regulation. • Against overtemperature by thermal circuit-breaker. • Against overcurrent on main input, by internal fuses. Various and functions • Automatic constant current operation. • Adjustable from 0 to 6,000 Amps ; resolution : 2 mA. • Setting accuracy : < 0,05% that to say ±10 mA. • Pmax : 96 W ; Imax : 6 A from 0 to 16V then decreasing to 3 A ; 32 V • Regulation : < 1 mA for a load charge from 10 to 90%. < 1 mA for a ±10% line charge. • Ondulation : < 1 mA peak to peak or 0.4 mA rms. • Display : 4 digits on graphic LCD. • Accuracy measurement : < 0,03% that to say ±2 mA. • Dispaly : Graphic LCD 128 x 64 pixels with white backlight. Visualization of all parameters (CV, CC, RMT, ...) • Memories : 16 including 15 configurable. • OVP/OCP : Against overvoltage and overcurrent, adjustable from 0 to maxi. • Functions : 6 available on U or I (Arbitrary, square, rising and falling periodically ramp, rise or fall time single shot). Time adjustement from 100 ms to 50 mn. • Standby : output, enable / disabled and standby of the power supply. Interfaces • USB, as a standard, insulated of the output (150 VDC max). • LabVIEW™'s drivers as a standard. Other specifications • Safety : Class I, enhanced safety between mains input and outputs Complies with EN 61010-1, CAT II. Output Safety Extra Low Voltage (SELV) • CEM : Complies with EN 61326-1 and EN 55011. • Input voltage : 220 - 240 Volts ±10%, 50/60Hz. • Mains input : Socket CE14 with C13, 2 poles + earth cable removable • Power consumption : 126 W maxi. • Efficiency : > 78% of the maxi powerful. • Operating temperature : +5 to +40 °C. • Coefficient of temperature /°C : 0.01% for the voltage ; 0,05% for the current. • Voltage on the earth : 150 VDC Max. • Presentation : Front-panel with sensitiv keypad, rear-panel with handle and cord storage area, metallic case with epoxy finish. 9 | www.elc.fr
ALR3203 价格&库存
很抱歉,暂时无法提供与“ALR3203”相匹配的价格&库存,您可以联系我们找货
ALR3203
    库存:12
