ALR3206D
ALR3206D
    ELC
    ELC - ALR3206D - Bench Power Supply, Programmable, 2 Output, 0 V, 32 V, 0 A, 6 A
ALR3206D 数据手册
PROGRAMMABLE POWER SUPPLY EAN CODE : 3760244880871 DOUBLE ALR3206D 2 outputs Powerfull VISUAL : Large graphic display SOFT-TOUCH : Sensitiv keypad CONNECTED : USB, RS485 & 0-10V isolated LabVIEW as a standard PERFORMANCE : output in the rear-panel,used for remote-sensing COUPLING : Auto mode : Series, Parallel, Tracking FUNCTIONS : square, positive and negative ramp, rise or fall time ELEGANT : New design and feathery SPACE-SAVING : vertical & COMPACT BOX / 390W PRACTICAL : Lightweight with built-in handle and cord storage area. QUIET : Silent temperature-controlled fan cooling. LOCKING : configuration & stand-by          0 - 6 A or 0 - 6 A or 0 - 6 A or 0 - 12 A LabVIEW      ULTRA-COMPACT                2 x 0 - 32 V 1 x ± 0 - 32 V 1 x 0 - 64 V 1 x 0 - 32 V    390 WATTS                Specifications Channel 1 and 2 MASTER AND SLAVE Independent Tracking Series Parallel Output voltage 2 x 0 - 32 V ± 0 - 32 V 0 - 64 V 0 - 32 V Minimum voltage ± 10 mV ± 10 mV ± 20 mV ± 10 mV Adjustement accuracy 0.03% or ±10 mV (20 mV in series) Ripple (mV rms) < 0.7 mV < 0.7 mV < 1.5 mV < 1 mV Pics of commutation (BP 20 MHz) < 15 mVpp < 15 mVpp < 30 mVpp < 30 mVpp Regulation / load 0 to 100% 12 mV 12 mV 24 mV 40 mV Regulation / source ±10% 1 mV 1 mV 2 mV 1 mV Time of answer load 10 to 90% 2 ms 2 ms 2 ms 5 ms Display resolution 10mV 10mV 20mV 10mV Accuracy measurement 0.03% or ±10 mV (20 mV in series) Display 4 digits + parameters on graphic LCD Output current 2 x 0 - 6 A ± 0 - 6 A 0 - 6 A 0 - 12 A Minimum current 2 mA 2 mA 2 mA 10 mA Adjustement accuracy 0.03% or ±2 mA (10 mA in series) Ripple (mArms)
ALR3206D 价格&库存
很抱歉,暂时无法提供与“ALR3206D”相匹配的价格&库存,您可以联系我们找货
