ULTRA96
Ultra96™ is an Arm-based, Xilinx Zynq UltraScale+™ MPSoC
development board based on the Linaro 96Boards specification.
The 96Boards’ specifications are open and define a standard
board layout for development platforms that can be used by
software application, hardware device, kernel, and other system
software developers. Ultra96 represents a unique position in the
96Boards community with a wide range of potential peripherals
and acceleration engines in the programmable logic that is not
available from other offerings.
Ultra96 boots from the provided Delkin 16 GB microSD card, pre-loaded
with PetaLinux. Engineers have options of connecting to Ultra96 through
a Webserver using integrated wireless access point capability or to use
the provided PetaLinux desktop environment which can be viewed on the
integrated Mini DisplayPort video output. Multiple application examples and
on-board development options are provided as examples.
Ultra96 provides four user-controllable LEDs. Engineers may also interact
with the board through the 96Boards-compatible low-speed and high-speed
expansion connectors by adding peripheral accessories such as those included
in Seeed Studio’s Grove Starter Kit for 96Boards.
Micron LPDDR4 memory provides 2 GB of RAM in a 512M x 32 configuration.
Wireless options include 802.11b/g/n Wi-Fi and Bluetooth 4.2 (provides both
Bluetooth Classic and Low Energy (BLE)). UARTs are accessible on a header as
well as through the expansion connector. JTAG is available through a header
(external USB-JTAG required). I2C is available through the expansion connector.
Ultra96 provides one upstream (device) and two downstream (host) USB 3.0
connections. A USB 2.0 downstream (host) interface is provided on the highspeed expansion bus. Two Microchip USB3320 USB 2.0 ULPI Transceivers and
one Microchip USB5744 4-Port SS/HS USB Controller Hub are specified.
The integrated power supply generates all on-board voltages from an external
12V supply (available as an accessory).
FEATURES
- Xilinx Zynq UltraScale+ MPSoC ZU3EG A484
- Micron 2 GB (512M x32) LPDDR4 Memory
- Delkin 16 GB microSD card + adapter
- Pre-loaded with PetaLinux environment
- Wi-Fi / Bluetooth
- Mini DisplayPort (MiniDP or mDP)
- 1x USB 3.0 Type Micro-B upstream port
- 2x USB 3.0, 1x USB 2.0 Type A downstream ports
- 40-pin 96Boards Low-speed expansion header
- 60-pin 96Boards High-speed expansion header
- 85mm x 54mm form factor
- Linaro 96Boards Consumer Edition compatible
To purchase this kit, visit www.ultra96.org
KIT INCLUDES
- Ultra96 development board
- 16 GB pre-loaded microSD card + adapter
- Voucher for SDSoC license from Xilinx
- Quick-start instruction card
OPTIONAL ADD-ON ITEMS
- External 12V @ 2.0A power supply
- USB-to-JTAG/UART pod
- Seeed Studios Grove Starter Kit for 96Boards
TARGET APPLICATIONS
- Artificial Intelligence
- Machine Learning
- IoT/Cloud connectivity for add-on sensors
- Embedded Computing
- Robotics
- Entry level Zynq UltraScale+ MPSoC
development environment
- Training, prototyping and proofof-concept demo platform
- Wireless design and demonstrations
using Wi-Fi and Bluetooth
BLOCK DIAGRAM
2 GB LPDDR4
(512M x32)
microSD
(primary boot)
Mini-Display
Port
Processing System (PS)
Wi-Fi/
Bluetooth
UART
(3-pin header)
USB 3.0
Host
MPSoC
User LEDs (x4)
XCZU3EG
I2C
I2C Switch
USB 3.0 Device
USB 3.0
Hub
USB 3.0 Device
USB 2.0 Device
SPI
GPIO
Low-speed
Expansion
(40-pin)
Programmable Logic (PL)
(SPI, I2C, UART, GPIO)
High-speed
Expansion
(60-pin)
(SPI, I2C, MIPI, UART,
GPIO, etc.)
FEATURED MANUFACTURERS
PARTS
Part Number
Description
Resale
AES-ULTRA96-G
Ultra96 Zynq UltraScale+ ZU3EG Development Board
$249.00
Part Number
Description
Resale
AES-ACC-U96-PWR
External 96Boards compliant power supply kit (12V, 2A, US plug)
$8.50
AES-ACC-U96-JTAG
USB-to-JTAG/UART pod for Ultra96
$39.00
110060157*
$69.00
ADM00559
MCP2221 Breakout Module
$19.99
AES-ACC-U96-4APWR
External 96Boards compliant power supply kit (12V, 4A, International plugs)
$19.99
RELATED PARTS
*This product is only available through http://uk.farnell.com/seeed-studio/110060157/grove-starter-kit-for-96boards/dp/2855417
Countries Available for Purchase: Americas, EMEA, Japan
CONTACT
INFORMATION
Americas
2211 S 47 th Street
Phoenix, Arizona 85034
United States of America
eval.kits@avnet.com
1-800-585-1602
Europe (Silica)
Gruber Str. 60c
85586 Poing
Germany
marketing@silica.com
+49-8121-77702
Europe (EBV)
Im Technologypark 2-8
85586 Poing
Germany
http://ebv.com/contact
Japan
Yebisu Garden Place Tower, 23F
4-20-3 Ebisu, Shibuya-ku
Tokyo 150-6023 Japan
eval-kits-jp@avnet.com
+81-(0)3-5792-8210
Copyright © 2018 Avnet, Inc. AVNET, "Reach Further," and the Avnet logo are registered trademarks of Avnet, Inc. All other brands are the property of their respective owners.
LIT# 5354-pb-ultra96-v1
很抱歉,暂时无法提供与“AES-ULTRA96-G”相匹配的价格&库存,您可以联系我们找货
