ALE1205.
ALE1205.
    ELC
    ELC - ALE1205. - AC/DC DIN Rail Power Supply (PSU), ITE, 1 Output, 60 W, 15 VDC, 5 A
ALE1205. 数据手册
OEM MODULAR & REGULATED POWER SUPPLY EAN CODE : 3760244880253 ALE1205 12 V REMOTE-SENSING PRECISE : Switching power supply offering a ripple < 3 mV rms. - Output voltage adjustable from 10 to 15 V SMALL : Modular, EASY : Direct DIN rail or panel mounting. PROTECTED : against short circuits and reverse polarity.    RESISTANT TO SHOCK                     60 WATTS               12 V (Adj. 10 to 15 V) 5A                   Specifications    Voltage • Floating outputs on spring terminal block with levers for 2,5 mm² (AWG 12) wires. • Output voltage : adjustable from 10 to 15 V. • Regul : < 20 mV for a load variation from 0 to 100% < 2 mV for a line variation from -10 to+10%. • Ripple : < 3 mV rms including: < 2 mV peak to peak of the signal at 100 kHz < 4 mV peak to peak of the signal at 100 Hz < 10 mV peak to peak of switching spikes • Hold-up time : 25 ms at half load and 12 ms at full load (190 V line input). • Indicator : green power-on LED indicator. Overheat or overcurrent red LED "status" indicator Current • Max I : 5,5 A in short circuit condition. 5 A from 10 to 12 V 4 A to 15 V Other specifications • Safety : Class II, Safety Extra Low Voltage (SELV), complies with EN 61010-1, EN 61010-2-201 and EN 62368-1. • EMC : Complies with EN 61000-6-2 and EN 61000-6-4. • Overvoltage Category : II ; Pollution Degree : 2. • Installation altitude : < 2000 m. • Protection level : IP 30. • Operating temperature : from -25 to +60 °C ; derating : 1 W/°C from +40 °C • Input voltage : 190 to 264 Volts, 50/60 Hz. • Mains input : spring terminal block with levers for 2,5 mm², (AWG 12) wires. • Power consumption : 74 W max. • Dielectric strength : 3000 VAC from input to output. • Presentation : modular polycarbonate case (6 x 17.5 mm) screenprinted. • Mounting : Clips package integrated in modular case for DIN rails profile 35x7,5 mm or 35x15 mm. Removable wall mouting integrated to the case for 4 mm screws. Power • Max output power : 60 W. Protection • Short circuit protection, by current limit. • Against overcurrent on primary circuit by fuse. • Against overtemperature, by thermal shutdown. • Cover on input output terminal block. Remote sensing Correction of the voltage drop in the wires (4 wires method) Input on spring terminal block with levers for 2,5 mm² wires (AWG12) Correction : Max 3 V (1,5 V per wire) Ripple : < 30 mV for a load variation from 0 to max. 57 | www.elc.fr
ALE1205. 价格&库存
很抱歉,暂时无法提供与“ALE1205.”相匹配的价格&库存,您可以联系我们找货
