ALF2405
ALF2405
    ELC
    ELC - ALF2405 - POWER SUPPLY, 1CH, 29V, 5A, ADJUSTABLE
ALF2405 数据手册
SWITCHING REGULATED POWER SUPPLY EAN CODE : 3760244880215 ALF2405 24V PRECISE : Output ripple < 3mV rms. COMPLIANT : EN 61000-3-2 Built in actif power corrector (PFC). PRACTICAL : Output voltage adjustable from 20 to 29V. - ON/OFF switch, power-on and output fault indicators. PROTECTED : Short circuit protection. - Temperature controlled fan cooling.      120 WATTS                         24V (Adj. 20 to 29V) 5A                    Voltage • Floating outputs on 4  mm safety sockets. • Output voltage : adjustable from 20 to 29V. • Regulation : < 20mV for a load variation from 0 to 100%. < 1mV for a line variation from 190 to 253V. • Ripple : < 3mV rms including: < 5mV peak to peak of the signal at 100 KHz < 3mV peak to peak of the signal at 100 Hz < 40mV peak to peak of switching spikes • Hold-up time : 25 ms at half load and 12 ms at full load (190V line input). • Indicator : green power-on LED indicator. "status, output fault" red LED. Current • Max I    Specifications          Other specifications • Safety : Classe II, double insulation, according to EN 61010-1. • EMC : Complies with EN 61326-1, performance criteria B, and EN 55011, ISM Group I, Class B. • Protection level : IP 30. • Input voltage : 190 to 253 Volts, 50 / 60 Hz. • Mains input : C8 socket with CEI320 C7 removable cable (2 poles double insulation). • Power consumption : 170 W max. • ON/OFF control : toggle switch • Power factor : 0.99 (built in PFC). • Dielectric strength : 3000 Vac between input and output. • Presentation : metal case with epoxy finish. : 5,5A in short circuit condition. 5A from 20 to 29V Power • Max output power : 150W. Protection • Short circuit protection, by current regulation. • Agains overcurrent on main input, by fuse. • Output overload protection by voltage limit to 33V. 45 | www.elc.fr
ALF2405 价格&库存
很抱歉,暂时无法提供与“ALF2405”相匹配的价格&库存,您可以联系我们找货
