ALF1502D
ALF1502D
    ELC
    ELC - ALF1502D - POWER SUPPLY, 1CH, 15V, 4A, ADJUSTABLE
ALF1502D 数据手册
SYMMETRIC POWER SUPPLY EAN CODE : 3760244880086 + 15V or 12V or 24V ALF1502D PRATICAL : ON/OFF switch. - Power-on indicator. - 60 W available on the positive output alone. PRECISE : Output ripple < 3mV rms. - Output voltage adjustable from ±10 to ±15V. PROTECTED : against Short circuit.      RESISTANT TO SHOCK 60 WATTS       Specifications • Regulation : < 15mV for a load variation from 0 to 100%. < 2 mV for a line variation from 198 to 264 V. • Ripple : < 3mV rms including : < 3mV peak to peak of switching signal < 5mV peak to peak of the signal at 100Hz < 15mV peak to peak of switching spikes -15V output • Regulation : < 30mV for a load variation from 0 to 100%. < 2mV for a line variation from 198 to 264 V. • Ripple : < 3mV rms including : < 4mV peak to peak of switching signal < 4mV peak to peak of the signal at 100Hz < 15 mV peak to peak of switching spikes                    +15V output        +/- 10 to 15V 2A or 12V 5A or 24V 1A              Current -15V (alone)   • Balanced-output power supply with common 0V. • Floating outputs on 4-mm safety sockets. • Ajustable output voltages : from ±10 to ±15V.       • I max : 2,1A in short-circuit condition 2A from 10 to 15V Current 24V (Adjustable from 20 to 30V) I max : 2,1A at the short circuit 2A from 20 to 30V Power • Max output power : 60W. • I max ±15V : 2A Protections • Against short-circuits by current limit. • Against overcurrent on source by fuse. • Overtemperature protection by thermal circuit-breaker 24V Output (Adjustable from 20 to 30V) Other specifications Indicators • Safety : Class II, Safety Extra Low Voltage (SELV) Complies with EN 61010-1, overvoltage category II, pollution degree 2. • EMC : Complies with EN 61326-1, performance criteria B, and EN 55011, ISM Group I, Class B. • Protection level : IP30. • Operating temperature : 5 to 40 ° C • Input voltage : 198 to 264 V, 50 / 60 Hz. • Mains input : C8 socket with CEI320 C7 removable cable (2 poles double insulation). • Power consumption : 78W max. • ON/OFF control : toggle switch • Dielectric strength : 3000 V between input to output. • Presentation : polycarbonate case screenprinted. Available between output + and •Regulation : < 15mV for a load variation from 0 to 100% < 2mV for a line variation from 198 to 264V •Ondulation : < 3mV rms including: < 5mV peak to peak of the switching signal < 8mV peak to peak of the signal at 100Hz < 25mV peak to peak of switching spikes • Green power-on LED indicator. • Overheat or overcurent red LED "status" indicator. Current +15V (alone) • I max  : 5,5A on the short-circuit 5A from 10 to 12V 4A at 15V 31 | www.elc.fr
ALF1502D 价格&库存
很抱歉,暂时无法提供与“ALF1502D”相匹配的价格&库存,您可以联系我们找货
