ERIC9
ERIC9
    LPRS
ERIC9 数据手册
eRIC Radio Transceiver Preliminary Data Sheet The easy Radio Intelligent Controller (eRIC) radio transceiver module is based on the Texas Instruments CC430F5137 System-on-Chip device to provide an intelligent radio sub-system that combines a high performance RF transceiver, RF band pass filters (BPF), an MSP430 microcontroller, 32Kb flash memory, non-volatile flash storage, temperature sensor, and a low drop voltage regulator. The device operates on the International licence exempt Industrial, Scientific and Medical (ISM) radio bands. eRIC thus extends the proven easyRadio product line by offering a low cost RF transceiver intended for high volume applications. The compact form factor, surface mount packaging and external antenna connector simplify product design and manufacture and provide for flexible placement of the module within an end product. Features Benefits          Simple serial data in/data out user interface and configuration 433 & 868MHz (UK & Europe), 315 & 915MHz (USA) Meets ETSI (Europe) & FCC Certified (USA) requirements Simplifies product design and manufacture Battery powered applications Can eliminate need for external application processor Minimises external hardware requirements for custom applications Secure communications Environment monitor Default ‘easyRadio’ Protocol Embedded ISM Frequency Bands Radio Approvals Small 15x20x2.2mm Surface Mount Device (SMD) Low power operation capable eROS Operating System & Application partitions Configurable & programmable User I/O AES 128 bit data encryption Built in Temperature Sensor easyRadio Operating System (eROS) eRIC’s processor memory is partitioned and embedded with a protected version of the easyRadio Operating System (eROS) that handles all the complex radio functions and thus eliminates the need for the user to program multiple control registers and understand their interaction. The other partition provides an optional user accessible application code area. Radio parameters such as frequency, channel, output power and data rate are passed by the application code and radio data is sent and received in the background by simply calling predefined functions. Also provided is a simple to use API that replaces low level chip specific code with intuitive pin commands that allow the multiple general purpose I/O pins and internal function blocks to be configured and interfaced to external hardware. These built in functions make customisation easy for the novice and powerful for advanced programmers. This architecture can eliminate the need for a separate application microcontroller and thus minimises cost and power consumption for simple ‘sense and control’ RF nodes such as might be employed within the ‘Internet of Things’. By default (factory settings) the application code area is pre-programmed with a subset of the familiar easyRadio command and communication software that allows key operating parameters such as operating frequency, RF power output and host communication settings to be (optionally) pre-configured using the ‘easyRadio Companion’ software or to be dynamically changed using simple serial commands sent from the host processor. This allows multiple eRIC devices to communicate free from interference with each other and other local RF devices. In the default application mode, data is sent to and received from host processors or devices using 3.3V logic level serial data (inverted) with packet sizes up to 250 bytes. Low Power Radio Solutions Ltd. Two Rivers Industrial Estate Station Lane, Witney Oxon, OX28 4BH England eRIC_Datasheet_Preliminary_0.36.docx Tel: Fax: Web: Email: Technical: +44 (0)1993 709418 +44 (0)1993 708575 http://www.lprs.co.uk info@lprs.co.uk technical@lprs.co.uk Page 1 of 9 eRIC Radio Transceiver Preliminary Data Sheet Antenna 24 GPIO 1 23 BPF eRIC 19 Temp Sensor 18 RF Transceiver Serial Data In 4 Gnd 7 20 Microcontroller NonVolatile Flash Operating System 3.3V Regulator 8 Application 9 10 11 General Purpose I/O Serial Data Out 3 Vcc 6 21 RF GPIO 2 GPIO 5 22 17 16 15 14 13 12 Figure 1 eRIC Transceiver Block Diagram Pin/Pad Description Pad No 1 2 3 4 5 6 7 8 9 10 11, 12 Name GPIO GPIO SDO SDI GPIO Vcc Gnd JTAG Reset GPIO GPIO 13 14 - 21 22 23 GPIO GPIO RF Gnd Description General purpose digital I/O General purpose digital I/O Rx Serial Data Out (Default) Tx Serial Data In (Default) General purpose digital I/O Operating Supply Voltage Power Ground JTAG pins Reset & JTAG use General purpose digital I/O Bootloader & General purpose digital I/O General purpose digital I/O General purpose digital I/O General purpose digital I/O RF Ground – 0V 24 RF 50R RF Input/Output Notes Optional A-D Input Optional A-D Input Digital output - Connect to host serial input Digital input - Connect to host serial output Optional A-D Input +2.4V to +6V. Supply should be ‘clean’, noise and ripple free 0V Reserved Use – do not connect Restricted Use – Internal pull-up. Connect to Gnd for Reset When connected together invokes bootloader function on reset Mappable secondary function Optional A-D Input. Mappable secondary function Connect to antenna ground and local ground plane. Internally connected to Power Ground 0V Connect to suitable antenna via 50R PCB trace or use the alternative UFL connector Notes GPIO Pins/pads are configured (by default) on power up or Reset as Inputs with internal weak pull ups.. Exercise caution when connecting to any external circuitry.. Pins/pad 1-7 are physically (pin/pad sequence) and electrically compatible with easyRadio eRA400/900 Transceivers. The eRA ‘Busy’ and ‘Ready’ handshake and ‘Carrier Detect’ functions are NOT implemented in the current firmware. Interrupt function available on Pins/pad 1, 2, 3, 4, 5, 22 Mappable functions are UART, SPI, I2C, TimerA, TimerB ,Compare/Capture I/O See eROS Developers Manual for further details and descriptions of these functions. Low Power Radio Solutions Ltd. Two Rivers Industrial Estate Station Lane, Witney Oxon, OX28 4BH England eRIC_Datasheet_Preliminary_0.36.docx Tel: Fax: Web: Email: Technical: +44 (0)1993 709418 +44 (0)1993 708575 http://www.lprs.co.uk info@lprs.co.uk technical@lprs.co.uk Page 2 of 9 eRIC Radio Transceiver Preliminary Data Sheet Absolute Maximum Ratings Operating Temperature Range Storage Temperature Range Supply Voltage - Vcc All Other Pins/Pads w.r.t 0V Gnd Antenna -40° C to +85° C -40° C to +85° C -0.3 to +6.0 Volts -0.3 to +3.3 Volts 50V p-p @ < 10MHz Performance Data: Supply +3.6 Volt ± 5%, Temperature 20° C DC Parameters Supply Voltage (Vcc) Internal Regulator (Vreg) Transmit supply current Receive supply current Sleep Mode current Initial Power Up Time Logic Levels Data Output Logic 1 Data Output Logic 0 Data Output Current Data Input Logic 1 Data Input Logic 0 Input Pull-ups/Downs RF Parameters Antenna Impedance Operating Frequency Pin 6 Min 2.4 2.95 6 6 6 All Max 6.0 3.65 33 50 3.1 0.1 6 2.0 0 15 3.6 0.2 100 24 24 -30 RF Power Output 869MHz 24 -30 Set by user Set by user ±10 ±5.2 ±127 -47 1.2 38.4 2.4 -111 -109 -91 -81 19.2 24 24 24 24 24 3, 4 Units Volts Volts mA mA uA ms Notes Volts Volts mA Volts Volts kΩ 10k load to 0V Gnd 10k load to internal +Vreg supply Under software control Hi/Lo drive 50 Ohms 402 434.00 470 MHz 868 869.85 870 MHz 902 915 928 MHz FSK Wideband MSK at 500kbps Modulation Transmitter RF Power Output 434MHz Frequency Accuracy FSK Deviation (Min) FSK Deviation (Max) Harmonics & Spurious Emissions Over Air Data Rate Receiver Receive Sensitivity 433MHz 868/900MHz 433MHz 868/900MHz Host Serial Data Rate Mechanical Size Pin/Pad Pitch Weight Typical 3.6 3.3 32 15 0.8 5 15 x 20 x 2.2 2.54 1.5 +10dBm RF power output Continuous mode @ 250kbps TBA See Note Under software control To internal +Vreg or 0V Gnd Via UFL connector or pads See Configuration Command set +12 dBm 50Ω load – 434MHz +5 dBm 50Ω load – 869MHz ±15 < -36 ppm kHz kHz dBm Overall 1.2kbps 58kHz filter bandwidth 250kbps, 540kHz Filter bandwidth Meets EN 300 220-3 500 Kbps Configurable 115.2 dBm dBm dBm dBm Kbps At 1.2kbps Data rate At 1.2kbps Data rate At 500kbps Data rate At 500kbps Data rate Host interface mm mm Standard 0.1 Inch grams *All Specifications are subject to change without notice Low Power Radio Solutions Ltd. Two Rivers Industrial Estate Station Lane, Witney Oxon, OX28 4BH England eRIC_Datasheet_Preliminary_0.36.docx Tel: Fax: Web: Email: Technical: +44 (0)1993 709418 +44 (0)1993 708575 http://www.lprs.co.uk info@lprs.co.uk technical@lprs.co.uk Page 3 of 9 eRIC Radio Transceiver Preliminary Data Sheet Notes When power is first applied to the module the processor retrieves ‘calibration’ data for the RF section that compensates for temperature and power supply voltage variations. The transceiver will then be ready to transmit or receive (default) and would normally be left in this state, ready to receive data. The internal Vreg is not brought out to a specific pin/pad. Should there be need to connect external pull up resistors then connection should be made to a spare GPIO pin/pad configured as a ‘High’ Output. Power Supply The supply used to power the transceiver should be ‘clean’ and free from ripple and noise (
ERIC9 价格&库存
很抱歉,暂时无法提供与“ERIC9”相匹配的价格&库存,您可以联系我们找货
