ERA400TRS
ERA400TRS
    LPRS
ERA400TRS 数据手册
Low Power Radio Solutions Ltd Data Sheet easyRadio Advanced ISM radio modules Modules Included: ERA400TRS ERA900TRS ERA400TS ERA900TS Datasheet Revision 3.4 April Page 1 of 20 Copyright LPRS 2011 . Contents Changes to this document ................................................................................. 4 Terms and Conditions of Use............................................................................... 4 Introduction to easyRadio Advanced ........................................................................ 5 New features: ............................................................................................... 5 Basic Specifications ........................................................................................ 5 ERA400TRS/ERA900TRS Transceiver Description .......................................................... 6 Easy-Radio Transceiver Block Diagram ................................................................... 6 Physical Dimensions ........................................................................................ 7 Pin Description (RAW RF Data mode) .................................................................... 8 ERAx00TS Transmitter ...................................................................................... 9 Block Diagram ............................................................................................... 9 Physical Dimensions ........................................................................................ 9 Pin Description .............................................................................................. 9 Application & Operation ERx00TRS-03 .....................................................................10 Typical System Block Diagram ............................................................................10 Timing Specifications – Applies to all EasyRadio Advanced Modules. ...............................10 Absolute Maximum Ratings ERA400TRS & ERA900TRS....................................................11 Performance Data: ERAxxxTRS Supply +5.0 Volt ± 5%, Temperature 20° C ........................11 ERA400TRS Channel Frequencies vs Bandwidth Settings ................................................12 easyRadio Configuration Command Set ....................................................................13 RS232 Communication Settings ...........................................................................13 RF POWER Settings .........................................................................................13 RF Channel Settings ........................................................................................14 Bandwidth ...................................................................................................14 Band Plan ....................................................................................................14 MISCELLANEOUS COMMANDS ..............................................................................14 TEST MODES .................................................................................................15 RAW Data Mode (TRS Only at time of print) ...............................................................16 Notes: ...........................................................................................................17 RSSI ...........................................................................................................17 PCB Layout ..................................................................................................17 Power Supply ................................................................................................18 Antennas .....................................................................................................18 Product Order Codes ..........................................................................................18 easyRadio Advanced Module Firmware Version ...........................................................19 Datasheet Revision 3.4 April Page 2 of 20 Copyright LPRS 2011 . Document History .............................................................................................19 Copyright .......................................................................................................19 Disclaimer ......................................................................................................19 CONTACT INFORMATION ......................................................................................20 Datasheet Revision 3.4 April Page 3 of 20 Copyright LPRS 2011 . Changes to this document This data sheet has been updated to reflect firmware changes throughout the range of modules. Specific alterations are recorded in the documentation history later in the document. Terms and Conditions of Use Low Power Radio Solutions Ltd has an on-going policy to improve the performance and reliability of their products; we therefore reserve the right to make changes without notice. The information contained in this data sheet is believed to be accurate however we do not assume any responsibility for errors or any liability arising from the application or use of any product or circuit described herein. This data sheet neither states nor implies warranty of any kind, including fitness for any particular application. easyRadio modules are a component part of an end system product and should be treated as such. Testing to fitness is the sole responsibility of the manufacturer of the device into which easyRadio products are fitted, and is expected BEFORE deployment into the field. Any liability from defect or malfunction is limited to the replacement of product ONLY, and does not include labour or other incurred corrective expenses. Using or continuing to use these devices hereby binds the user to these terms. Datasheet Revision 3.4 April Page 4 of 20 Copyright LPRS 2011 . Introduction to easyRadio Advanced  easyRadio Advanced (ERA) modules extend on the simplicity of previous easyRadio(02) modules by incorporating truly innovative features, including the ability to change bandwidth of the radio from 19.2KHz down to 12.5KHz, which means narrowband performance on a wide-band budget. Internal temperature measurement ensures less than 1.5KHz frequency drift from ambient 20°C, over a range of -40°C to +85°C, as well as providing a usable thermometer for the connected application accurate to within 1°C. Modes of transmission include an enhanced easyRadio protocol with 16-bit encryption and anticross talk software, plus raw data modes where users can now use self-coding system which can be set to interface to any other raw data module on ISM bands in both FSK (FM) and ASK (AM) modulation. With the addition of three (total 4) separate data buffers, data throughput has been massively improved by around 25%*. Datasheet Revision 3.4 April      New features: A new digital RSSI (Received Signal Strength Indication) now reduces the requirement for the host to handle A-D measurement and can be called via a simple command for either the current RSSI level or the signal strength of the last received data packet. This value can also be delivered as the first BYTE in the delivered packet. Temporary channel/power level selection: This new command allows the user to scan other channels without storing the settings in internal EEPROM, therefore not reducing the life of the EEPROM through repetitive modification. Free flash firmware upgrades. Using the tools from LPRS, new updates/features can be quickly programmed making a truly future proof solution. Custom firmware can also be used (Contact LPRS for details) Back compatibility with 02 modules. Temperature compensation plus crystal controlled synthesiser for frequency accuracy less than +/- 1KHz over full temperature range Temperature sensor usable by host Basic Specifications High sensitivity receiver o -107dBm @ 19.2 Kbps o -112dBm @ 4.8 Kbps o -117dBm @ 2.4 Kbps  Current o Receiver: 21mA (Max) o Transmitter: 32mA (Max)  User Programmable: Frequency (Up to 132 channels) Bandwidth (Down to 12.5KHz) RS232 Data Rate Output Power (Up to 10dBm) 10mW @ 434MHz 5mW @ 869.85MHz  Page 5 of 20 PageCopyright Copyright 5 of 20 LPRS LPRS2011 2011 . ERA400TRS/ERA900TRS Transceiver Description The easyRadio Transceiver is a complete sub-system that combines a high performance very low power RF transceiver, a microcontroller and a voltage regulator: easyRadio Transceiver Block Diagram 3.3v Regulator RFIC Carrier Detect (Pin 3) μ Processor Temperature Sensor Vcc (Pin 8) BUSY (Pin 4) Serial Data Out (Pin 5) Serial Data In (Pin 6) Ready (Pin 7) EEPROM Ground (Pins 2 & 9) The Serial Data Input and Serial Data Output operate at the standard 19,200 Baud and the two handshake lines provide optional flow control to and from the host. The easyRadio Transceiver can accept and transmit up to 180 bytes of data, which it buffers internally before transmitting in an efficient over-air code format. Any other easyRadio Transceiver within range and on the same channel that „hears‟ the transmission will decode the message and place the recovered data within a receive buffer that can then be downloaded to the receiving host for processing and interpretation. Radio transmission and reception is bi-directional (half duplex) i.e. transmit OR receive but not simultaneously. Increased internal buffers however, allow the user to upload while a download is in progress giving an appearance of fully duplex data flow. Datasheet Revision 3.4 April Page 6 of 20 PageCopyright Copyright 6 of 20 LPRS LPRS2011 2011 . Physical Dimensions 14.0 mm 38.0 mm 4.0 mm 10.0 mm ERA400TRS ERA900TRS 15.24 mm 1 2 3 4 5 6 7 8 9 Pin Pitch 2.54mm PCB Hole Size 1.0mm Pin Description (easyRadio mode) Pin No Name 1 Antenna 2 RF Ground 3 CD 4 Busy Output 5 Serial Data Out 6 Serial Data In 7 Host Ready Input 8 Vcc 9 Ground Datasheet Revision 3.4 April Description Notes 50Ω RF input/output. Connect to suitable antenna. RF ground. Connect to antenna ground (coaxial cable screen braid) and local ground plane. Internally connected to other Ground pins. Carrier Detect Digital Output to indicate that CTS function transceiver is ready to receive serial data from host. Digital output for received data to host Digital input for serial data to be transmitted Digital Input to indicate that RTS function Host is Ready to receive serial data from transceiver Positive supply pin. +2.5 to +5.5 Volts. This should be a „clean‟ noise free supply with less than 25mV of ripple. Connect to supply 0 Volt and ground plane Page 7 of 20 PageCopyright Copyright 7 of 20 LPRS LPRS2011 2011 . Checklist 1. The module operates internally from an on board 3.3 Volt low drop regulator. The logic levels of the input/output pins are therefore between 0 Volt and 3.3 Volts. (See specifications/performance data). 2. The serial inputs and outputs are intended for connection to a UART or similar low voltage logic device. Do not connect any of the inputs or outputs directly to an RS232 port. The transceiver module may be permanently damaged by the voltages (+/- 12V) present on RS232 signal lines. See Application Circuit (Figure 11) for typical connection to an RS232 port via MAX232 interface IC. 3. The „Host Ready Input‟ should be tied to 0 Volt (Ground) if not used, only when handshaking is enabled. 4. Outputs will drive logic operating at 3.3 Volts and inputs will be correctly driven by logic operating at 5 Volts. 5. Fit 1K resistors in series with data lines if connecting to 5V logic. Pin Description (RAW RF Data mode) Pin No Name Description 1 Antenna 2 RF Ground 3 CD/Config 50Ω RF input/output. Connect to suitable antenna. RF ground. Connect to antenna ground (coaxial cable screen braid) and local ground plane. Internally connected to other Ground pins. Carrier Detect 4 5 6 RX Select RX Data TS Data 7 TX Select 8 Vcc 9 Ground Datasheet Revision 3.4 April Notes Carrier Detect/Config mode select pin Active Low RX mode select pin Raw RF data output Raw RF data Input (Toggling this pin modulates the carrier) Enables the transmitter Active Low carrier. Positive supply pin. +2.5 to +5.5 Volts. This should be a „clean‟ noise free supply with less than 25mV of ripple. Connect to supply 0 Volt and ground plane Page 8 of 20 PageCopyright Copyright 8 of 20 LPRS LPRS2011 2011 . ERAx00TS Transmitter 3.3v Regulator Vcc (Pin 4) Temperature Sensor μ Processor RFIC Transmitter Serial Data Out (Pin 3) Serial Data In (Pin 6) EEPROM Ground (Pins 2 & 5) Block Diagram 4.0 mm 12.0 mm 31.0 mm ERA400TS ERA900TS 17.78mm 1 2 3 4 5 6 Pin Pitch 2.54mm PCB Hole Size 1.0mm Physical Dimensions Pin Description Pin N Name 1 RF Gnd 2 3 4 RF Out Serial Data Out Vcc 5 6 Gnd TXD Description Notes RF ground. Connect to antenna ground (coaxial cable screen braid) and local ground plane. Internally connected to Pin 5 50Ω RF output. Connect to suitable antenna RS232 Output for Command use (SDO) Positive supply pin. +2.5 to +5.5 Volts. This should be a „clean‟ noise free supply with less than 25mV of ripple Supply 0 Volt and Ground Plane RS232 Transmit Data Digital Input (SDI) Notes: 1. The module operates internally from an on board 3.3 Volt low drop regulator. 2. TXD input will be correctly driven by logic operating at 2.5 - 5 Volts. Input should not be driven by an analogue source. Datasheet Revision 3.4 April Page 9 of 20 PageCopyright Copyright 9 of 20 LPRS LPRS2011 2011 . Application & Operation ERx00TRS-03 The diagram below shows a typical system block diagram comprising hosts (user‟s application) connected to easyRadio Transceivers. The hosts (A & B) will be monitoring (collecting data) and/or controlling (sending data) to some real world application. Serial Data Output Serial Data Input Host (A) Busy Serial Data Output RF Link Easy-Radio Transceiver (A) Easy-Radio Transceiver (B) Host Ready Serial Data Input Busy Host (B) Host Ready Typical System Block Diagram The hosts provide serial data input and output lines and two „handshaking‟ lines that control the flow of data to and from the easyRadio Transceivers. The „Busy‟ output line, when active, indicates that the transceiver is undertaking an internal task and is not ready to receive serial data. The „Host Ready‟ input is used to indicate that the host is ready to receive the data held in the buffer of the easyRadio Transceiver. The host should check before sending data that the „Busy‟ line is not high, as this would indicate that the transceiver is either transmitting or receiving data over the radio link. It should also pull the „Host Ready‟ line low and check that no data appears on the Serial Data Output line. Timing Specifications – Applies to all easyRadio Advanced Modules. Host Serial Input/Output Host Character Format End of Data Delay RF Transmit Buffer Size 2400, 4800, 9600, 19200, 38400, 31250 (MIDI), 76800 & 115200 1 Start, 8 Data, No Parity, 1 Stop 2 x BAUD BYTE Duration Depends on Bandwidth 1-180 baud 1 Bits 2 mS mS Bytes 3 4 5 Notes 1. 2. 3. 4. 5. Data is inverted i.e. Start Bit is logic low. The inputs are intended for direct connection to a microcontroller UART or to RS232 inputs and outputs via an RS232 Level translator such as a Maxim MAX232, which invert the logic of the RS232 signals. This allows direct connection to, for example a Microcontroller UART. The data rate is user programmable (Default 19200 baud) and may differ between individual units within a system. (See Application Circuit diagram for logic level to RS232 interface figure 11). 1 start, 8 data, 1 stop = 10 bits @ 104uS/bit = 0.52mS/character at 19200 Baud. (Default) The „End of Data‟ delay is fixed at twice the character time. A fixed package overhead of xx is added to all packets. The buffer size is limited to 180 bytes. Sending more than 180 bytes will cause loss of data. a. CTS pin will go high 2 bytes before the buffer is full. This allows characters already sent to be accepted by the ER module. Datasheet Revision 3.4 April Page 10 of 20 PageCopyright 10 Copyright of 20 LPRS LPRS2011 2011 . P Absolute Maximum Ratings ERA400TRS & ERA900TRS Operating Temperature Range Storage Temperature Range -40° C to +85° C -40° C to +85° C Vcc All Other Pins (N.B.) Antenna - 0.3 to + 6 Volts - 0.3 to 3.3 Volts 50V p-p @ < 10MHz Must be insulated to prevent damage from ESD Performance Data: ERAxxxTRS Supply +5.0 Volt ± 5%, Temperature 20° C DC Parameters Supply Voltage (Vcc) Transmit supply current Receive supply current Sleep Mode current Pin Min Typical Max Units 8 2.5 3.3-5.0 5.5 Volts 8 32 33 mA 8 21 mA 8 800 µA 3.1 0.1 Volts Volts Interface Levels Data Output Logic 1 Data Output Logic 0 Logic Output Current Data Input Logic 1 Data Input Logic 0 Input Pull-ups RF Parameters Pin Antenna Impedance 1 RF Frequency 2.0 402 868 902 100 Typical 50 434 869.85 915 -5 -5 +9 +5 Min 25 mA 3.6 0.2 Volts Volts KΩ Units Ohms MHz MHz MHz Max 470 870 928 Notes 10k load to +Vcc supply 10k load to +Vcc supply 1 Notes See ER Configuration Command set Transmitter RF Power Output 1 Frequency accuracy ±2 9.9 2.4 2.025 FM deviation Harmonics/ Spurious Emmissions Over Air Data rate +10 +5 dBm (434MHz) dBm (869MHz) ppm Khz Khz KHz 50Ω load Depends on Frequency Overall 100KHz Spacing 25KHz Spacing 12.5KHz Spacing -47 < -36 dBm Meets EN 300 220-3 1200 19200 38400 bps Manchester Encoded 115.2 dBm dBm Kbps At 100KHz Channel Spacing At 12.5KHz Channel Spacing 2.4 -107 -117 19.2 Receiver Receive Sensitivity Serial Data Rate Datasheet Revision 3.4 April Page 11 of 20 Host interface. 6 PageCopyright 11 Copyright of 20 LPRS LPRS2011 2011 . P Logic Timing Initial Power Up Time Pin Min Mechanical Size Pin Pitch Weight Typical Max Units Notes 5 75 mS 2,3 mm mm gms (Standard 0.1 Inches) 38 x 14 x 4 2.54 3.5 Notes 1. The „Host Ready Input‟ and the „Serial Data Input‟ have „weak‟ internal pull-ups enabled. 2. When power is first applied to the module the processor retrieves „calibration‟ data for the RF section that compensates for temperature and power supply voltage variations. The transceiver will then be ready to receive (default) or transmit. It would normally be left in this powered state ready to receive data. 3. During power up the Busy Output line goes high and goes low once ready. ERA400TRS Channel Frequencies vs Bandwidth Settings Each channel frequency is calculated relative to the channel number, the channel width, and the start frequency of the channel. Three commands control the settings of each of these parameters: Channel command: ER_CMD#Cn - Where n is channel number (See command table) Bandwidth Command: ER_CMD#Bn - Where n is the Channel spacing Band Plan Command: ER_CMD#bn - Where n is the START frequency of the band plan being used The centre frequency of each channel is calculated using the formula: Centre Frequency (f) = b + cs + 𝑠 2 Where b = band plan start frequency c = channel number s = channel spacing Datasheet Revision 3.4 April Page 12 of 20 PageCopyright 12 Copyright of 20 LPRS LPRS2011 2011 . P easyRadio Configuration Command Set The programming software sends „Text Commands‟ to the modules and this action can be performed by terminal software or the host‟s Microcontroller using the following list of commands: Note that shaded items are either new 03 commands or changes from 02 modules. RS232 Communication Settings ER_CMD#U1 ER_CMD#U2 ER_CMD#U3 ER_CMD#U4 ER_CMD#U5 ER_CMD#U6 ER_CMD#U7 ER_CMD#U8 UART Data Rate 4800 9600 19200 38400 31250 76800 115200 ER_CMD#U? Get UART Value ER_CMD#A70 PARITY DISABLE ER_CMD#A71 ER_CMD#A72 EVEN PARITY ODD PARITY ER_CMD#A41 FAST ACK Enable ER_CMD#A40 FAST ACK Disable 2400 4800 9600 19200 38400 31250 76800 115200 2400 The module replies echos with the UART value. Eg: ER_CMD#U2 No ACK is required. DISABLED BY DEFAULT When enabled data = 1 Start, 8 Data, 1 Parity, 1 Stop OFF OFF ER400Series ER900 Series (Upper case i) See notes on “FAST ACK” below. RF POWER Settings ER_CMD#P0~9 ER_CMD#P? RF Power Output The module replies with the power value. eg: ER_CMD#P9 No ACK is required. Get Power Value Datasheet Revision 3.4 April Page 13 of 20 PageCopyright 13 Copyright of 20 LPRS LPRS2011 2011 . P RF Channel Settings ER_CMD#Cx Where x = Channel Number in Decimal ER_CMD#cx As Upper case C ER_CMD#C? Get Channel Value Eg Channel 5: ER_CMD#C5 or ER_CMD#C05 or ER_CMD#C005 Uppercase 'C' stores settings in EEPROM Lowercase 'c' does not store in EEPROM The module replies echoes with the current channel. Eg: ER_CMD#C9 No ACK is required. Bandwidth ER_CMD#Bx X=0 1 2 3 6 Band Plan ER_CMD#bx 12.5KHz 25KHz 50KHz 100KHz 150KHz 2400bps 4800bps 9600bps 19200bps 02 Compatibility ERA400 Default = 0 1 2 3 433.1 433.1125 458.5125 433.0 MHz MHz MHz MHz After this command, the Channel number will set to Channel 0. ERA900 869.7MHz 902MHz 863MHz This setting chooses the start frequency of Channel 0 MISCELLANEOUS COMMANDS ER_CMD#R0 ER_CMD#A00 ER_CMD#A01 ER_CMD#A10 ER_CMD#A11 ER_CMD#A20 Reset module (POR) DCS OFF (default) Recommended ON for new designs where back compatibility to older devices is not required DCS ON Encryption OFF Encryption algorithm (default) is created and owned solely by LPRS. It uses a 16-bit seed that can be set by the developer. Encryption ON CRC16 OFF The CRC16 routines are more efficient and secure than the old CRC8. For new Datasheet Revision 3.4 April Page 14 of 20 Power reset PageCopyright 14 Copyright of 20 LPRS LPRS2011 2011 . P applications it is recommended. All new Bandwidth settings use CRC16. This setting only applies to 02 compatibility mode. ER_CMD#A21 ER_CMD#A30/1 ER_CMD#A40/1 ER_CMD#A50/1 ER_CMD#A70 ER_CMD#A71 ER_CMD#A72 ER_CMD#a0/1 CRC16 ON(default) Repeater OFF/ON NOT YET IMPLEMENTED Fast ACK OFF/ON Handshaking OFF/ON Parity Disable Parity Even Parity Odd RSSI In Packet When enabled each packet is preceded by the 8 bit RSSI value of the received packet TEST MODES ER_CMD#T0 ER_CMD#T1 Upper FSK Carrier Modulated Carrier ER_CMD#T2 ER_CMD#T3 Lower FSK Carrier Get Firmware Revision ER_CMD#T4 ER_CMD#T5 RAW Data Test Modulated Carrier ER_CMD#T7 Temperature Sensor ER_CMD#T8 Last Packet RSSI ER_CMD#T9 Current RSSI Test Mode 0 Test Mode 1 With Temperature compensation Test Mode 2 Returns Firmware String: eg ERA400TRS V3.6.23 Out of CTS pin Without Temperature compensation Reply example: -15'C or 23.7'C Returns the HEX value of the RSSI register measured on the last valid packet. Live RSSI Value To successfully send commands do the following: 1. Send Command from host: e.g. ER_CMD#U5 2. In the case of a TRS/RS: o Wait for echo of command from module. 1. Send the ASCII string from the host: ACK (Set UART BAUD to 38400) e.g. ER_CMD#U5 The commands should be sent exactly as shown (case sensitive) with no spaces between characters. The ACK command is sent as three ASCII characters, ACK in sequence. „A‟‟C‟‟K‟ . Datasheet Revision 3.4 April Page 15 of 20 PageCopyright 15 Copyright of 20 LPRS LPRS2011 2011 . P RAW Data Mode (TRS Only at time of print) easyRadio Advanced modules have the added versatility of being used without the proprietary protocols from easyRadio and yet still being used as a multi-channel, multi-bandwidth module. This allows the user to set precise frequencies to replace other raw data devices on exact frequencies. Both FSK (FM) and ASK (AM) modes are supported, and with the integration of a configuration mode, AM/FM modes, power levels, channels and bandwidth settings, can be changed on the fly with a very efficient command structure. Enable RAW data mode: 1) When in easyRadio mode send the command ER_CMD#L40202 2) Perform a power reset with Pin 3 left either floating or held high Return to easyRadio mode: 1) Hold Pin 3 low while providing power (This will not change the default POR setting) 2) Once powered, send the command ER_CMD#L40200. This will reset the default POR setting to easyRadio Mode Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 ERA400TRS ERA900TRS 1 2 Mode Selection Pin 3 x x x 1 0 Antenna RF Ground Carrier Detect/Config Mode Pin RX Select (Active Low) RF RX Data Output TX Data Input TX Select (Active Low) VCC Data Ground 3 4 5 6 7 8 9 1 = +V, 0 = 0V, x = Don’t Care Pin 4 Pin 7 1 1 0 1 1 0 0 0 0 0 Mode Sleep RX Enabled (Output on Pin 5) TX Enabled (Input Modulation on Pin 6) Module asleep but higher current (Not recommended) Configure mode Once in configure mode, Pins 5 & 6 return to functional UART pins at the stored module BAUD rate (default 19200). The configuration command set ALL setting in one command which is 5 bytes long: BYTE 1 Bandwidth/AM-FM BYTE 2 Band Plan BYTE 3 Channel BYTE 4 Power Level BYTE 5 CSUM Each byte uses Hex values in 8-bit format and corresponds to the settings used when selecting parameters in normal ER commands. Bit 7 of BYTE 1 is used to switch between AM/FM modes. 0 = FM, 1 = AM. Therefore, to set an FM channel 10 at 12.5KHz Spacing on Band-plan 0 and power level 9: The configuration word would be: 01 00 0A 09 14 (Note CSUM at BYTE 5) Datasheet Revision 3.4 April Page 16 of 20 PageCopyright 16 Copyright of 20 LPRS LPRS2011 2011 . P The module will ALWAYS respond with an ERROR Status Byte: 76543210 7 6 X X 5 PLL 4 BW 3 BP 2 C 1 P 0 CSUM A high in ANY of these positions indicates a failure in the Values used. Bit 5 (PLL) indicates a failure to lock frequency using the settings requested and returns the module to the previously set mode. Exit Configuration Mode: Simply return Pin 3 to the High State and once all operations are completed (After delivery of ERROR Status BYTE) the Radio will return to RAW Data Mode with the new settings. Notes: RSSI The Receiver/Transceiver has a built in RSSI (Received Signal Strength Indicator) that provides a digital value relating to the power at the input. This value can be read back using the ER command “ER_CMD#T8” or can be set to deliver the value as the first byte of each packet. This value will be different, depending on the bandwidth currently in use. The graph below explains how to interpret the values:
 PCB Layout The Ground (0 Volt) pins of the receiver should be connected to a substantial ground plane (large area of PCB copper) connected to 0 Volt. It is suggested that a double sided PCB be used with one layer being the ground plane. Datasheet Revision 3.4 April Page 17 of 20 PageCopyright 17 Copyright of 20 LPRS LPRS2011 2011 . P Power Supply The supply used to power the receiver should be „clean‟ and free from ripple and noise (
ERA400TRS 价格&库存
很抱歉,暂时无法提供与“ERA400TRS”相匹配的价格&库存,您可以联系我们找货
